Estes Proto X FPV with HD Camera RTF Review
The Estes Proto X FPV has a camera for FPV with viewing on a screen in the front of the transmitter and it can record video on an included micro memory card. While bigger than last years Proto X Nano it is a sweet little machine.
Proto-X FPV RTF (1 min 24 sec)
Dimensions: 4.5" x 4.5" diagonal between motors
Blade Length: 2.2"
Width blade tip to tip: 5 3/8"
Length blade tip to tip: 5 3/8"
Flying Weight: 2.05 oz.
Camera: 1280 x 720P HD, 30FPS 120 degree FOV
Operating Video Range: 240'
Transmitter: 2.4GHz
Transmitter Screen: 4.5" diagonal with sun screen
Battery: 1S 650mAh LiPo
Charger: USB charge cord
Camera Accessories: 4 GB memory card & reader
Manufacturer: Estes
Available From: Tower Hobbies and Fine Hobby Stores Everywhere
Price: $229.98 RTF
Last year I reviewed the Proto X Nano and was so impressed by the control I had of her that I bought several of them for Christmas presents. It had and still has a very stable hover and flew where I directed her with no bad habits. This year they have the larger Proto X FPV and she not only carries a camera she broadcasts the video image on 5.8 GHz and the video can be seen on a 4.5" screen on the front of the transmitter. Thanks to that screen I, my family and friends can see what a pilot in the Proto X FPV would see and they can see it in real time. While waiting for my Proto X FPV to arrive I downloaded the instruction manual and read it completely and learned quite a bit about her. Some of that information is worth sharing. I learned the transmitter is designed to automatically find the best frequency for best quality live video feed. If there is a problem the frequency can be programmed on the transmitter from 5.75 to 5.945 GHz to get better video transmission.
The Proto X FPV system has not one but two recording systems. There is space in the Proto X in back for a micro memory card. There is a button near the card and by pressing it once it starts to record and an LED flashes to let you know recording has started. Pressing the button again stops the recording. The second recording system is in the transmitter and it records the video signal received from the Proto X. A second memory card goes into the right side of the transmitter when the transmitter is off. There is a button on the front of the transmitter by the bottom right corner of the video screen. With the Proto X FPV linked to the transmitter one just pushes the record button and recording to the memory card in the transmitter is started. The word REC appears on the screen. Press the button for a second time and the recording stops. The recording made in the transmitter can be viewed on the video screen by playing the recording. I had no idea about these transmitter functions until I saw the instructions.
A video signal is not the only signal transmitted from the Proto X FPV to the transmitter. It also sends information on its battery voltage via telemetry and that information is displayed on the transmitter's screen at the top via voltage readout (4.5V is a full charge) as is the voltage of the transmitter with a separate graph bar. This way I can know how much voltage the quad has and plan on ending my flight before she runs out of voltage.
The camera is 1280 x 720P HD and shoots at 30 frames per second with a 120 degree field of view. The Proto X FPV comes set for Mode 2 operation which is the common method used here in North America with throttle and rudder on the left stick and forward and reverse and side to side controls on the right stick. It can be converted to Mode 1 operation for those that prefer that method of control. There are even trim tab location bars that can be viewed on the transmitter screen to know where the trim tabs are set.
The transmitter has two connections on the left side of the transmitter. One is for video FPV glasses and the other is for an ear piece. I will have to experiment with those once I get into the actual review. The servos can be reversed in the transmitter but I don't expect to be using that. I can also change the sensitivity setup to allow for faster or slower movements in standard/normal or expert mode. Expert mode is obtained and exited by pushing in the right stick. I also learned how to flip my Proto X FPV but I will share that in the main review. In fact lets get into the main review now.
