Old Dec 05, 2014, 02:55 PM
katana2665's Avatar
Guilford, Ct.
Joined Jan 2004
1/16. They are not drop in and require fitting. Also piggybacks are not necessary, I just did them for coolness not for racing.
Currently my project is sitting in a box, but now that winter is here, i may take it out and see where I left off.
http://www.ebay.com/itm/Integy-T3460...item43d3d79bee
katana2665 is online now Find More Posts by katana2665
Old Dec 17, 2014, 04:19 PM
Hi
I have a BP 8 chassis for sale which I haven't had the time to finish.
Carbon frames are 2mm by fibrelyte uk and are great quality.
Cost me £150 with shapeway nylon parts.
Will need donor bike parts etc to finish.
Looking for £90 buyer pays postage.
-----SOLD------
chilau is offline Find More Posts by chilau
Old Dec 17, 2014, 07:43 PM
RCMCConline com
Kev71H's Avatar
San Jose, California, United States
Joined Apr 2002
Too bad your not in USA.
Kev71H is online now Find More Posts by Kev71H
Old Dec 21, 2014, 03:37 PM
100% _Maybe
Rob1o1's Avatar
Australia, QLD, Brisbane
Joined May 2012
Originally Posted by Bastelpeter View Post
The design is based on 1.5mm Sheets, however it should work if you adapt a few things.
1. You Need to shorten the bushings between Frame and swing arm.
2. If you use 2mm for the battery plate , you need to shorten the spacers in front and behind the battery by 1mm
3. The steering head gets higher. You might need to adapt the fork.
Beside that you should end up in a rock solid bike
Hey Peter,
I bought the project with the 2mm plates.
1. Shorten them (bushings) each by .5 each ? easy enough to trim?
2. I should be able to copy the battery plate and make one out of 1mm
3. I will be using venom upgraded forks. I wonder what "adapt" will mean. Guess we will see.
I have a heap of venom parts including some ZH rims. I just need some inserts and decent tyres. I think it has a castle esc and motor in it. I will tear it down this week, although it may be by winters end that I get the BP8 together!
Rob1o1 is offline Find More Posts by Rob1o1
Old Dec 22, 2014, 09:44 AM
Bastelpeter's Avatar
Germany, RP, Nierstein
Joined Jun 2011
Hey Rob,
sounds great. Bushings should not be a big deal. The fork might to be taken on a turning machine to enlarge the length of the step. But I do not really know since I never used the venom fork. Due to lack of parts I did my own.
Please feedback once you drove it.
Cheers
Bastelpeter is offline Find More Posts by Bastelpeter
Old Dec 22, 2014, 04:35 PM
katana2665's Avatar
Guilford, Ct.
Joined Jan 2004
I put the venom fork on my build, if i remember correctly it required a different size bearing and some spacers to clear the screws on the steering hub. Also for those screws you need buttonheads as anything taller will interfere.
Old Dec 22, 2014, 06:31 PM
Berlin, Germany
Germany, Berlin
Joined Aug 2013
Venom fork fits perfect, (I used the alu triple clamp.)
The BP8 is a very reliable bike, more than 1,5 years without problems, what the frame and the whole kit is concerned. I would not sell. The only thing I did, I changed the position of the scatch bar holders, I mounted it on the main frame. At the origin position the material gave up...
Piekus is offline Find More Posts by Piekus
Old Dec 22, 2014, 06:33 PM
United States, TX, Houston
Joined Jun 2006
I also fitted mine with the venom fork. I ground down where the triple hit the button heads and fitted a flanged bearing both top and bottom of each triple (otherwise if you use a spacer it pushes through). You can probably get away without the grinding. The biggest pain was getting a shaft that could fit it all together. I ended up using an old shock shaft from the parts bin.
-rskip
rskip is offline Find More Posts by rskip
Old Dec 22, 2014, 10:51 PM
katana2665's Avatar
Guilford, Ct.
Joined Jan 2004
Yep, I used a shock shaft as well....
Old Dec 23, 2014, 08:34 AM
100% _Maybe
Rob1o1's Avatar
Joined May 2012
ok. I´ve found that I had a lot of GPV1 parts so I can raid the GPV1 for the good bits (forks, alloy triples, wheels etc and use the other spares. I can already see the issues with using 2mm plates as Pete described. It does not go together too well. the main areas being the swing arm spaces - the swing arm will bind put also the frame spacers wont line up for the swing arm shaft if the battery plate is thicker than 1mm. I will pull them both down and see what I build. It might take a while though...
Old Dec 24, 2014, 09:28 AM
Joined Mar 2014
Driving now with foam tires. Works great. Never go back to rubber.
Here some Video from the first run: http://www.dailymotion.com/video/x2d...gummitest_tech
The bike is running with a improved Venom fork.
Stitch. is offline Find More Posts by Stitch.
Old Dec 24, 2014, 12:10 PM
DLAWW
DLAWW's Avatar
Socal
Joined Dec 2005
That bike is the business, very fast transitioning and cuts like a diamond love it.
DLAWW is offline Find More Posts by DLAWW
Old Dec 24, 2014, 01:10 PM
RCMCConline com
Kev71H's Avatar
Joined Apr 2002
SO who is making the foams?????
I could see where firm foam tires would be awesome grip. How do people get them?
Old Dec 27, 2014, 06:30 AM
Joined Mar 2014
The foams from GP Speed Tires. The 54/80mm rings i used for the front tire are watercut. The rear tire (60/90) was in stock, think from 1/8 scale cars. You have to glue the rings on a rim (from OTO, Shapeways, etc..) and grind it down for the right shape. 80-120 sandpaper works well.
Help! 3D printable open-source RC Truggy - RC minds needed to finish project remondo Off-road Cars 21 Sep 16, 2014 01:35 AM
New Product The X-CAM Brushless Gimbal Control System (not Alexmos and other open source project) tomye Multirotor Talk 13 Nov 26, 2013 10:47 AM
Discussion The OSRC Project - Open Source Remote Control mdem Australia 16 Aug 02, 2013 09:40 AM
Sold Pz420 Camera control board or other open source projects. $5 Johnnymeg FPV Equipment (FS/W) 1 Apr 29, 2013 10:51 PM
Discussion Open source project of spektrum DSM2 receiver? hyonlim Multirotor Electronics 0 Jan 28, 2013 08:13 PM
