Old Sep 21, 2011, 02:57 PM
Marty7n is offline
Find More Posts by Marty7n
retrocopter
Marty7n's Avatar
Ireland, Dublin, Dublin City
Joined Jul 2011
Question
1000mAh?
hi all
i have orderd a new plane
it says it needs a 1000mAh 11.1v lipo battery and charger
these are the specs
Motor: 2410 brushless outrunner
ESC: 20A
Servos: 2x9g
Battery compartment size: 50x50x41mm
i was wondering what would be the best resonably priced battery and charger from hobbyking?i dont need an expensive make,turnigy battery and hobbyking charger i was thinking of these 2 will they work together?
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
http://www.hobbyking.com/hobbyking/s...cessories.html
Marty7n is offline Find More Posts by Marty7n
Old Sep 21, 2011, 03:16 PM
Ranandar is offline
Find More Posts by Ranandar
Ranandar's Avatar
Kentucky
Joined Dec 2008
Off hand I would say those will work.
I like chargers with a fan in them. Had a cheaper one burn out on me.
Make sure the JST connectors will work for you. They are rated at 10 amp max and you have a 20 amp ESC. That could be pushing the limit. What kind of battery connector does your ESC have? I only use JST with light weight 2S systems. Use EC3 connectors on 3S (11.1v) batteries.
Good luck with your new plane!
Ranandar is offline Find More Posts by Ranandar
Old Sep 21, 2011, 03:21 PM
Marty7n is offline
retrocopter
Marty7n's Avatar
Joined Jul 2011
i am not sure i have just orderd the plane tonight!
so go for EC3 connectors!!!
what would be a good 3s battery and charger from hobbyking???
Old Sep 21, 2011, 03:30 PM
rafe_b is offline
Find More Posts by rafe_b
Joined Jan 2009
That battery is fine, I've got a few just like it. The charger you have linked to is simple and generic and should work -- but (as is common) you will need a 12 volt power supply for it. You can get that from HK, or your local Radio Shack, or possibly use an old wall wart from some discarded electronic appliance. This one from HK will be fine:
http://www.hobbyking.com/hobbyking/s...er_Supply.html
rafe_b is offline Find More Posts by rafe_b
Old Sep 21, 2011, 03:50 PM
Marty7n is offline
retrocopter
Marty7n's Avatar
Joined Jul 2011
Thaks rafe what are my advantages if i bought a 30c instead of an 20c?what would be the normal discharge?
Old Sep 21, 2011, 04:11 PM
Ranandar is offline
Ranandar's Avatar
Kentucky
Joined Dec 2008
The 30c will probably last longer (as in more charge cycles),
but with your setup a 20c would be sufficient.
Old Sep 21, 2011, 04:16 PM
Marty7n is offline
retrocopter
Marty7n's Avatar
Joined Jul 2011
cool but my battery compartment is 50x50x41mm and the biggest part of an 1000mha battery is 75mm!!!!!what would be the downfall buying an 800mha battery?less flight times?
Old Sep 21, 2011, 04:25 PM
Belem is offline
Find More Posts by Belem
Foam flogger
Roseville, CA
Joined Apr 2009
That's an odd compartment size. What plane is this?
Belem is offline Find More Posts by Belem
Old Sep 21, 2011, 04:27 PM
Marty7n is offline
retrocopter
Marty7n's Avatar
Joined Jul 2011
http://www.hobbyking.com/hobbyking/s...lug_n_Fly.html
i think i will get a 1000mha battery in at an angle or make adjustments lol
Old Sep 21, 2011, 04:34 PM
Belem is offline
Foam flogger
Roseville, CA
Joined Apr 2009
Comments suggest that the dimensions are wrong. I'd just get the battery you linked to originally and not worry about it. If it's too big just dig a little foam out.
Old Sep 21, 2011, 04:37 PM
Marty7n is offline
retrocopter
Marty7n's Avatar
Joined Jul 2011
k!what does backorder mean on the hobbyking site?Expect delays with delivery?
Old Sep 21, 2011, 04:56 PM
signflyer is offline
Find More Posts by signflyer
2^p - 1
signflyer's Avatar
United States, MO, Springfield
Joined Feb 2003
Backorder means DON'T ORDER unless you don't mind waiting an indefinite amount of time. I suggest that you stick with items that are in stock.
signflyer is offline Find More Posts by signflyer
Old Sep 21, 2011, 05:04 PM
Marty7n is offline
retrocopter
Marty7n's Avatar
Joined Jul 2011
yes i did that and placed an order for items in stock + fast delivery!
Old Sep 21, 2011, 07:27 PM
rafe_b is offline
Joined Jan 2009
It's not terribly uncommon to have to do some carving. But that's an odd size for a battery compartment, any way you cut it.
As to the C rating. Higher numbers are almost always better but usually cost more and are heavier for the same mAh rating. Most of my batteries are 20/25/30C.
The 'C' rating times the capacity (in amp-hours) gives the maximum safe/recommended discharge rate for the battery. Eg. 1000 mAh at 20C means 20 amps max.
Old Sep 22, 2011, 11:35 AM
Marty7n is offline
retrocopter
Marty7n's Avatar
Joined Jul 2011
cool
the J3 I ordered comes with a 30amp esc and the batteries i orderd are 25c discharge which is just under the max for the esc! it has a 2410 brushless outrunner motor inclu do you know if its a strong motor and reliable?
i calculated the kv at about 11,000kv
battery is 11.1v 1000mha 25c
Sold 2x HBZ1013 1000mAh NiMH - LOWER PRICE flyandi Aircraft - Electric - Batteries & Chargers (FS/W) 3 Sep 26, 2011 05:53 PM
Sold 610mAh, 1000mAh, 1300mAh 11.1V 3S LiPos kyle7119 Aircraft - Electric - Batteries & Chargers (FS/W) 3 Sep 20, 2011 10:06 PM
Wanted Trade 9.6V 1000mah for 8.4V 1000mah NiMH suseuser Aircraft - Electric - Batteries & Chargers (FS/W) 2 May 17, 2010 09:26 AM
Sold E-flite 1000mAh 3S & Turnigy 1000mAh 3s's isaacdro Aircraft - Electric - Batteries & Chargers (FS/W) 2 May 05, 2010 10:48 AM
Sold OUTRAGE 1000mAH XP20 3S1P 11.1V 1000mAH 20C REFF Aircraft - Electric - Batteries & Chargers (FS/W) 3 Apr 04, 2009 05:00 PM
