Old May 08, 2010, 08:21 PM
trope is offline
Find More Posts by trope
trope's Avatar
Joined Apr 2010
Question
Compression? How to check?
Miss Elam is my first nitro boat. I think I got her broke in, but not sure.
Local hobby shop told me this, and I quote:
If you don't know what you're doing, maybe you should unload the boat before you do damage since one small mistake could do alot of damage. If you do screw something up, and decide to sell it, someone who knows about boats can simply check the compression and see the boat is worthless.
Ok, fair enough. I took my time, broke in the engine I think. 1 tank on pond, 2 tanks with homemade water cooling system, 2 more tanks on pond. It seems to scream for RTR out of box.
But I would like to learn about this "compression". What is it, how do I check it, and what calibrations should I expect for my boat???
Thanks, I really appreciate your advice!
trope is offline Find More Posts by trope
Old May 08, 2010, 10:57 PM
Ron Olson is offline
Find More Posts by Ron Olson
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
Simple enough and you don't need any tools or gauges. Just turn it over and if it feels tight at TDC it should be fine. You'll feel that pop when it's good.
If you wanted to get all fancy about it then you could use a pressure gauge then check for leak-down/blow-by but the problem is that most boat engines have a tapered bore which can throw a wrench in the works.
Ron Olson is offline Find More Posts by Ron Olson
Old May 11, 2010, 10:18 PM
PAINLESS3 is offline
Find More Posts by PAINLESS3
Joined Apr 2009
Do some searching around 1/8 scale nitro car sites, I've seen a compression gauge for sale but can't find it now. Don't know what a good reading (number) would be though.
The worst thing you can do is run your engine in a lean condition, that will kill compression quicker than anything due to over heating.
PAINLESS3 is offline Find More Posts by PAINLESS3
Old May 13, 2010, 07:53 PM
trope is offline
trope's Avatar
Joined Apr 2010
After much searching on this subject, I cannot find any relevant information - which leads me to one conclusion:
Not something I need to know about right now.
Thanks Ron, Thanks PAINLESS.
Old May 22, 2010, 09:25 AM
txt killer is offline
Find More Posts by txt killer
Joined Apr 2008
You need a compression gauge to tell the exact compression. Every size engine has a different number. Smaller engines like yours has a low number and when the engine has gone past that number it will be junk. You can tell buy turnning the motor over the feel of the compression but you don't know the numbers when it was new to junk.
txt killer is offline Find More Posts by txt killer
Old Jun 10, 2010, 05:03 PM
dialed is offline
Find More Posts by dialed
rc racer
dialed's Avatar
Pa.
Joined May 2010
I have pinched many sleeves mostly for 1/8 scale racers, my best advice to you is check the pinch when the motor is hot like rite after you shut it down. Just after you shut it down roll the fly wheel in the same direction the motor would run when started. At TDC you should feel a good amount of resistance if you can even get it through TDC, that's a good pinch. If you roll through TDC with very little resistance your pinch is going, a good sign your pinch is gone is when the motor is idling and shut down for no reason. Also keep in mind that you can have a good pinch and no compression, this can happen if you drop the element out of a glow plug and score the piston and sleeve I have past over a few of these in my time. I do have a compression guage but only used it once and thought that it was hurting the motor with out any fuel and oil running through it.
Good luck...
dialed is offline Find More Posts by dialed
Question Compression Gauge mredzadventure Engines 4 Apr 02, 2010 10:23 PM
Discussion on your prefrlight check list, remember to check your... GAU-8 FPV Talk 6 Mar 26, 2010 01:03 AM
Question How to hold the plane to check the cg David22 High Performance 11 Nov 27, 2009 09:31 AM
Cool How bout Building Avistar That Can Land Inverted?Some nut case done it,check it out Aga1978 The Builders Workshop 6 Oct 12, 2009 05:37 AM
Discussion how much compression? twchdyn Engines 2 Apr 12, 2006 07:11 PM
