Old Jan 20, 2010, 08:17 PM
Joined Dec 2009
Help!
Need help converting Guillow's Piper Super Cub 95
This is my first time actually converting a model into an R/C. I chose the Piper because I am more familiar with it than, say, the Hellcat, but I do not know where to start. I have not even unwrapped the box because I know I might mess it up, but it is hard to keep my hands away... Can someone tell me where to begin, what to convert, HOW to convert, and stuff like that? Thanks.
hahakingpin is offline Find More Posts by hahakingpin
Old Jan 21, 2010, 10:24 AM
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
Not familiar with the Piper but my B17 guillows plan contained but model for display plans as well as extra plans and step to take if you wanted to make the model flyable (ucontrol line).
If yours does not, then several things are to be considerer.
Weight is always a factor so you dont want to go crazy with reinforcing everything with extra wood but some will be needed.
Firewall or where the motor will mount is where you are going to want to reinforce as well as where the control surface hinges are going to be.
Then building the model with moveable control surfaces is something else.
Ailerons, elevator & rudder unless this model as dihedral wing then you could get away with elevator rudder only.
Then build the airframe with some sort of access hatch is also to be considered, you need access inside to swap out battery and insert electronics.
the added weight of said electronics will of course mean you will need a strong landing then original designed. All these things must be taught of first as to not have to back step when building.
freechip is online now Find More Posts by freechip
Old Jan 21, 2010, 10:48 AM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
These threads may help -
Guillow's Piper Super Cub 95 - Brushless Conversion
also - Guillows piper super cub 95 conversion.HELP
and - Guillows 20" Piper cub RC conversion
eflightray is online now Find More Posts by eflightray
Old Nov 17, 2014, 03:14 AM
Siskiyou RC Scalers
FalconFPV's Avatar
Joined Aug 2013
I'm building one right now! Here I go
http://www.rcgroups.com/forums/showt...6#post29964410
FalconFPV is offline Find More Posts by FalconFPV
Build Log Guillow's Piper Super Cub 95 - Brushless Conversion BennettOZ84 Scale Kit/Scratch Built 142 Jan 31, 2013 02:10 PM
Discussion Guillows piper super cub 95 conversion.HELP yellowmg1978 Scale Kit/Scratch Built 7 Jan 20, 2010 07:39 PM
Help! .049 in a Guillow Piper Super Cub 95? Straker 1/2A Planes 16 Dec 05, 2007 09:17 AM
Guillow Chipmunk & Piper Super Cub 95 Fireflynj Scratchbuilt Indoor and Micro Models 2 Nov 22, 2005 11:59 AM
Guillow's Piper Super Cub 95 Capt Crash Free Flight 3 Sep 08, 2004 01:43 AM
