Old Nov 06, 2011, 01:56 PM
Joined Jul 2006
Guardian Hanging Elogger and OSD Help Please!!!
I was trying to setup the guardian stabilizer. I connected it to my OSD and updated to the latest firmware versions (10.04) and set the on screen menus to turn on the stabilizer from the data recorder software. Now the elogger is no longer recognized in windows. It shows up as failed in device manager. If I start the data recorder software and plug in the elogger the data recorder stops responding. When viewing the transmitted video signal the OSD shows stabilizer discconnected at the top of the screen. It seems like the elogger won't active USB mode now because it can't find the guardian. I have it connected correctly to the OSD and the green light flashes on the guardian. The lights on the elogger no longer come one.
How can I reset the data logger if I can't get it connected to the software? This seems like a bug in the programming. The usb function shouldn't be blocked because the stabilizer is configured but not found. I have a feeling if I could turn it off the OSD and logger would start working again.
I guess the guardian guards well. If the plane is grounded it can't crash. Not really the type of protection I was looking for though.
Please help!!!
nem
nemesis43 is offline Find More Posts by nemesis43
Old Nov 07, 2011, 07:19 AM
Resistance is Futile
camship's Avatar
United States, FL, Panama City Beach
Joined Oct 2001
Please help!!!
nem
camship is offline Find More Posts by camship
Old Nov 07, 2011, 12:04 PM
KJ4YYJ
EugeneFlorida's Avatar
Saint Petersburg FL
Joined Jun 2009
Try http://eagletreesystems.com/support/apps.htm
go down to Windows Application BETA version
and it will in stall install ver 07 or 08. see if that works For you.
EugeneFlorida is offline Find More Posts by EugeneFlorida
Old Nov 08, 2011, 05:18 PM
billpa's Avatar
Joined Nov 2003
nemesis43, if the eLogger's LED does not blink when the Guardian is connected, there is an issue with either the connection, the cabling, or the hardware.
Please do this:
1) check that the OSD or Guardian is not connected incorrectly (backwards connection, off by one connection, etc.)
2) if those are correct, please connect either the OSD or the guardian to the eLogger, and determine which of them is causing the LED not to blink. The one that causes this either has a broken wire, or has been damaged.
billpa is offline Find More Posts by billpa
Site Sponsor
Cool Guardian stabilization module for your OSD Pro - $54.99! billpa FPV Equipment 1981 Jun 18, 2014 05:29 PM
Question OSD Pro, eLogger V3, GPS V4 problems updating firmware in OSD Pro jbfoamy Eagle Tree Systems 23 Jun 02, 2012 03:59 PM
Sold Complete EagleTree OSD Pro and guardian. bakchos FPV Equipment (FS/W) 9 Oct 05, 2011 12:40 AM
Sold Eagletree OSD Pro/Elogger V4/GPS Expander RaptorAP FPV Equipment (FS/W) 10 Sep 16, 2011 10:45 PM
Help! Noob needs help wiring elogger-v3/OSD Pro Mykro Eagle Tree Systems 7 Jun 25, 2010 01:59 AM
