May 06, 2013, 08:06 PM
United States, PA, Meadville
Joined Feb 2011
I'm thinking cut it open on the bottom side perhaps a 1" wide piece containing the old CF. Put in some spars if you want to with grooves cut in the bottom where the cf will go. Put 1/2" wide strips on both sides of the carcass half way exposed. Mount a new CF on the replacement 1" strip. Then glue in and tape over.
I used an arrow from walmart in mine. Lots of criscrossing fibered packing tape on the outside and foam spars