INCLUDES
Estes Proto-X Quadcopter with HD Camera
  • 6-ch 2.4GHz Controller with Video Screen
  • Memory Card and Card Reader
  • USB Charge Cord
  • Sun Shield (five pieces) for Video Screen protection
  • Four Spare Rotor Blades
  • Blade Removal Tool
  • Seven LED Lights on Proto X FPV
  • Instructions
Additional Items Required
  • 4 Alkaline AA batteries for transmitter
  • Separate micro memory card for the transmitter
Features
FEATURES
  • Equipped with a 1280 x 720P camera that shoots HD videos that pilots can watch on the transmitter's 4.5" (114.3mm) screen
  • Memory card and card reader allow videos and images to be downloaded to a computer
  • 3-axis gyro and 3 accelerometers create extremely stable flight
  • May be flown indoors or outdoors (In relatively calm conditions per reviewer)
  • 6-channel 2.4GHz transmitter with hooded video screen for easy outdoor viewing
  • 650mAh 1S LiPo battery with USB charge cord
  • Ninety day limited warranty beginning at date of purchase
The Proto X FPV came fully assembled and ready to fly. No assembly was required of the Proto X FPV.
The Sun Shield came in five pieces with a base, two sides a front and a back. The pieces snap together and I used no glue. The shield snaps onto the transmitter to shield the video screen from the sun. It is easily removed and is not needed when watching the transmitter screen inside a room.
I installed the four AA batteries I supplied into the back of the transmitter.
To complete the Proto X I had to charge the flight battery. It came already installed in the Proto X FPV. I plugged the charge cord into a USB connector on my computer. I plugged the other end onto the tab for it on the back of the Proto X. Nothing! I read the instructions and connected the battery to the Proto X and the red LED in the USB connector turned on and the battery was charging. The instructions say a fully discharged battery can take up to 2 1/2 hours to recharge. I will want to get a spare battery or two in light of that information. The initial charge took about an hour and a full charge with a depleted battery took two hours and 18 minutes. Most of my recharges were with only a partially discharged battery.
For recording I installed the supplied 4 GB micro memory card into the Proto X FPV. The micro memory card was included along with a reader in the kit. I installed the 4 GB micro memory card into the back of the Proto X FPV. Only one memory card was included so I supplied a 2 GB micro memory card for the recorder in the transmitter. I installed it into the right side of the transmitter. The button to start and stop recording on the transmitter there is a button located on the right side front of the transmitter by the bottom right corner of the transmitter. The recorder in the Proto X is activated with a button on the back right of the Proto X before the start of the flight. The recorder in the transmitter can be activated and turned off with the button on the transmitter during the flight. Thus if something interesting is encountered during a flight the recorder in the transmitter can capture it. The memory card in the transmitter must be formatted in the transmitter the one in the Proto X FPV is not formatted. I do not switch these micro memory cards EVER!
Transmitter information and programming
When I turn on the transmitter it initializes and then tells when it is ready to bind to the Proto X FPV.
As discussed above the transmitter screen gives information on the voltage for both the Proto X FPV and the transmitter. The Proto X when fully charged reads 4.5 Volts on the screen and as it goes down the reading drops by .1V. The transmitter's voltage has been a bar as seen below.
The trim tabs allow for individual adjustment of the controls if needed. The screen has tab bars in the bottom corners to show how the trim tabs have been adjusted if at all.
Push the right stick down on the transmitter and hold it down for one second and you get into the programming menu. Make your selection by moving the stick up and down and when the one you want is high lighted press down on the stick again. In the menu area I can program the clock in the transmitter. I can select between standard/normal and expert flight modes and individually adjust the expert flight mode settings. The video card in the transmitter can be formatted and any transmitter recorded video can be played back on the screen on the front of the transmitter. The frequency for the FPV transmission can be manually programmed if needed (I didn't need to use this.). There is also set reverse but I didn't use that in this review.
