Old Apr 10, 2013, 06:46 PM
lv2soar is offline
Find More Posts by lv2soar
Los Angeles, CA
Joined Mar 2004
Question
What can I use this system for?
Can this system be used on a plane or is it only good for a heli?
http://www.rcgroups.com/forums/showt...9#post24686393
If so, what size and weight of plane?
lv2soar is offline Find More Posts by lv2soar
Old Apr 11, 2013, 04:23 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
If you Google Hacker C50 14XL it will come back with quite a few hits. It would seem it's ideal for a larger aerobatic model.
But, most references also refer to using a 6.7:1 planetary gearbox and a 10s pack, and something like a 20" prop.
That and a model could involve quite a big investment.
From a forum comment -
To use the C50-14xl in a pattern plane you must have the planetary geardrive fitted or it will not turn the big props with a 10s battery pack the C50-14xl motor is turnning over 40,000 RPM the planetary geardrive has a reduction of 6.7 to 1 which allows it to turn big props at 6,000+RPM
I have a C50-14xl comp turnning a APC 20x15 at 6500 RPM + drawing 77amps using flightpower 5000 mah 10s1p battery packs
eflightray is offline Find More Posts by eflightray
Question 5S Lipo vs 2S + 3S..Why use 2 when you can use 1? rcwarrior High Performance 19 Apr 16, 2013 01:13 PM
Question Can my tricopter use 4s? chrisdafer Multirotor Electronics 1 Apr 07, 2013 03:57 AM
Discussion kits you can use sukhoi or polecate guts in? swampflyer Foamies (Kits) 3 Jan 10, 2013 06:20 AM
Question Can I Use Foam Core? AirplaneFreak100 Foamies (Scratchbuilt) 6 Jan 08, 2013 05:36 PM
