Old Jun 13, 2009, 01:53 PM
Joined Jun 2009
SU-27 XXL custom build and prop help
Hey guys this is my custom SU-27. XXL
I really need some prop help.
I am will be running onea these ebay motors
http://cgi.ebay.com/ws/eBayISAPI.dll...m=260295786048
yes i like speed lol this plane is renforced. but what would be a good prop to use?
on my old SU-27 it had a 4.75x4.5 and that was a stock motor it was slow and hard to keep afloat, so i swaped out to a brushless motor and was running a CLIPPED prop a 8x6 and it gave it OK speed but i wanna try and max her out
i am running a 3s 1800 cell lipo
and for backup a 3s 2525 hehehe
but what prop should i use that would give me the most power?
And any ideas on some micro retracts??
and YES she has rudders lol
moonpie33 is offline Find More Posts by moonpie33
Old Jun 13, 2009, 03:43 PM
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
My initial thoughts are you may need a small prop for this, as the KV is very high. Maybe a 4-5 incher. (I've no actual experience with it.)
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Jun 13, 2009, 03:54 PM
Iranair
SoliSab's Avatar
Joined Aug 2007
Hi moonpie33
It is very clever of you to ask about the prop for this motor, because
chances that this motor is a heli motor is very much, and that means
that you have got to go way down in prop size or use gear.
I am very ankshes to see what the more experience guys will tell you
about it.
Good Luck........
SoliSab is offline Find More Posts by SoliSab
Old Jun 13, 2009, 04:05 PM
Joined Jun 2009
i was thinking of a gear box but its a $10 ebay motor soo im not really worried. i will prolly run the small prop first then go to the cliped prop after i ballance it.and i believe it is a heli motor lol i was like dang o well but it should be cool either way....
Old Jun 13, 2009, 08:25 PM
Joined Jun 2009
i just flew her and she flies good but she needs more power
3s 1800 lipo
ebay motor up to 1000 rpm the cheap kind
cliped 8x6 prop
Old Jun 14, 2009, 08:41 AM
Iranair
SoliSab's Avatar
Joined Aug 2007
3s 1800 lipo
cliped 8x6 prop
If you haven't burned the motor or the esc. until now so you really are lucky. becarefull with that. Ask or read about high kv motors, and what you have to do so you just dont burn everything.
I am just writing this because i have been there, done that....
Good Luck with it, and please let us know how it goes .........
Old Jun 14, 2009, 01:17 PM
KZ RIDER
raythomas's Avatar
Confederate States of America
Joined Nov 2001
where exactly is the CG or balance point on your plane?
If you measured from the very tip of the nose, how far back does it come out to be?
How much throw do you have on your control surfaces?
Thanks Ray
raythomas is offline Find More Posts by raythomas
Old Jun 14, 2009, 01:46 PM
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
Yup, ya got to watch them high KV motors, and the props you put on them. High KV motors benifit from small props (cut down or not). "Over-prop" and the ESC/motor system may burn out.
Old Jun 14, 2009, 02:47 PM
Joined Jun 2009
as for CG and throw
well i like to max the throw out and it is maxed out lol
im a 3D pilot at heart and cant resist
the CG is 13 inches from nose to back
but i might go 12ish
it has a nice glide slope!!!!!
and what speed to you think this plane can fly before ripping apart
and i have been reading that whole su-27 guide like crazy trying to determine which is the best motor and prop
Old Jun 14, 2009, 03:12 PM
MartinT's Avatar
Joined Mar 2006
I have the original by Icarus, I fly it with the Grayson 2200 KV motor, and a 6x4 prop,
performance is A W E S O M E. Unlimited vertical and insane high alpha slowflight cap!
I modded the moving rudders as well, had to reinforce the vertical tails (put a carbon X in between both tails, and put a carbon spar spanning the horizontal tails and the fuselage. And put another spar running lengthwise in the fuse from nose to engine.
It is an awesome flyer!!!
Best regards,
Martin
MartinT is offline Find More Posts by MartinT
Old Jun 14, 2009, 11:06 PM
Joined Jun 2009
i ordered the another ebay motor but with 2200 kv motor and im gonna try the 6x4 prop hehehe
and i have templeates to go around!!!!!!!!!!
Gallery Ikarus SU 27 XXL Jurgen Heilig Foamies (Kits) 1607 Jun 11, 2014 11:31 AM
Help! Need motor help with HL SU 27 XXL shockflyer sgil2001 Pusher Prop Jet Models 0 Sep 03, 2006 10:57 AM
Discussion Finished Su 27 Xxl Help UBILDIT Foamies (Kits) 3 Jan 19, 2006 02:29 PM
Ikarus SU-27 XXL Build Thread jumpinj Pusher Prop Jet Models 2 Oct 21, 2005 05:05 AM
New Shockflyer SU-27 XXL Jurgen Heilig Foamies (Kits) 3 Feb 14, 2005 03:35 PM