Flight Modes
In Standard/Normal Mode the rates are set at 50%. Flips cannot be performed in this mode. 50% limits the amount the Proto X FPV will tilt and limits its movement and helps keep its speed down (But it is still capable of pretty fast flight.). The instructions says to switch between Normal rates and Expert rates high light the set sensitivity and push the right stick to the right. I found that did nothing but they switched if the stick was pushed down. In Expert Mode the rates are set at 100 and the Proto X FPV is much more responsive and aerobatics and flips can be performed. The rates can be adjusted in both modes. The rates are adjusted by using the trim tabs. I lowered the trim rates for aileron, elevator and rudder to 40 and that has made it an even more stable video platform. I have left the expert setting at 100. I have discovered that I can switch between standard/normal mode and expert mode with just a tap of the right stick down so the switch is quick and easy in operation.
Transmitter & Proto X FPV Videos
To use the transmitter recorder and play back it is necessary to format the memory card and this makes many little sections in the memory card. It will greatly reduce the recording available with that card if used in the Proto X FPV without removing the formatting. I used a separate 2GB micro memory card that I supplied in the transmitter. I used that recorder only to record something to show back on the screen. It is a nice feature to have to share something interesting spotted in a flight. I used the supplied 4 GB memory card only in the Proto X FPV and they are the videos recorded there that are shared later in this review. I treat the transmitter recorder as one for immediate view back or sharing and the one from the Proto X FPV as my recorder to share via my computer. For that reason I did not try and download the video from the transmitter recording. It is a nice feature to have and it can be activated while the Proto X is in flight by a push of a button on the front of the transmitter. The recorder on the Proto X FPV must be activated on the Proto X FPV before the start of a flight or it must be landed and activated and then the flight resumed. As with all video the quality of the picture depends in part on the amount of light available when recording.
Proto X FPV Features and Functions
To charge the flight battery it is necessary for the battery to be plugged into the Proto X FPV as the charger plugs into the Proto X FPV to charge the battery. No separate stand alone charging of the battery is available as sold.
There are two flight modes for the Proto X FPV: Standard/Normal and Expert modes. Expert mode allows the Proto X to bank more and thus fly faster. Also in expert mode it can do flips which cannot be performed in standard mode. I recommend that the first few flights, especially flights using FPV be performed in standard mode. The exception is if you are flying outside in a breeze. Then you might need Expert mode and flying in an open space as the greater rates lets you fight against a breeze better. The Proto X FPV will fly quite a bit faster than the Proto X Nano that I reviewed last year and it is quite a bit bigger. It is also a little more responsive to direction control input so some might find it slightly more hands on to keep in a hover as they may need to make more correction to stop initial directional input as they get use to the handling of the Proto X FPV. This learning curve was quickly learned by me but there was a short learning curve as the handling of the two is different. That said, the controls remain the same. In Mode 2 the left stick controls the throttle for climb, hover and descent as well as rudder for rotational turning in either direction. The right stick controls direction: forward, backward and to the left or to the right or a combination of directional moves.
To transition from Standard Mode to Expert Mode just push and hold down the right stick for a moment and they change. If you hold down the right stick for a second you get to the menu page. There one can scroll down to "Set Sensitivity" and select the mode by pushing down on the stick. Here you can select Expert Mode or back to Standard Mode. Standard Mode is the default mode when the Proto X FPV is turned on and bound to the transmitter initially. Thus there are two methods to change modes. The first is quick and easy the second is slow and complex.
From a flat level surface just power up the Proto X FPV and she will rise into a fairly stable hover in calm conditions. If outside in a breeze she will drift with the breeze and some correction will have to be applied to correct for the breeze. Even in calm conditions some minor correction is necessary to stay in a hover but it was easy to do with just a little practice and using only small stick movements.
To land just fly over the desired landing spot and get into a hover and slowly lower the throttle until the Proto X FPV touches down and then turn off the throttle completely. The Proto X FPV with a fully charged battery has plenty of power and can fly for a full ten minutes plus depending on throttle management.
In Expert Mode the rates come set at 100. When in that 100 setting a flip can be performed in any direction. With the Proto X FPV in a basically level position give some positive throttle for a slight climb. Move the right stick first in the opposite direction from which you want to flip and then rapidly to the direction you want to flip and then back to the center position. It took me some practice to get mine to flip and if I am not quick enough I just get directional flight and then reverse direction. The keys are rapid movement in Expert Mode and rate at 100.
