Old Oct 23, 2013, 01:15 PM
TEAM HILLBILLY
Somethin' Extra's Avatar
United States, MN, Fairmont
Joined May 2013
charger question
ok so i have a small hobbyzone charger that only charges 3 cells, so could i hook up a parrelel charging board and be able to charge different cell types? thanks, jacob.
Somethin' Extra is online now Find More Posts by Somethin' Extra
Old Oct 23, 2013, 01:17 PM
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
What do you mean by "types"?
Cell count, mah, C-rating, chemistry?
mw
Mark Wood is online now Find More Posts by Mark Wood
Old Oct 23, 2013, 01:18 PM
TEAM HILLBILLY
Joined May 2013
sorry. by type i mean different number of cells, like 3 or 4 cells
Old Oct 23, 2013, 03:21 PM
characters welcome!
Mark Wood's Avatar
Joined Feb 2000
You can charge batteries in parallel as long as the cell count (voltage) matches. You can even charge a 3s 2100 and a 3s 5000 together.
mw
Old Oct 23, 2013, 03:32 PM
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
If its a small charger basically of the type supplied with RTF ... then safe answer is no.
The charger is most likely low power ... with poor cooling ... cheap board and components ... subjecting it to charging board would most likely overheat it and you'd end up with dead charger or even worse a shorted system risking dire effects on your LiPos.....
Also the charger is most likely a balance charger that charges via the balance lead ? If you change the cell count - it will not be able to safely work balance function.
If you want to improve your charging - then get a better charger .. that's the better solution.
Nigel
solentlife is online now Find More Posts by solentlife
Old Oct 23, 2013, 04:02 PM
Staffs, UK
Joined Nov 2003
To be really clear....NO!! You cannot ever connect batteries with different numbers of cells e.g. 3S and 4S in parallel. It kills them in seconds.
Steve
slipstick is offline Find More Posts by slipstick
Old Oct 23, 2013, 04:12 PM
TEAM HILLBILLY
Joined May 2013
Steve
Oh ok thanks.
Question Battery/Charger Questions clintonm9 Batteries and Chargers 6 Jan 29, 2013 02:47 PM
Discussion Charger question. Fast Charging? robert low Batteries and Chargers 17 Jan 23, 2013 08:53 PM
Question charger question seamusagleann Electric Heli Talk 2 Jan 16, 2013 11:02 AM
Discussion Question about AC Charger and Battery Replacement Spirittoo Coaxial Helicopters 3 Jan 09, 2013 04:56 PM
Discussion TB6AC Charger question stevetarget Batteries and Chargers 3 Jan 07, 2013 05:24 PM
