Old Oct 19, 2008, 07:31 PM
deburgess is offline
Find More Posts by deburgess
Joined Sep 2008
CX2 Transmitter DC Input Port
Is it possible to run the CX2 Transmitter from a DC power source rather than from batteries?
deburgess is offline Find More Posts by deburgess
Old Oct 20, 2008, 07:52 PM
modfly is offline
Find More Posts by modfly
Doing it in the Lateral Axis
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
Yes........but why would you want to do that?
modfly is offline Find More Posts by modfly
Old Oct 20, 2008, 08:50 PM
faithalone is offline
Find More Posts by faithalone
Faith Alone...In Christ Alone
faithalone's Avatar
USA, AR, Brookland
Joined Sep 2008
i have tried some rechargeable aa batteries and the result was horrible because of their low voltage output... using good high quality aa batteries (energizer or duracell etc.) they last a really long time so battery usage should not be too much of a problem...
faithalone is offline Find More Posts by faithalone
Old Oct 20, 2008, 11:10 PM
modfly is offline
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
what? I use rechargeable ni-mh in a lot of TX and have never had a problem. Alkalines drop under load to what the ni-mh read under the same load so how can that be a problem
Old Oct 28, 2008, 08:49 PM
Joined Sep 2008
Thanks for your replies.
I use the LP5DSM transmitter to run on a Heli-X simulator on my PC. I would like to plug in a DC adapter for when I practice. I tried to obtain a DC-adapter from Radio Shack with the correct tip polarity. However, the transmitter did not seem to work when the adapter was plugged into the DC port. Has anyone successfully used a LP5DSM transmitter with a DC-adapter?
Old Oct 28, 2008, 10:13 PM
modfly is offline
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
these charging plugs are wired so that the batteries in the TX only recieve charge current from the TX charge plug with then TX power switch is in the OFF position.
Old Oct 29, 2008, 07:10 AM
freechip is offline
Find More Posts by freechip
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
AS mentionned above, the LP5DSM transmitter plug is ONLY for charging, when you turn it on, it will disable the plug. I have always use NiMH in my LP5DSM and never had a problem & usually last for ever....volt reading from 5.8 on fressh charge down to 4.8 & then I recharge because thats what the manufacturer suggest not going below 4.8 volts....
freechip is offline Find More Posts by freechip
Data CX2 Transmitter (LP5DSM) has CCPM Mixing! MondoMor Coaxial Helicopters 29 Nov 17, 2008 10:00 AM
Discussion CX2 Transmitter Battery Terminal aztecgizmo Coaxial Helicopters 1 Jan 11, 2007 05:51 AM
transmitter dc inline jack size? supa phatty J Radios 3 Sep 21, 2004 11:39 PM
Minimum DC Input for Triton? rutat Batteries and Chargers 5 Mar 24, 2004 10:21 AM
Triton Charger and AC/DC Input stuka Batteries and Chargers 12 Nov 27, 2002 09:57 AM