This transmitter will also bind with and control my original Proto X Nano and I do better flips with it in Expert Mode than I do with the Proto X FPV. Possibly because I don't worry about it with the smaller Nano model. I recommend practicing over thick soft grass to protect the Proto X from damage should there be a crash.
I consider the FPV and the ability to record videos in flight to really be the special performance. I have other multi-rotors that are more aerobatic and I plan to use the Proto X FPV only as a camera platform.
Flying using FPV First Person Video
If you haven't flown FPV before I recommend you start in an open space as there is a learning curve to get used to flying this way. There is also a very slight lag between what the screen is showing on the transmitter and where the Proto X is actually flying. Although this is a very short lag I recommend you leave yourself some space from foreign objects, especially while getting used to this method of flying. Some propeller guards would have been helpful during this adjustment period as well but they don't have any with the Proto X FPV. If flying outside the sun screen is very helpful to keep the screen visible even in bright sunlight.
I started with the Proto X FPV facing away from me so its right was my right. I knew I had wide open space in front and to my sides (Very helpful to my confidence level and keeping me relaxed.) I powered her up, lifted into a hover at about five feet and flew forward. Using the left stick I did a slow 360 degree turn in place and resumed flying away from me. I climbed up to about 20 feet and was approaching a tree. I stopped forward flight and put her in reverse. A slight breeze pushed me to my right and while backing up I bumped into a small twig on a branch which I didn't see flying towards the tree. The branch stopped a prop from turning. The Proto X FPV started to crash and I looked out to see the Proto X FPV with my own eyes. A crash onto the grass was unavoidable so I killed the power and she hit the grass. NO DAMAGE! Flying over carpet and soft grass is highly recommended by me, especially when learning. I set her back upright on a walk way and resumed flying FPV. With just a little practice I have gotten a lot better. I can now fly over and under a number of objects without trouble and fly closer to hazards than I do with my FPV equipped plane. I have had a few more minor incidents (crashes) with no damage to date thanks to landing on grass or carpet. I still don't get quite as close to objects such as Christmas trees when flying FPV vs. visual and I avoid flying over people or pets at any time. All in all it has been a very enjoyable learning experience.
YES! The Proto X FPV is an easy multirotor to fly, especially in standard mode and when flown in an open area. I see no reason a beginner cannot be successful in flying the Proto X FPV with no previous flying experience.
I recommend that the beginner start with the Proto X FPV start facing away from them so that its right and left are the same as the pilot's left and right. This makes orientation and control much easier for the beginner. Slowly beginners start to get their heads into the Proto X FPV and can control it coming toward them as well. As discussed in past reviews I recommend beginners orient the transmitter to match the direction of the air craft to help maintain proper orientation with the craft. Take it slowly, in an open space and with small movements and soon it should become second nature to have proper orientation.
Video clips of the Proto X FPV flying indoors and out.
Proto X FPV RC Multi-Rotor Viewed in Flight (3 min 15 sec)
A video from the recorder on the Proto X FPV taken at night outside of Christmas lights.
Proto X FPV on board Recording Night Flight (2 min 7 sec)
Video of the FPV picture on the transmitter and then video from the on board Proto X recorder.
Proto X FPV First Person and Camera Video (2 min 35 sec)
RC Group Member, Bo Lorentzen, records a morning flight with his Proto X FPV
ProtoX FPV morning flight (4 min 28 sec)
I have been very happy with the basic handling and flying of the Proto X FPV and have very much enjoyed the ability to see first person video on the transmitter screen and with my Shark FPV goggles as well as sharing the experience with friends and family. The fact that my goggles receive the signal and work without being connected to the transmitter was a surprising plus for me and made sharing the flight experience even easier. The ability to record videos during the flights both on board the Proto X FPV and the transmitter has increased the fun. As discussed above I use the transmitter for immediate view back and the recordings from the Proto X FPV are downloaded to my computer and two have been shared in this review.
