Old Oct 10, 2012, 09:51 PM
rotccapt is offline
Find More Posts by rotccapt
that tree ate my plane
rotccapt's Avatar
oklahoma city oklahoma
Joined Apr 2004
umx sbach removable wing mod?
hi all i have one of the origonal e-flight umx sbach's and i love it. i would like to use it as a travel plane to take with me on trips and would like to try and make the wing removable so i can fit the plane and tx in a hard case. do you think it is possible to do?
my first thoughts are to use a piece of carbon fiber in the front and some magnets in the back.
rotccapt is offline Find More Posts by rotccapt
Old Oct 11, 2012, 12:27 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
As designed, the wing is a structural part of the plane..When glued in place the entire plane becomes more rigid...With a well thought out plan you could reenforce the plane...
Also, due to the G's this plane is capable of I would feel better about bolting the wing in place...In the front of the wing you could use dowels and some thin sheet plastic to make some recepticles for the dowels...At the rear of the wing you could use a small nylon 10-32 screw to hold the wing on...This plane is capable of some wild manuevers, both in positive and negative G's!!!
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Oct 11, 2012, 12:42 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The wing and fuselage by themselves are very weak.
It would take major re-engineering. The best thing to do would be start with new foam.
UNGN is offline Find More Posts by UNGN
Old Oct 11, 2012, 11:57 PM
rotccapt is offline
rotccapt's Avatar
Joined Apr 2004
is the rx and servos mounted to the wing or are they attached to the fuse? i think it could be a fun little project and it would make a great travel plane.i will have to look at it and see what i can come up with.
on a side note what does it take to get the original one to spin? i cant seam to do flat spins with mine even with the rudder at max throw
Old Oct 12, 2012, 12:05 AM
Joined Mar 2007
Aileron servos are mounted to the wings...Flat spins!!!???...When spinning add down elevator to get the spin to flatten out...And reduce power...It also helps if your CG is pretty far back...
Kevin
Old Oct 12, 2012, 07:15 AM
BumpierDrake960 is offline
Find More Posts by BumpierDrake960
Joined Aug 2012
Are they shipping from the CA or IL warehouse?
BumpierDrake960 is offline Find More Posts by BumpierDrake960
Old Oct 12, 2012, 10:28 PM
rotccapt is offline
rotccapt's Avatar
Joined Apr 2004
so i looked at the plane today and i think it would not be too difficult to mod it. from the looks of the plane i will have a rod at the TE to hold it in. for the front i will be using a single nylon 10-32 bolt. the only thing is i will have to re-tape the canopy every time i brake down the plane because i will have to unplug the ailerons from the board. to strengthen the fuse section where the wing mounts i will add either some carbon fiber strips or some 1/64 light ply to the fuse. this should strengthen this part of the plane.
what do you guys thing? do you think it is worthwhile?
Discussion UMX Beast vs UMX Sbach binaryclock Micro Ready-to-Fly 43 Apr 06, 2013 06:50 PM
Sold UMX Sbach 342 and UMX Gee Bee R2 ASMX $135 each shipped ton2di Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Sep 13, 2012 06:13 AM
Discussion UMX Sbach 342 mods beetyii Micro Ready-to-Fly 3 Mar 19, 2012 04:52 AM
Discussion PhoenixRC UMX Beast & UMX Sbach 342 Models MarkDeLo Simulators 2 Apr 30, 2011 02:28 PM
