Old Jan 05, 2003, 03:46 PM
jevid is offline
Find More Posts by jevid
Cayucos, CA
Joined Jan 2003
Taping a plane - design question
I'm getting ready to cover my first plane, a Windrider Bee. I have a question about putting on the colored tape. I'd like to put some kind of design or pattern on the bottom of the wing, perhaps chevrons. Is it ok to just cover the plane with a sloid color, then use cut out pieces of tape to create a design? I would do the same on the left & right side of the bottom so the weight would be even. Or, when using tape, do you need to work the design in as you are taping. It seems to me that the colored tape should be complete pieces from the center of the plane to the wingtips for added strength & durability. But maybe not....?
David
jevid is offline Find More Posts by jevid
Old Jan 05, 2003, 05:18 PM
Brian Courtice is offline
Find More Posts by Brian Courtice
Brian Courtice's Avatar
United States, FL, Punta Gorda
Joined May 2002
There is no reason at all not to tape the whole plane in one color and then add trim.
Brian Courtice is offline Find More Posts by Brian Courtice
Site Sponsor
Old Jan 06, 2003, 12:45 AM
CactusJackSlade is offline
Find More Posts by CactusJackSlade
Whadda YOU lookin' at?
CactusJackSlade's Avatar
United States, CA, Folsom
Joined May 2002
Packing Tape
Yes, make the first color out of long continuous pieces, then add trim color.
I would also heat shrink the first covering layer before adding the trim color - heat shrinking adds strength and rigidity, just be careful and keep the heat gun moving!
Many people do not know that you can heat shrink covering tape, but it works nicely!
Keep in mind that when using this tape it is thin and slightly transparent - if you put light colors over light colors they may not show up as you like...
Go here for photos - most of these were heat shrunk:
http://hobiehawk.com/Zagiphotos.html
CactusJackSlade is offline Find More Posts by CactusJackSlade
Old Jan 06, 2003, 01:03 PM
McGrrr is offline
Find More Posts by McGrrr
McGrrr's Avatar
Cedar Park, Texas, United States
Joined Jul 2002
Tape Color
I would use a lighter color for the base and a darker color for the design. Dark colors bleed through the lighter shades and looks horrible.
McGrrr is offline Find More Posts by McGrrr
Discussion Float design question for 18lb plane Larry3215 Waterplanes 8 Jun 09, 2006 07:18 PM
Elexaco plane design requirements RFD Electric Plane Talk 15 Jan 14, 2006 12:01 AM
design question for you jet gurus KSU Flyer Electric Ducted Fan Jet Talk 10 Aug 22, 2002 12:19 PM
Elevon Design question rparigoris Power Systems 2 Feb 20, 2002 12:31 AM
another intake design question Jensst Electric Ducted Fan Jet Talk 15 Oct 18, 2001 09:20 AM
