Old Apr 08, 2010, 12:58 AM
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Video
Dynamax/Big Screamer 8.8kw bench run
For the vewing pleasure of power hungry EDF crazies everwhere.
Knife Liddle is offline Find More Posts by Knife Liddle
Old Apr 08, 2010, 02:13 AM
lavochkin's Avatar
Mokena,Illinois -United States
Joined Oct 2006
Sweet Lee!! But damn 200 amps!!!!!!! With an exhaust on that it will just go up. I wonder what efflux will be then with a proper exhaust. It sounds sweet though at that rpm.
lavochkin is offline Find More Posts by lavochkin
Old Apr 08, 2010, 02:33 AM
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Wow... definitely the wrong Kv! I am only pulling 150A on 15S with the 650Kv setup, and generating 22 pounds of thrust!
JimDrew is offline Find More Posts by JimDrew
Old Apr 08, 2010, 02:52 AM
lavochkin's Avatar
Joined Oct 2006
Run it on 10s and see what it does then. Id be interested in those numbers.
Old Apr 08, 2010, 06:51 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Jim, I think my thrust scale must be giving low readings, because even when I duplicate the 12s tests, I`m about 1.5lbs lower than what you guys get.
We should be pretty close to the same rpm with the two setups according to my math, so the thrust should be very close too.
Old Apr 08, 2010, 06:53 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I`m set up so that I can do 10s. I`ll check it for you, but I need to wait until my neighbors are awake, LOL.
Old Apr 08, 2010, 07:45 AM
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Now put it in a Starfire of simular sport jet and do 200+mph
rvincent is online now Find More Posts by rvincent
Old Apr 08, 2010, 07:56 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I`ve purchased a Cyclone kit ICDF from the 90`s just for that purpose Bob.
Old Apr 08, 2010, 08:29 AM
rvincent's Avatar
Joined Jul 2004
Sweet Lee
Old Apr 08, 2010, 10:06 AM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
yeah, youyr rails should be centerline with the fan, the fan is wanting to push downward with the position of the rails the way they are, cause drag, hence lower thrust readings. you think the eflux would be higher than that too. do you read from just one spot, or move it around to find the best spot?
corsair nut is online now Find More Posts by corsair nut
Old Apr 08, 2010, 10:17 AM
rvincent's Avatar
Joined Jul 2004
The efflux is MUCH higher, but he is reading it without a tail pipe
Old Apr 08, 2010, 11:42 AM
Current project: Electrolyte
pdawg's Avatar
United States, CA, Torrance
Joined Apr 2004
Great video! Your adapter sounded very smooth...even at 30k rpm.
pdawg is offline Find More Posts by pdawg
Old Apr 08, 2010, 12:40 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I moved it around, but can only do short bursts with this esc. I have another Monster on the way, then I can get a little better readings on everything.
Also, I`m going to get a tailpipe on it that will fit the AS nacelle and get the efflux up. Will probably drop to 11s when I do that.
Old Apr 08, 2010, 12:43 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Thanks, yes I`m very happy with the results of my shade-tree adapter. It does run very smooth, but could even be a touch smoother by playing with the position of the rotor and spinner. Haven`t done that yet. I just bolted it on.
Old Apr 08, 2010, 01:30 PM
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
no wonder it was an 18 sec. video. Poor 30c battery's are melting. Wonder how many amps the 40-50c packs would kick out!
efficieny..huh... what's that?
Sounds cool though!
stoneenforcer is online now Find More Posts by stoneenforcer
Mini-HowTo My home-made Dynamax/Big Screamer combo Knife Liddle Electric Ducted Fan Jet Talk 62 Jul 19, 2010 08:58 AM
For Sale OS 61FX Bench Run Only Kevlar Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 06, 2010 07:06 PM
Sold AstroFlight 05 Brushless Motor #806 3-Turn; Bench run only old_dude Aircraft - Electric - Power Systems (FS/W) 2 Sep 27, 2009 01:29 PM
Discussion Dynamax Scorpion 630kv Bench Test DForbes Electric Ducted Fan Jet Talk 12 Aug 24, 2009 09:49 PM
Video TJ-100/3D fan run up on 11s 100amps, 3.8kw, and 48.4K rpm!! Knife Liddle Electric Plane Talk 0 Jun 19, 2008 10:07 PM
