Old Oct 06, 2006, 06:06 PM
bryadelm is offline
Find More Posts by bryadelm
United States, PA, West Chester
Joined Mar 2006
Question
Ford Flivver Electrical Power
I just ordered by Ford Flivver small glo 40 size ARF which is a special running now at Dymond Modelsports. While I expect to use a RCV 58CD on another plane now (bad intention?), I welcome any suggestions for selecting an electric power for this size Flivver.
Here are Dymond's recommendations for 3 flights 8 minutes each or one long flight approx 25 min:
Motor Gunther 30/3
Speed controller 60 A
5 mm clamp on propeller adapter with 40 mm aluminum spinner
Aluminum motor mount with cooling fins
Propeller 11 x 5.5
Battery 3S2P 7000 mah
I do not want to use a receiver battery, so I will need to get an ultimate BEC which can be wired in parallel with the speed controller and provides the power for the receiver.
Also, I am interested in all tips, including from those who have built and flow the Ford Flivver large glo 60 size ARF, which is no longer available from Dymond.
bryadelm is offline Find More Posts by bryadelm
Old Oct 06, 2006, 06:17 PM
bryadelm is offline
Joined Mar 2006
Here are the specs:
Wing 54"
Weight 78.5 oz
Wing area 648 sqin
.40 Twostroke
.52-.56 Fourstroke
2 Micro size D 200 BB 3 Std size for ailerons
Old Oct 14, 2006, 05:26 PM
bryadelm is offline
Joined Mar 2006
Given no replies here in one week, I moved this topic to Power Systems hoping for a response there.
This tread may be closed.
Discussion Ford Flivver small glo 40 size ARF Electric Power 6 Options bryadelm Power Systems 37 Feb 11, 2008 08:49 AM
Discussion Ford Flivver Electrical Power bryadelm Hacker Brushless 6 Nov 28, 2006 03:58 PM
Ford Flivver Flight Report Roger P Scale Kit/Scratch Built 1 Dec 06, 2002 12:00 PM
Ford Flivver bobandris Scale Kit/Scratch Built 10 Aug 02, 2002 03:15 PM
Ford Flivver bobandris Scale Kit/Scratch Built 4 Jul 31, 2002 07:25 PM
