Old Apr 17, 2003, 06:49 PM
mumblety-peg is offline
Find More Posts by mumblety-peg
mumblety-peg's Avatar
USA, CA, Martinez
Joined Feb 2001
Herr Pitts Control Throws
Could someone tell me what the throws are for this model. I've decieded to take mine out of mothballs for the summer.
Mitch
mumblety-peg is offline Find More Posts by mumblety-peg
Old Apr 24, 2003, 08:33 PM
ewingnut is offline
Find More Posts by ewingnut
Surrey, BC, Canada
Joined Apr 2001
30" Pitts
Off the plans...
Elevator = 1/4" up, 1/4" down
Ailerons = 1/8" up, 1/8" down
Rudder = 1/2" left, 1/2" right
Rich.
ewingnut is offline Find More Posts by ewingnut
Old Apr 28, 2003, 06:08 AM
surfer is offline
Find More Posts by surfer
Brussels (Belgium)
Joined Nov 2001
ailerons throws: watch out
I would suggest you to put a maximum throws on ailerons because mine had a strong tendancy to turn left. And after reading about other pitts owners, many of them had the same problem.
Also If you can you should mix ailerons and direction (I have done it after first flight). It really is a lot easier to fly and help to make nice and soft turns.
Good luck
surfer is offline Find More Posts by surfer
Old Apr 30, 2003, 09:14 AM
USA, CA, Martinez
Joined Feb 2001
Thanks guys-
I'm going to max the ailerons and do the mix as suggested. The poor aielron response caused me grief on takeoff last time I flew this plane.
Old Apr 30, 2003, 03:43 PM
USA, CA, Martinez
Joined Feb 2001
Surfer-
How much mix do u use. I tried 15% and it was not near enough.
I only had one flight then I broke off the tail wheel. I do more damage in pre-flight then in flight sometimes. Anyway, not near enough flight time to see if I still like it.
It was just as hard to get off the ground as I remember
Old May 05, 2003, 06:48 AM
surfer is offline
Brussels (Belgium)
Joined Nov 2001
about mix
Mumblety,
I will check for the exact amount of mix when I get back home.
The principle is. The master is the aileron servo with a maximum throw. I would say when you turn left at the maximum on your aileron, the direction must follow and turn left about half the maximum throw. I don't know in figures ... it should be about 50%?
Will check and confirm it tomorrow.
Anyways I also had some problems for firts flights but once you find the trim (for me it was right trim) and coorect mix it is quite easy to fly.
Also another tip for take-off. I found it easier to take off if you put full gas immediatly.
good luck.
Old May 07, 2003, 06:45 AM
surfer is offline
Brussels (Belgium)
Joined Nov 2001
I checked its 25% mix
Old May 07, 2003, 07:29 AM
USA, CA, Martinez
Joined Feb 2001
Old May 07, 2003, 09:31 PM
ElectRick is offline
Find More Posts by ElectRick
Eye Drather Beef Lying
ElectRick's Avatar
Jacksonville, FL
Joined Aug 2002
Full gas?
Gas? Horrors!
Oh the humanity......
Just kidding.
Rick
ElectRick is offline Find More Posts by ElectRick
Old May 08, 2003, 06:40 AM
surfer is offline
Brussels (Belgium)
Joined Nov 2001
you are right. It should be more like ... full electrons!
Long life to elect (Rick)..
Flea's CG and control throws WilliamSettle High Performance 6 Jul 27, 2001 11:07 PM
Adjusting control throws ? John E Beginner Training Area (Aircraft-Electric) 8 Jun 22, 2001 07:52 AM
Adrenalin 400 control throws. Erik Johansson High Performance 1 Jun 20, 2001 09:17 AM
Silly Question: Control Throws? spy0o7 Electric Plane Talk 3 Jun 19, 2001 11:14 PM
Speedy control throws? Bill72pa High Performance 3 Jun 12, 2001 04:38 PM
