Old Apr 27, 2015, 10:46 PM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
Question
PL8 parallel charge cable options
So I have a Power Lab PL8 charger. Originally I used a MPA board but sold it not liking the size and picked up a paraboard. I still find that larger than I need. On my iCharger 306 I bought a large connection of these http://www.progressiverc.com/paralle...e-adapter.html and I am wondering how I can use these with my PL8. Seems I need some adapter to plug into the charger. Those just simply plugged into the 306 I had but not so simple with the PL8
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Yesterday, 06:16 AM
On loan to Texas
Joined Oct 2005
?? No one parallel charging a PL6 or 8 without a Paraboard??
Old Yesterday, 06:35 AM
davidmc36 is offline
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
One of their adapter boards into which you could plug your pigtails that split out/multiply your balance connections?
http://www.revolectrix.com/cellpro_adapters.htm
davidmc36 is offline Find More Posts by davidmc36
Old Yesterday, 07:00 AM
On loan to Texas
Joined Oct 2005
What mode (node wiring) do you set up the charger for then FMA Wiring mode or XH/EH?
Old Yesterday, 07:29 AM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
I don't recommend using squids since they don't have the fuse protection the better parallel boards have.
Ohmic is offline Find More Posts by Ohmic
Old Yesterday, 07:54 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
I would surmise XH. Same as if you were using any parallel board.
The charger will tell you if you made the wrong choice.
Old Yesterday, 10:44 AM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Those cables have JST-XH connectors. The connectors on the PL6 and PL8 are JST-PA. So you would have to find or fabricate a JST-XH to JST-PA cable.
If you buy a Paraboard for a PL6 or PL8 it comes with such a cable.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Yesterday, 09:23 PM
On loan to Texas
Joined Oct 2005
I am already using a powerboard I was just looking for a little more compact. I guess I will stay with it and in part for the fused protection.
Sold Walkera Parallel Charging Cable for 3 Walkera 1s Lipos JST XH Balance fluxcapacitor121 Aircraft - Electric - Helis (FS/W) 2 Mar 15, 2015 03:53 PM
Found parallel charge cable for 1s lipo Florin777 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Dec 16, 2014 12:52 PM
Found parallel charge cable for 1s lipo Florin777 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Dec 16, 2014 12:06 PM
Discussion PL8 Parallel charging displays TankPilot FMA Direct 7 Feb 21, 2014 05:54 PM
Sold Parallel Charge and Parallel Balance Cables $8 shipped flybydanny Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 21, 2013 10:07 AM
