Old Feb 19, 2014, 12:44 PM
Joined Oct 2011
Originally Posted by Witterings View Post
I didn't think that one through did I :-)
Be a useful thing to have for keychain cameras etc!!
You can use these cables to charge an 808 cam on a 306B. You just need a female servo lead adapter to a Banana lead or whatever you use on your paraboard.
The + and ground lines on the cables will work with any key cam -- it doesn't have to be an FPV version.
syzygyQ is online now Find More Posts by syzygyQ
Old Feb 19, 2014, 03:39 PM
Son, Norway
Joined Sep 2004
It's clearly labelled "5V input"! The camera. like most gadgets, have a built in charger that needs 5V input (USB port etc.). Connecting it to a charger will destroy the camera.
The USB charge port on 308 duo is just a 5V 1A output.
Fred
flarssen is online now Find More Posts by flarssen
Old Feb 19, 2014, 04:06 PM
Joined Oct 2011
I don't know what a “308 Duo" is -- I don't know why you're telling me about them.
The 306B that I do mention feeds 4.2V to 1S lipos. While YMMV, the 306B won't fry your 808 camera unless, as with any lipo charge configuration, you set it up wrong.
That being said -- I haven't tried it. It seems to me like it would work, but I don't know enough about the tech to be sure.
Old Feb 19, 2014, 05:11 PM
United States, MA
Joined Jan 2011
If the camera has its own charge circuit, then you need to feed it 5V, and it will take care of the rest. Don't give it anything else besides just a 5V source.
If it can charge via a simple USB cable, then it is likely intended to simply take 5V.
The power source would give it 5V, and the internal charge circuit will take care of charging the LiPo.
You would not be able to read the LiPo voltage via the 5V-in port, so best case, the charge would not work. Worst case, you would damage the internal charge circuit.
My TX is like this. It needs just a 12V power source. It's internal charger will charge the battery. Connect your charger to the 12V-in port, however, and you will damage the TX. Even if you set it to the type of battery the TX uses.
If the charger was external, and you could read the LiPo voltage via the port, then that would be different. But then they would be providing a specific external charger, and you could not simply use any USB cable.
The 308Duo is another iCharger, which has a USB port that can be used to charge any device that can charge via USB.
RedOctobyr is online now Find More Posts by RedOctobyr
Old Feb 20, 2014, 12:53 AM
BGR
Foam Junkie
United States, CA, Oceanside
Joined Dec 2003
I though USB power was 12 volts ???
BGR is offline Find More Posts by BGR
Old Feb 20, 2014, 01:32 AM
ΜΟΛΩΝ ΛΑΒΕ
habitforming's Avatar
USA, KY, Hebron
Joined Dec 2005
oh my, no!
from wikipedia:
Originally Posted by Wikipedia
Electrical
Signal 5 volt DC
Max. voltage 5.000.25 V (pre-3.0); 5.00+0.25-0.55 V (USB 3.0)
Max. current 0.50.9 A (general);
5 A (charging devices)
habitforming is offline Find More Posts by habitforming
Old Feb 20, 2014, 05:37 PM
Spain, Valencian Community, Alicante
Joined Dec 2008
Originally Posted by alberthamon View Post
Dear all,
first, I wish apologise for make the same question that other people.
second, also apologie for my bad english
I have two 106B+ and one is with the message: connection break down, since I did conected it to the battery car.
I did replace mosfet burned, but continue with the same message. The Zener is OK and Q26 changed for aNPN compatible.
can somebody help me whith this.
thanks in advance.
Q26 and Q46 changed and working again. Thanks
alberthamon is offline Find More Posts by alberthamon
Old Feb 20, 2014, 06:32 PM
United States, MA
Joined Jan 2011
That's great, I'm glad you got it working again, and thank you for posting the results. Maybe that will help someone else in the future.
Old Feb 25, 2014, 02:22 PM
Joined Aug 2013
Does someone have a buddycode for the icharger 1010Bplus 300w?
iCharger 1010Bplus 300W 10s Balance/Charger
usab is offline Find More Posts by usab
Old Feb 26, 2014, 06:07 AM
Joined Oct 2011
I guys. I bought the iCharger 106b+
http://www.hobbyking.com/hobbycity/s...idProduct=6792
Spec.
Input voltage range : 10.0 18.0VDC
Charge current range : 0.05 10.0A
Discharge current range : 0.05 7.0A
Maximum charge power capacity : 250W @ input voltage > 13.5V
Maximum discharge power capacity : 20W
Maximum extern discharge power capacity : 170W @ 20V/7A
Current drain for balancing : <300mA
Balance accuracy : <10mV
Lithium (LiPo/LiIo/LiFe) battery cell count : 1 6 series
NiCd/NiMH battery cell count : 1 17 series
Pb battery cell count : 1 12 series (2 24V)
Battery setup memories : 10
Intelligent temperature control : Yes
PC Connect : USB port
Weight : 350g
with this power supply:
http://www.hobbyking.com/hobbycity/s...dProduct=17424
Specs:
Input Voltage: 220~240V AC
Output Voltage: 13.8v DC
Output Amps: 25A
Output Watts: 350W
Temperature Cutoff: Cooling: Single Fan
Dimensions 165.5 x 111 x 50.5mm
Weight: 710g
When i try to discharge one of my 4S batteries it will not DSCG over 1A, it keeps holding it at 0.99A and wotn go higher. The charger can do much more than this, why is that? trying this on a Zippy Compact 4S pack.
peithan is offline Find More Posts by peithan
Old Feb 26, 2014, 06:29 AM
United States, MA
Joined Jan 2011
Look in Settings, there will be a page where you can set Discharge power. I think it defaults to 15W. You can increase this to 20W, the maximum that the charger can dissipate during a discharge.
But with a 4S (16.8V-max) battery, you still won't get much over 1A.
Initially, you'd get 20W/16.8V = 1.2A. This will increase a bit as the battery voltage decreases during the discharge.
Old Feb 26, 2014, 07:09 AM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Double post / multi threads
http://www.rcgroups.com/forums/showthread.php?t=2112772
everydayflyer is online now Find More Posts by everydayflyer
Old Mar 07, 2014, 04:52 PM
scottc39's Avatar
USA, MN, Shakopee
Joined Sep 2004
can some one tell me why my 106b icharger will not discharge at a the 7.0 amps continuously, the charger will start at the 7.0 amps but in a few mns will drop to 1.2 amps and discharge there till the set discharge rate, take note I have a 350 watt power supply being used with the charger to .
scottc39 is online now Find More Posts by scottc39
Old Mar 07, 2014, 06:17 PM
So. Cal.
Quite simply, you're most likely hitting the 20 watt maximum internal discharge capability of your charger. To understand maximum discharge current, divide 20 by battery voltage. Suspect that you have a 4 cell lipoly that you're attempting to discharge?
mrforsyth is online now Find More Posts by mrforsyth
Old Mar 07, 2014, 07:10 PM
scottc39's Avatar
USA, MN, Shakopee
Joined Sep 2004
mrforsyth your right on the battery pack size, is this the same with all chargers with max internal discharge capability?, thanks for the input to.
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 03:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 01:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 04:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 09:55 PM
