Old Aug 14, 2002, 07:12 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Aileron Torque Rod Connections
Anybody have any good pictures or diagrams of a 'quick connect' torque rod setup?
I'm wanting something that can be easily disconnected when the wing is removed. Can't seem to get the right picture in my head, and thought I could use some help.
Please?
Gene Bond is offline Find More Posts by Gene Bond
Old Aug 14, 2002, 11:09 AM
Master Nursery Builder
The_Giver's Avatar
Canton, GA
Joined Jan 2001
I don't remember who, but I know someone was using insulation stripped from some wire and/or small diameter heat-shrink tubing.
-O Geoffrey
The_Giver is offline Find More Posts by The_Giver
Old Aug 14, 2002, 01:03 PM
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
So you're looking for a setup so that the aileron servo can stay in the fuselage while you remove the wing? What application is this? It's rather unusual.....
BEC is offline Find More Posts by BEC
Old Aug 14, 2002, 03:10 PM
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
And it's not a good idea!
"Easy on, easy off"... with "easy off" IN the air.. crunch!
Sparky Paul
http://www.angelfire.com/indie/aerostuff
PJB's Seriously Aeronautical Stuff
http://home.earthlink.net/~pjburke1/aindex.html
Sparky Paul is online now Find More Posts by Sparky Paul
Old Aug 14, 2002, 03:32 PM
Senior Member
Paul Penney's Avatar
Ancaster, Ontario, Canada
Joined Nov 2000
servo heads
Paul Penney is offline Find More Posts by Paul Penney
Old Aug 14, 2002, 03:33 PM
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
Buddly, how did you secure those where the servo arms connect to the torque rods? Epoxy?
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old Aug 14, 2002, 03:37 PM
Senior Member
Joined Nov 2000
Dreamer,
Nope, the wire sticks up, and you drill a small hole on either side of the little round part on the servo head, and stick it through the wire. Use CA to secure. Make sure it is a TIGHT hole!
Simple as 123. My own invention......
Old Aug 14, 2002, 06:22 PM
Leave me alone!
Joined Feb 2002
I like it! I'll remember that one
Martin
Old Aug 14, 2002, 06:59 PM
Senior Member
Joined Nov 2000
I'm surprized I thought it up!
Old Aug 14, 2002, 08:26 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Um ah....
Old Aug 14, 2002, 08:32 PM
Senior Member
Joined Nov 2000
Sparky,
haha, dont worry, I got a screw in there....
Old Aug 14, 2002, 10:29 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
No particular application, just a recurring thought about how to handle ailerons on a 2 piece wing, w/o using 2 servos.
On my UltaFlyer (Cheap Parkflyers), I'm using the little DuBro Micro clippy-thingamajiggers instead of Z bends on the aileron horns, but it's a pain to attatch. The linkage sucks, too, so I'll probably just add another servo if it seems to fly decent on the EPS100 or J250....
aileron torque rod question??? bosley Parkflyers 15 Sep 20, 2005 02:21 PM
How to install torque rod for top-hinged aileron made of solid balsa dimple The Builders Workshop 2 Sep 10, 2003 08:19 AM
GWS Zero Aileron Torque Rod carguy Parkflyers 8 Oct 19, 2002 06:58 AM
Best Torque Rod setup....? Alan W High Performance 2 Jan 25, 2002 11:41 AM
