Old Jan 05, 2003, 07:34 PM
bosley is offline
Find More Posts by bosley
bosley's Avatar
United States, CA, Twentynine Palms
Joined Jun 2002
Switchback Motor trouble?
I have been noticing a decrease in power over the last several flights, I wasn't quite sure what was causing this or if there was any real difference at all.
I was about 4 minutes into my fourth flight today when the motor cut out on me. I thought it was strange for the battery to die this early in a flight. I throttled back then on again, the motor cut on for a couple seconds than stopped again. It wouldn't come back on again no matter what I tried so I brought her in dead stick. Thinking it might have been my battery, I switched it out and still no dice.
I tried spinning the prop by hand and there was a pretty rough grinding noise and it was definitely fried.
My question is.
What is an average life span for an EPS300-C running on 8 cell 700 AAA nimhs?
Todays session brought it up to 41 flights and just under 5 hours of flight time. I would say definetly less than 50% of the flight time at full throttle.
Is that normal?
Thanks for any help
Boz
bosley is offline Find More Posts by bosley
Old Jan 05, 2003, 07:38 PM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
Re: Switchback Motor trouble?
Originally posted by bosley
Is that normal?
Quick answer: yup
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old Jan 05, 2003, 07:55 PM
bosley is offline
bosley's Avatar
Joined Jun 2002
Hey Dreamer i like your Frankness in the matter You had me laughin out loud.
I got another question for you.
Are both poles inside the motor supposed to have brushes on them?
I was pretty sure they were supposed to. At any rate this motor only has one now. The other is probably layin out in the ball field somewhere.
Would the motor locking up like it did fry my ESC too? The servos and stuff still respond and there was no smoke. I am thinking that maybe the motor not being able to turn would draw enough amps to fry the ESC. Does the Pixie 20P have an overload protection circuit? Or am I just completely off base here?
Last one.
Where is the cheapest place to get a couple more of these bad boys? I don't need the gearbox just a motor or four! Now I'll probably break the gear box next so I ought to get on of those while I'm at it!
Thanks guys
Boz
Old Jan 05, 2003, 08:18 PM
CoClimber is offline
Find More Posts by CoClimber
Mountain Models Wannabe
CoClimber's Avatar
Ithaca, NY USA
Joined Mar 2001
Boz,
I have a few replacement motors for $10 each. Shipping will be $3.85.
The Pixie 20 is pretty tough so I doubt you hurt it.
Doug
CoClimber is offline Find More Posts by CoClimber
Old Jan 05, 2003, 08:25 PM
bosley is offline
bosley's Avatar
Joined Jun 2002
Thanks Doug I just sent you an email asking about the motors. I'll be placing an order very soon now that my wife has gone to bed.
Do they come with the pinion already installed? Does timing the motors help to prolong their life or just improve the performance while it is alive?
Can't wait to get it back in the air!!! I was so close to 50 flights too
Old Jan 05, 2003, 08:33 PM
rclark is offline
Find More Posts by rclark
A Clinger
rclark's Avatar
Butte, MT
Joined Sep 2001
FYI, going to 8 cell 600AE and 1100s your motor life is about ~25 flights. My Zero with a 7 cell is about ~45 flights . This was my experience before going brushless .
BTW the 'brush' you 'lost' is just wore off -- didn't fall off . Your ESC 'should' be fine-- I had 6 motors do this without any problems to the D20 ESC I was using (Now my heart, on the other hand, on panic deadsticks LOL may have some defibb problems -- seems always not in a 'good' spot for a good landing ) .
rclark is offline Find More Posts by rclark
Old Jan 05, 2003, 08:37 PM
Basketcase is offline
Find More Posts by Basketcase
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Hi Boz, same thing happened to me, check out this thread:
http://www.rcgroups.com/forums/showt...threadid=36302
Near the end are directions how to adjust the timing so both brushes wear evenly. I don't know how much extra time it provide but might be worth a try.
BC
Basketcase is offline Find More Posts by Basketcase
Old Jan 05, 2003, 08:41 PM
mlehman is offline
Find More Posts by mlehman
mlehman's Avatar
United States, FL, Cape Coral
Joined Jun 2002
Hi
I have one you can have for free..PM me with your address
mlehman is offline Find More Posts by mlehman
Old Jan 05, 2003, 08:50 PM
bosley is offline
bosley's Avatar
Joined Jun 2002
Awesome offer!!!
Thanks alot for your help. Just sent a PM. This kind of support can't be found in to many places these days. The people of this site make this hobby so much more enjoyable for me. Thanks again Sprinter and everyone else.
Boz
Old Jan 05, 2003, 10:15 PM
Leave me alone!
Joined Feb 2002
Interesting question, as I had a defective brand new motor take out my Pixielite 14 (Pixie 20 without the wires included) and two servos when the motor stopped in flight.
Martin
Old Jan 08, 2003, 05:17 PM
bosley is offline
bosley's Avatar
Joined Jun 2002
Ordered from Mountain Models Sunday
Got here today!! Awesome service!
Thanks Doug, I should be back in the air tomorrow. It has been windy for a couple days anyway, so I didn't miss too much.
I just orderd some of the cheapy 2/3 A 1000 mah cells from BYD.32 cells for $36.00.(we'll see if they are worth it) What is the best 8 cell configuration to fit in the SB sport with the new style canopy?
Boz
Old Jan 08, 2003, 05:20 PM
CoClimber's Avatar
Ithaca, NY USA
Joined Mar 2001
I have some of those BYD cells. If you aren't trying to go vertical, they aren't bad. Make then as a staggered two rows of 4.
O O O O
O O O O <-- This row should be offset
Doug
(edited the battery diagram)
Old Jan 08, 2003, 06:46 PM
bosley is offline
bosley's Avatar
Joined Jun 2002
Doug,
How fast can you charge those 2/3 A cells? I am hoping they can handle more than 1C.
By the way I tried my ESC and all seems to be right in the world again. No problems at all.
Old Jan 08, 2003, 08:24 PM
mlehman is offline
mlehman's Avatar
Joined Jun 2002
I use the BYD 2/3A batteries all the time..I get about 11-12 minutes WOT with a stock GWS motor in GWS P-51..about the same run time with a MiniAC 20 turn brushless motor in a SB.I use a 9 cell pack in everything
I`ll get the motor out sat morn
Old Jan 08, 2003, 08:49 PM
bosley is offline
bosley's Avatar
Joined Jun 2002
Thanks again Mike. What are your charge rates on the 2/3 A cells. I have a couple packs of their AAA's and it takes over an hour to charge them. At least to charge them without venting some cells
If you don't mind telling, How is the performance with the mini AC. How much does it cost to get a setup with one.
Boz
Switchback motor decision - Tempted by brushless Bill Germanson Parkflyers 48 Nov 04, 2002 10:51 AM
Switchback motor question... Zak Parkflyers 7 Sep 16, 2002 12:42 PM
Alternative Switchback motor can... genovia Parkflyers 20 Jul 26, 2002 10:12 AM
switchback motor and batts? dpoles Parkflyers 7 Jun 10, 2002 10:28 AM
Switchback motor alternatives? JBowling Parkflyers 9 May 28, 2002 09:58 AM