The Proto X allows someone to try the FPV experience first hand both indoors and out. It required no mixing and matching of components to get started it was just charge and fly after reading the short instruction manual. Almost anyone can operate this in just a matter of minutes. The range is limited to 240 feet for FPV signal but as small as this unit is I won't be testing that range again ever. I have even been able to share the experience with co-workers so they know a little bit more about my hobby. Relatively affordable, easy to use, good (not perfect) results. I am very happy with my Proto X FPV and I recommend it to those interested in having a close in FPV experience.
I will be buying some extra batteries for my Proto X FPV. If I don't find some at the AMA Expo I know Tower Hobbies is getting some in mid January.
Pluses & Minuses
Pluses
  • Ready to fly, fully assembled
  • Can record video from the Proto X FPV and or from the transmitter
  • Ten minute plus flight time with fully charged battery
  • Has standard/normal mode and expert mode
  • Takes little space to store or transport
  • Sun shade easily installed and removed
  • Spare propellers included with tool to remove props
  • Affordable and complete FPV system
Minuses
  • Battery must be in Proto X FPV to be recharged
  • Must supply second micro memory card
  • Must supply the four AA Alkaline batteries for the transmitter
  • No blade guard included or sold for the Proto X FPV
My thanks to Hobbico and Estes for supplying the Proto X FPV for this review. My thanks to Dick Andersen for his help in getting the media pictures and to RC Group member, Bo Lorentzen, for sharing his You Tube video.
Old Jan 13, 2015, 02:55 PM
parajared is offline
Find More Posts by parajared
helis, boats, cars and planes
parajared's Avatar
United States, AZ, Prescott
Joined Oct 2013
Great review,
They should call it something else, I was thinking it was a proto x sized fpv platform. The fact that the battery has to be recharged inside the airframe is a real bummer. Looking forward to seeing what people do with these little things.
parajared is offline Find More Posts by parajared
Old Jan 13, 2015, 08:29 PM
Slurth is offline
Find More Posts by Slurth
Joined Dec 2014
You can buy separate charge cords to charge additional batteries, this is what I have done. It's the same connector that Helimax uses I think for the 1cel batteries.
Slurth is offline Find More Posts by Slurth
Old Jan 13, 2015, 08:57 PM
Capgun_Slim is offline
Find More Posts by Capgun_Slim
Reno Cannon, Nevada, United States
Joined Jul 2003
Just a question. Has there ever been a bad, or very negative review of a product of any kind on RCGroups. If so, I've never seen one.
Again! Not trying to start a flame. I just want someone to point me to a bad review of something here on RCG.
Capgun_Slim is offline Find More Posts by Capgun_Slim
Old Jan 13, 2015, 09:47 PM
parajared's Avatar
Joined Oct 2013
Typical RCgroup thread:
1st page: hey check out this new item
page 1-20: I ordered one can't wait for it to arrive, me too, me too, me tooooo
page 20-40:This is the best item on the face of the planet!!!
page 40-60: ok, here's a more realistic representation of what the product is actually like
page 60-200 crazy mods to make the item work better, often a whole lot of work for very little improvement
skip to the last 10 pages (page 500 or so): grizzled veterans who have item with a definite idea of what and what doesn't work getting offended at noobs who didn't read all 500 pages and want to know what the best setup is.
Old Jan 14, 2015, 08:56 AM
Mtnflyby is offline
Find More Posts by Mtnflyby
United States, WV
Joined Jan 2014
Mtnflyby is offline Find More Posts by Mtnflyby
Old Jan 14, 2015, 12:14 PM
Michael Heer is offline
Michael Heer's Avatar
Stockton, Ca. USA
Joined Apr 2001
Suppliers of review products get a chance to read our reviews before they go live for technical mistakes. They can recommend a change and if there is a technical error the author usually agrees as we want our reviews to be accurate. Suppliers of a product may have a right to kill a review but I am not sure about that as I have never had a review killed.
