This thread is privately moderated by RCWorks, who may elect to delete unwanted replies.
Old Jan 17, 2013, 02:22 PM
Мої Медс ногами в!
RCWorks's Avatar
Joined Aug 2003
2007 Malibu window problems
You will first check the fuse for the Power Windows. This fuse will be in the BODY CONTROL MODULE. If bad replace it... if good continue...
Pull the driver window switch assembly oout leaving it plugged in to it wiring harneess...
The switch has 2 plugs C1 and C2. C1 is the one with the yellow wire.
Hook the clip of your test light to a good ground, with the motor running see if the yellow wire has power at the connector by back probing the connector or peircing the wire with the probe. (Careful not to impale your fingers.)
Do you have power at the Yellow wire on the back side of the Driver Power Window Switch????
RCWorks is offline Find More Posts by RCWorks
Sold Ignite wave setter malibu rtf fuzzyhead Boats (FS/W) 3 Jan 08, 2013 04:20 PM
