Old Feb 07, 2009, 10:32 PM
Have Fun! Land, Sea or Air
jetcaptain's Avatar
United States, TX, Austin
Joined Jul 2006
Profile MIG-25 "Foxbat"
For all you MIG lovers out there, here is a big profile pusher jet for you.
This is the brain work of crxmanpax(the design) and myself(plans drawing). Currently crxmanpat is building the first prototype, but says the parts are fitting well and it's time to post the plans.
Wing Span: 32.5"
Length: 49.5"
Weight: 20oz with electronics and battery.
jetcaptain is offline Find More Posts by jetcaptain
Old Feb 07, 2009, 10:37 PM
jetcaptain's Avatar
Joined Jul 2006
Test fit pictures
These pictures are from the first test fit by crxmanpat.
Old Feb 08, 2009, 09:50 AM
United States, CT, Torrington
Joined Jun 2006
Hi Jetcaptain,
It's a beautiful Mig-25. Thank you for sharing the drawings. I would like to build one for myself.
Would you give me more info how you set this plane up, please.
I would like to know how you set ailerons and elevator, motor and prop size, battery pack size.
Rcminh
rcminh is offline Find More Posts by rcminh
Old Feb 08, 2009, 02:48 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I got the plane glued together this morning and just did some glide tests to determine CG. She glides real nice with the CG at ~4" from the wing break.
Due to the larger size of this plane, I'm planning to use a Grayson Super ParkJet combo with an APC 6X5.5E and a 3S 2200mAh lipo.
I weighed all the components the other night and came up with 17oz. By the time I add hinges, control horns and rods and the CF spar I should be somewhere around 20oz AUW.
I'll post more pics later.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Feb 08, 2009, 03:05 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Here's a pic to give you an idea of the size of the plane. I am 5'6" and I'm holding the plane right up against my body.
Pat
Old Feb 08, 2009, 03:07 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Oh, and just for grins I decided to see if something would fit. Those are GWS EDF55 fans.
Pat
Old Feb 08, 2009, 03:10 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Rcminh
Rcminh,
I posted my motor, prop and lipo choices above. As for ailerons, I'm going to do what I always do and use a single GWS Naro servo on each side, then hook both the aileron and elevator together so that they move in unison.
Pat
Old Feb 08, 2009, 04:40 PM
jetcaptain's Avatar
Joined Jul 2006
Pat, that's looking really nice. Thanks for the CG location, I will update the plans.
Old Feb 08, 2009, 04:41 PM
jetcaptain's Avatar
Joined Jul 2006
Looks like we posted these plans in the wrong forum!
Pat
Old Feb 09, 2009, 01:40 PM
Pushing the Limits of FFF
wirbech's Avatar
United States, CA, Sierra Madre
Joined Jun 2005
Pat,
I have a couple of hot 55mm fans that will drop right into this one.......You hay see one at the field in the next couple of weeks.
John
wirbech is offline Find More Posts by wirbech
Old Feb 14, 2009, 11:59 AM
Binome's Avatar
Joined Jan 2009
Sorry to be a pain - but I would also like to build one of these in 6mm Depron - but I am not sure what you mean by the following CG location
"CG at ~4" from the wing break".
I know this might sound stupid for you but please would you let me know what the wing Break is /where does it start ?
once I understand this I can look at build this great Plane.
Martyn
Binome is offline Find More Posts by Binome
Old Feb 14, 2009, 12:38 PM
You sabotaged my plane.
eliworm's Avatar
Arizona
Joined Jun 2002
Pat, Whats your word on this one. I've wanted to do one of these for a while.
JIm
eliworm is online now Find More Posts by eliworm
Old Feb 14, 2009, 01:19 PM
jetcaptain's Avatar
Joined Jul 2006
Martyn
Here is the CG location. Good luck on your build, and make sure to post pictures of your progress.
Old Feb 14, 2009, 06:30 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Jim,
I will try to slap everything in it tonight and fly tomorrow. Had a couple consignment builds to take care of first.
Pat
Old Feb 14, 2009, 06:45 PM
jetcaptain's Avatar
Joined Jul 2006
Can't wait to see this one fly. Hopefully there is enough taileron area.
Mig 25 Foxbat hoser Electric Ducted Fan Jet Talk 38 Feb 22, 2011 09:45 AM
Discussion mig 25 foxbat lavochkin Electric Ducted Fan Jet Talk 1 Apr 06, 2007 09:39 PM
Discussion does anyone know about ejf mig 25 foxbat? lavochkin Foamy EDFs 3 Apr 06, 2007 09:16 PM
Jet Design Contest-Mig 25 Foxbat Frenche Electric Ducted Fan Jet Talk 8 Dec 06, 2004 11:44 AM
Edf-50 MiG-25 Foxbat Tyson Electric Ducted Fan Jet Talk 6 Feb 26, 2002 05:04 AM