There are a lot of products that are not presented for review. The company may not want those products subject to scrutiny.
Some companies supply me with a product for a review for them to make suggestions for changes or corrections before the product is brought to the market. That is Alpha testing and my findings are shared only with the company. That helps them improve the product before it ever goes for sale. Alpha testing also helps many of the companies catch problems so the final product that gets reviewed is really a version 2 with the problems removed through the testing process.
My audience for my reviews is RC Group members who read the review, or if the review is in a magazine for the magazine's readers. I try to point out problems I had or even mistakes I made and how to avoid them or how I got around them. For example in my recent Hero 3D review I pointed out some bolts that didn't fit for the motor mount and how I got around that. There was one or two other problems I encountered and I discussed them in the review. The product when assembled flew great. But check out that review and see what I am talking about.
The best compliment I can get is when someone tells me they get an aircraft I reviewed and my tips helped them and it flew just as I said. Since we post videos of the product in action I think our reviews of how something flies are generally pretty well documented.
Sellers don't want to see bad reviews so most don't send out products that they aren't really happy with in the first place. So I stand by my reviews and I think that is true of all the reviewers here in RC Groups. I don't know anyone here who would not share their honest opinion in their reviews.
As for this review I talked with several owners of the FPV Proto X at the AMA Expo this past weekend and saw two more flying at the event and we all were very happy with the product and its performance. Mike Heer
Old Jan 19, 2015, 10:56 AM
Deserteagle is offline
Find More Posts by Deserteagle
Deserteagle's Avatar
USA, Mt, Great Falls
Joined Nov 2006
I honestly laughed when I read this.
Soooo spot on it's ridiculous!
We need a thumbs up emote!
Deserteagle is offline Find More Posts by Deserteagle
Old Jan 19, 2015, 11:02 AM
Joined Nov 2006
NO! you can't make money on advertising and manufactures won't send you free stuff if you did. This is not consumer reports after all.
I am looking forward to this little copter though. It would be nice to fly around indoors while the weather outside is frightful.. let it snow let it snow let it snow...
Old Jan 20, 2015, 01:09 AM
Joined Jul 2003
Mike I respect and understand what your saying. But it just seems like every review, is like that episode of The Simpsons, years ago, when Homer was a food critic. There wasn't any restaurant, or food in those restaurant's that weren't a 10.
I'm not going to name planes, but there have been some real stinkers, that got rave reviews here, I've purchased as far back as a few months after I first logged into this board. They took extra time and money to really get them to fly, remotely like the videos, or claims.
Example. I've been into Bodybuilding for a long time, and before I even started lifting I was reading every Bodybuilding magazine I could get my hands on. Thank god my older brother was really into it was well, and had years of training behind him, tell me that 99% of the stuff in those magazines, when it comes to reviews of supplements, are complete lies. Then, some years later, a guy had the brilliant idea, to start a BB magazine, that was nothing but truth. Truth on training, steroid use, supplements, basically anything and everything that had to do with weight training. The magazine was so great, they wouldn't let just "Any" supplement company advertise in their mag. They never accepted free new products to try out. They would go buy it in the supplement stores, like the rest of us. Take them to independent labs, have it tested to see if it had what it claimed to have in it, and if it were really a legit supplement or not. Only after supplements/companies who after testing said product, passed the lab tests they claimed to have, would then allow them to advertise in their mag. There were too many to count, that didn't pass the test, and the mag would write about the "Real" results of their products, and would tell the public they don't have or perform, as they stated. This caused a lot of controversy of course, and a lot of lawsuits. But the BB community was behind them all the way. Other magazines that had been around for a long time, started getting a lot less readers, while these guys flourished, and all they did, was tell the truth. After several years, the guy who started it, did what most do, and sold it to the largest company, for a hefty price. and it then became just another crappy magazine, full of lies and deceit.
