Old Mar 09, 2008, 12:36 PM
DO OR DO NOT--THERE IS NO TRY
United States, AZ, Prescott Valley
Joined Mar 2006
Idea
PVC Pipe For Motor Mount
Hi All,
I don't propose I "invented" this idea but I haven't seen it along the way. I was looking for an easy way to create a motor mount for my new build project, the CalderCraft Schaarhorn. I stumbled on the idea of cutting a 1 1/2 inch (inside diameter) PVC pipe joint and using each half as a motor mount cradle. As photos show, the motor is secured with an auto-type radiator hose type clamp and the whole assembly is aligned and set in place with epoxy. The system is simple, works well, is very stable and comes apart easily.
If I "borrowed" this idea from someone, hey, I offer my apology.
AZCAPTAIN
azcaptain is offline Find More Posts by azcaptain
Old Mar 09, 2008, 01:13 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Solutions are where you find them! Handy stuff, PVC pipe and fittings... there's more of it in my models than you might guess!
Epoxy: I never trust the stuff on plastic. Once you think it's set, give the mounts a good tug. If they don't pop loose, fine. If they do- put a bit of CA in the joint and stick it back together!
Or- before epoxying, grind some divots into the back of the PVC in a way that locks the parts into the glue.
patmat2350 is offline Find More Posts by patmat2350
Old Mar 09, 2008, 02:31 PM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Arizona: I think that is a brilliant idea! Kudos to you!
I also noticed your PVC pipe tool holders. Another brilliant idea!
Kmot is online now Find More Posts by Kmot
Old Mar 09, 2008, 07:54 PM
Predreadnut's Avatar
Joined Jul 2007
Nifty idea and nice kit. I have always thought the Schaarnhorn was a nice looking ship. I've thought of using PVC pipe to store lengths of scale lumber,plastic tubing, strips etc. Please, please post pictures as you progress on the Schaarnhorn.
Predreadnut is offline Find More Posts by Predreadnut
Old Mar 09, 2008, 11:29 PM
Joined Mar 2006
Schaarhorn Build Photos
I think I'll try doing a "build thread" on this model. I haven't done it before. This might be a good opportunity.
And, Pat Matthews, thanks for the tips on uising epoxy. I didn't know about it being "chancy" with plastic. I DID check the adhesion. It seems good, maybe because the pipe joint I used was threaded, which helped adhesion.
azcaptain
Old Mar 10, 2008, 08:40 AM
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
I was just going to say that you could also use a straight coupling if you didn't want the threads but maybe the threads are good to have in the epoxy.
norgale is offline Find More Posts by norgale
Discussion JB Weld for motor mount?s crocket High Performance 8 May 18, 2006 11:32 AM
Looking for motor mount for the K278 fly_boy99 Power Systems 0 Oct 17, 2005 08:01 PM
One or two set screws for motor mount? Jim13704 Power Systems 0 Jul 21, 2004 01:51 PM
Looking for motor mount for a Kontronik 500 with 5:2.1 geardrive Michael Heer Scale Kit/Scratch Built 6 Mar 31, 2004 09:13 AM
Apoxy for motor mount M.PROTZEK Electric Plane Talk 9 Jul 27, 2003 02:17 PM
