Old Jun 19, 2013, 05:42 PM
mumblety-peg's Avatar
USA, CA, Martinez
Joined Feb 2001
Ice Lite 100 4 red flashes
This just started after maybe 10 flights. I can power up the motor. When I go full throttle, the motor stops abruptly. At this point I see a series of 4 red LED flashes. I don't see anything burned. But I have not pulled the motor yet. I hate working in those tiny spaces.
Mum
mumblety-peg is offline Find More Posts by mumblety-peg
Old Jun 19, 2013, 06:29 PM
A man with too many toys
United States
Joined Feb 2001
4 flashed is prop strike detect.
In your case it indicates a motor problem or motor wiring problem.
1. Bad solder joint between motor and ESC. If the motor came with pre-installed connectors that’s probably it. I have had that problem in quite a few motors. Now I take the connectors off all new motors and resolder them on myself.
2. Bad motor bearings
3. Loose prop or prop drive
4. Bad solder joint internal to motor
5. Shorted windings. Sometimes the motor is not would correctly and a wire touches the magnets. After a few flights the insulation is worn off and it shorts out when you run it up
RC Man is online now Find More Posts by RC Man
Old Jun 19, 2013, 06:31 PM
United States
Joined Feb 2001
Also if it’s a small motor some of those cheap small connectors are just no good. Soldering the motor wires direct to the ESC solves that problem.
Old Jun 20, 2013, 10:49 AM
USA, CA, Martinez
Joined Feb 2001
Thanks guys. I found a bad solder connection. No time to fix so far unfortunately. But I'm sure that was the issue
Found Castle Creations Phoenix 100 Ice lite esc or 75 Ice lite rcwarrior Aircraft - Electric - Power Systems (FS/W) 1 Jan 08, 2012 05:53 PM
Discussion Phoenix Ice Lite 100/ Ice 100 sebbe Power Systems 5 Nov 10, 2011 05:15 PM
For Sale Ice lite 75 and ice lite 100 fs ChrisBowker Aircraft - Electric - Power Systems (FS/W) 3 Aug 28, 2010 10:24 AM
For Sale WTT: My ice 100 Lite for your Ice 100 std la528it Aircraft - Electric - Power Systems (FS/W) 1 Apr 18, 2010 12:26 AM
Sold Phoenix ICE 100/ICE LITE 100 NIP hole digger Aircraft - Electric - Power Systems (FS/W) 9 Oct 14, 2009 02:47 PM