I guess what I'm really trying to say, is, it would be nice to have an actual R/C product I.E. Plane, Heli, Boat, Car etc., that really performed as every reviewer claims it does. No mods, no fooling around. To me, mods always meant, if you want to hop up a proven design to make it even better, you can do this, or that. Not, "To make this product work as it should, out of the box as claimed, you need to do x,y,and z, to get it to perform as stated.
That's what the R and D dept. are for. They shouldn't use the public by giving them free products, to test, what the R/D dept. is getting paid to do. If anything, they should not only give you free stuff, they should also give you a paycheck, for doing what the R/D can't seem to get done.
I understand these companies want to make money, and also want to get new and exciting products to market. But in their haste, a lot of times, they leave most, disappointed.
I hope I'm not looked down upon, for giving my opinion here. Again, not trying to start a problem. This will be my last post on this thread.
Let me close this up by saying, I do enjoy your reviews. Not Patronizing you.
Old Jan 20, 2015, 06:52 PM
Joined Nov 2006
+1 just give it to us real. At the same time there was allot that went into this little copter to bring it to market along with many products.
Old Feb 01, 2015, 04:37 PM
Lama2MetalHead is offline
Find More Posts by Lama2MetalHead
Lama2MetalHead's Avatar
Easton, PA
Joined Jan 2009
My 1st Impressions
Hi everyone. My dad just got me the ProtoX FPV for my birthday and my first impression (first flight) is very solid!
Sure there are something things I don't like but overall i think it is a very well built machine. My 1 qualm is is the tranmissiter side recording function. But, I guess for main video recordings, the SD card being inside the actual heli is the way to go. I also thought this thing would record audio during flight but I was wrong.
Here is my first video:
ProtoX FPV - Inaugural Flight (2-1-2015) (7 min 30 sec)
Lama2MetalHead is offline Find More Posts by Lama2MetalHead
Old Mar 26, 2015, 05:35 PM
TravisBean is offline
Find More Posts by TravisBean
Have Guitar Will Travel
TravisBean's Avatar
The Digital Domain
Joined Nov 2008
Time really does fly (no pun intended). I've been posting on/reading these threads for seven years now,
and you've pretty much summed it up for 99% of what I've seen !!!
TravisBean is offline Find More Posts by TravisBean
Old Mar 26, 2015, 05:48 PM
TravisBean's Avatar
The Digital Domain
Joined Nov 2008
The Blade SR did get some really bad reviews..............
http://www.rcgroups.com/forums/showt...light=Blade+SR
Old Apr 13, 2015, 08:28 AM
rdemrem is offline
Find More Posts by rdemrem
France, Nord-Pas-de-Calais, Marchiennes
Joined Mar 2015
change MODE 2 to MODE 1
Hi guys
I boulght this Proto X in USA during a business trip...but I did not remind that in NA, most of the people are using Mode 2
Do you know how I could convert it to Mode 1?
I already opened the remote and the grimbal are soldered on a double side PC board, so I think I can manage t unsold them but how should I wire it to be in Mode 1?
thanks fo ryour help
rgds
rdemrem is offline Find More Posts by rdemrem
New Product Estes Proto X Nano RTF/Hubsan Q4 Nano/Estes Syncro Nano FieldofDreamsFlyer Mini Multirotors 5428 May 02, 2015 05:09 AM
Review Estes Proto X RTF Nano Quadcopter w/ 2.4GHz: Review Michael Heer Multirotor Talk 64 Feb 18, 2015 07:47 PM
Sold Estes [EST] Proto X Nano Sized RTF RC Quadcopter ESTE4606 Mike Fortune Aircraft - Electric - Multirotor (FS/W) 1 Feb 23, 2014 01:40 PM
Sold Estes [EST] Proto X Nano Sized RTF RC Quadcopter ESTE4606 Mike Fortune Aircraft - Electric - Airplanes (FS/W) 0 Feb 23, 2014 11:50 AM
