Old Aug 09, 2014, 06:58 PM
skumgummi dave
Gresham, OR.
Joined Mar 2004
Sure would enjoy knowing where to just buy the connectors. Have only found kits with plastic rods and connectors.
Dave-
foamdave is offline Find More Posts by foamdave
Old Aug 09, 2014, 07:12 PM
Joined May 2010
Dave,
Do a Google search for "molecular model kit." I find looking under images to be very helpful. Look here.
The buckyball is called in organic chemistry a "C-60" molecule, so after you find a particular supplier of your choice, put c-60 into the search box of the supplier and out will pop the model you requested.
Look here for the one I did for you.
You can adjust the diameter of the sphere by increasing the lengths of the interconnecting tubing or rods depending upon whether you choose to use rod or nylon tubing, i.e male or female connectors.
corocopter is offline Find More Posts by corocopter
Old Aug 09, 2014, 07:32 PM
Joined May 2010
How to.... instructions "Making a Buckyball":
Making a C60, Bucky Ball, Buckminsterfullerene model
Old Aug 09, 2014, 08:18 PM
Joined May 2010
Buckytube:
How about a Buckytube: for the "quad in a cage" idea.
Old Aug 09, 2014, 08:22 PM
Joined May 2010
Buckyball closeup shot:
You can see the lengths of nylon tubing used with the inter connectors. It all looks too heavy. I've not found the female connectors yet.
You may need to send an email to the builders of the Gimball and ask about those connectors. If you read the article I linked to, you will find some info that will point you to the inventor. It may take a bit of leg work. It appears that these parts must be of foreign design. Perhaps they custom built them, but I'm sure I've seen female connectors in the Chemistry Dept on the campus where I use to teach. I did not teach chemistry, but they had some nice display cases in the hallway. I now live a great distance from that school.
Click image to enlarge for detailed viewing.
Old Aug 11, 2014, 01:51 AM
skumgummi dave
Gresham, OR.
Joined Mar 2004
corocopter:
Thank you Sir for all the good info. You are correct. Looks like the parts are made in China. Reminded me of the D-Link set I had as a kid.
Dave-
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 116 Mar 14, 2014 02:23 PM
Discussion New AR Drone (i-drone) light mod bungle68 Multirotor Talk 3 Apr 13, 2011 05:30 PM
Discussion AR Parrot Drone For Sale Matt Gunn Atlanta Area RC 4 Mar 16, 2011 07:41 AM
Found Parrot AR. DRONE iceman77 Aircraft - Electric - Helis (FS/W) 3 Mar 15, 2011 01:51 PM
Discussion Piloting Drone From iDevice BUT takeoff/landing from a computer chope1 Multirotor Talk 0 Mar 07, 2011 10:12 AM
