Old Apr 17, 2015, 09:57 AM
SergeyK is offline
Find More Posts by SergeyK
SergeyK's Avatar
United States, NY, Kings
Joined Feb 2006
Originally Posted by Robert R View Post
Sergey, Interesting. do you know the dimensions of the nose LG leg? I might have a look.
I'll make some measurements once I get home.
SergeyK is offline Find More Posts by SergeyK
Old Apr 19, 2015, 02:01 AM
Robert R is offline
Find More Posts by Robert R
This is a fine fiddly business
Robert R's Avatar
United States, WA, Marysville
Joined May 2009
Possible solution to the rear landing gear leg
This is a mockup. I strung an elastic band from the LG leg to the interior of the wing.
There are two sections of plastic straw on the elastic band which allows it to retract into the wing.
Robert
Robert R is offline Find More Posts by Robert R
Old Apr 19, 2015, 12:56 PM
payne9999 is offline
Find More Posts by payne9999
Balsa&Tissue
payne9999's Avatar
United States, OR, Beaverton
Joined Jan 2011
Robert,
Very clever idea! That should work fine. Can't wait to see her finished and in the air.
Dave
payne9999 is offline Find More Posts by payne9999
Old Apr 20, 2015, 08:19 PM
SergeyK is offline
SergeyK's Avatar
Joined Feb 2006
Robert
This should give you idea of the sizes. The jackscrew is 48mm long.
I would probably use a 3D printer to build custom legs around the jackscrew mechanism
Old Apr 23, 2015, 03:52 AM
Robert R is offline
Robert R's Avatar
Joined May 2009
Final Medial Landing Gear Struts
Mockups of the medial landing gear struts were initially fabricated out of drinking straws and hot glue. The design worked and now they are made of aluminum tube and JB Weld.
Robert
Old Apr 23, 2015, 07:02 PM
Robert R is offline
Robert R's Avatar
Joined May 2009
Sergey,
Thank you.
Robert
Old Apr 25, 2015, 02:56 AM
Robert R is offline
Robert R's Avatar
Joined May 2009
A Bit Closer on the Posterior Gear Leg
The most promising solution so far for a cosmetically acceptable, retracting posterior gear is two short aluminum gear legs strung on elastic cord.
The function isn't quite right yet. The posterior leg still hangs up about one retraction in 15. I need to figure out a way to guide the rear LG leg upward so that it never binds.
I also added bushings for the axles so that the wheels would fit properly and used a washer and a cotter pin as wheel retainers.
Robert
Old Apr 27, 2015, 01:39 AM
Robert R is offline
Robert R's Avatar
Joined May 2009
And then there were two
The second LG leg is complete.
Bart came over tonight and helped me work on the LG. He came over to show me some progress on a Bush Hawk he is building. I hope he makes a build log. It looks great.
Tightening the elastic thread a bit solved the intermittent retraction malfunctions.
Robert
Old Apr 27, 2015, 01:47 AM
Bart83 is offline
Find More Posts by Bart83
71% of the world is runway . .
Bart83's Avatar
Nederland, ZH, Oostvoorne
Joined Jun 2009
So good to see the works on this aircraft are in progress again.
Keep up the good work.
Cheers,
Bart
Bart83 is offline Find More Posts by Bart83
Old Apr 27, 2015, 05:17 AM
don olsen is offline
Find More Posts by don olsen
I hate spray cans
don olsen's Avatar
United States, NM, Rio Rancho
Joined Jul 2007
Nice to see great minds at work
don olsen is offline Find More Posts by don olsen
Old Apr 27, 2015, 03:07 PM
Robert R is offline
Robert R's Avatar
Joined May 2009
Thanks Bart and Don,
By the way when I wrote "Bart" of course it was Marysville Dutch Bart formerly of Zeeland, not Dutch Bart currently of Oostovoorne. In my experience one can never have too many Dutch Barts although it can cause confusion.
Robert
Discussion Modifying the scale of Boeing 247 plans Robert R Scale Kit/Scratch Built 10 Nov 19, 2012 12:21 PM
Discussion Boeing 247 plans, drawings motorbill66 RC Airliners (Commercial, Cargo, Troop Carrier) 25 Nov 07, 2012 04:02 PM
Wanted Vintage Cleveland Model & Supply "Eaglet" plans or kit $13 shipped. Yellow Baron Non R/C Items (FS/W) 1 Jul 14, 2009 04:51 PM
Wanted Old Cleveland Model & Supply "Eaglet" plans $13 shipped Yellow Baron Aircraft - General - Miscellaneous (FS/W) 1 Jun 22, 2009 07:40 AM
Wanted Old Cleveland Model & Supply "Eaglet" plans $13 shipped Yellow Baron Aircraft - Sailplanes (FS/W) 1 Jun 22, 2009 07:39 AM
