Old May 23, 2013, 05:15 PM
Joined Jan 2004
Difference in Cox engine speed between pusher and tractor?
I was just wondering if there was an appreciable difference in the Cox engines when run as a pusher vs. a tractor configuration. Are the ports somehow timed to run better in the normal clockwise direction?
gettinout is offline Find More Posts by gettinout
Old May 23, 2013, 05:50 PM
Canada
Joined Nov 2000
No...they are not, rotation direction makes No difference whatsoever.
Possibly varying friction on thrust plate vs Crank face might... if any.
Bare is offline Find More Posts by Bare
Old May 23, 2013, 06:16 PM
"Unnecessary Necessity"
coriolan's Avatar
Canada, BC, Vancouver
Joined Sep 2006
The reedy run either way the same, Cox TD requires pusher prop or KK crankshaft!
coriolan is offline Find More Posts by coriolan
Old May 23, 2013, 09:47 PM
Joined Jan 2004
Okay, thanks. The reason I asked was because I wanted to use a couple of the Cox Sopwith Camel propellers on a couple of vintage design airplanes, and the props are left handed props.
Old May 23, 2013, 10:42 PM
Western KY
Joined Sep 2003
+1
If you're using the engine in a standard tractor configuration with a left-hand prop, you'll see no difference on the reedies.
Andrew0820 is online now Find More Posts by Andrew0820
Old May 24, 2013, 09:52 AM
Power Upward
GeorgeG97322's Avatar
United States, OR, Albany
Joined Jun 2007
Difference will be in the props used. I don't think the pusher props are as good as many of the tractor props are.
George
GeorgeG97322 is offline Find More Posts by GeorgeG97322
Discussion tractor vs pusher goly Foamies (Scratchbuilt) 14 Mar 28, 2013 08:02 AM
Question Pusher and Tractor Props 94'325is Power Systems 12 Feb 20, 2013 01:03 PM
Question Tractor and pusher propellers question minduim The Builders Workshop 6 Feb 03, 2013 10:43 AM
Discussion Difference in noice, Tractor/Pusher Electraglide Modeling Science 7 May 04, 2011 12:23 PM
Difference between 6v and 7.2v speed 400 engines??? soholingo Beginner Training Area (Aircraft-Electric) 13 Jul 20, 2001 10:50 PM
