NEW! Skyzone 3D FPV Goggles
3D FPV is Coming
SkyZone takes it to another dimension
3D is the latest advancement in FPV. Skyzone is releasing a 3D goggle and camera combo set at the end of January. The goggles have been designed from the ground up and feature a high res widescreen display with a 30 degree FOV. It has dual receivers built in that works in tandem with the included 3D camera and 600mW video transmitter. This provides a crazy 3D flight experience like you've never seen before. The goggles also have head tracking if you wanted to add a pan/tilt setup on the camera for complete immersion.
You get audio/video inputs and outputs on the goggles and also a built in DVR with playback. They carry over the camera on the front from earlier goggles so you can switch to a live view to see what's in front of you. There are so many features on this set of goggles it's almost unreal. Who's ready for 3D FPV! I know I can't wait to try it out and see what this experience will be like.
Check out the new Skyzone 3D FPV Goggles at HobbyKing.
Features:
  • 3D FPV
  • Complete plug and play set
  • 2D diversity mode
  • Built-in DVR
  • Built-in 32CH 5.8G Diversity receiver
  • Built-in self-calibrating head tracking (gyro, inertial and compass)
  • Built in Dual 854X480(WVGA) Monitors, 1,229,760 color sub-pixels
  • Built-in external camera for surrounding view (640X480)
  • AV in/ AV out/ Earphone socket (with volume control)
  • Adjustable Interpupillary and Diopter for your eyes
  • Adjustable brightness and contrast
Specifications:
  • FOV: 30 degrees
  • Resolution: 854x480 (WVGA) 1230k
  • Interpupillary (IPD) distance: 60-68mm adjustable, Diopter with optional lenses
  • Channels: 32CH 4band 5.8GHz (Fatshark, Boscam & Skyzone compatible)
  • Receiver: Dual ISM 32ch Diversity receiver -90dbm Sensitivity
  • Video Format: NTSC/PAL
  • Antenna Connector: 2x SMA 50ohm
  • Front Internal Camera: 120 degree 640x480
  • Head Tracker: Compass/ Inertial and gyro ppm selectable channel output
  • A/V Port: 3.5mm
  • Ear Out: 3.5mm with volume control
  • Power Supply: DC 7-28v / 1A
  • Power Consumption: 4.3w
3D Camera Specs:
  • FOV: 85 degrees (Diagonal)
  • Resolution: 720X576
  • Video Standard: PAL
  • Video output level: 1.0Vp-p Typ. / 75ohm
  • Audio output level: 2.0Vp-p Typ. / 10Kohm
  • Power supply: DC 5.0V/ 0.5A
  • Power Consumption: 1.6W
Old Jan 16, 2015, 03:00 PM
Machy2k is offline
Find More Posts by Machy2k
Machy2k's Avatar
Ft Lauderdale, FL.
Joined Jan 2007
This is gonna be good!!
Machy2k is offline Find More Posts by Machy2k
Old Jan 16, 2015, 04:46 PM
Hammer Head is offline
Find More Posts by Hammer Head
the journey is the reward
Hammer Head's Avatar
Canada
Joined Apr 2002
Wow! Looking forward to learning more about this.
Hammer Head is offline Find More Posts by Hammer Head
Old Jan 16, 2015, 06:12 PM
SuarezLuis is offline
Find More Posts by SuarezLuis
SuarezLuis's Avatar
United States, TX, Killeen
Joined Jul 2013
Take my money!!!!!!!
SuarezLuis is offline Find More Posts by SuarezLuis
Old Jan 16, 2015, 08:21 PM
pigmypuncher is online now
Find More Posts by pigmypuncher
pigmypuncher's Avatar
United States, TX, Plano
Joined Oct 2010
It's good to see more competition in the 3D FPV arena.
pigmypuncher is online now Find More Posts by pigmypuncher
Old Jan 16, 2015, 09:11 PM
out of stock is offline
Find More Posts by out of stock
DONT PANIC! :)
out of stock's Avatar
United States, FL, Lehigh Acres
Joined Jan 2012
I just bit myself
out of stock is offline Find More Posts by out of stock
Old Jan 17, 2015, 03:44 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
What competition ? There is no such thing because there is no 3D, simply...
Was already demonstrated that 3D sensation based on stereoscopy happens for close objects, under 20 meters, which is not the case for FPV, unless you are planning to fly forest race.
For landscapes simply it don't happen, we don't have the feeling or judge that a mountain is closer than other unless if they overlap partially, but this is perspective, not 3D.
renatoa is online now Find More Posts by renatoa
Old Jan 17, 2015, 03:53 AM
schumixmd is online now
Find More Posts by schumixmd
schumixmd's Avatar
Moldova
Joined Jun 2010
A great unboxing video already done by BMSWeb on the thread opened by FPVModel.
schumixmd is online now Find More Posts by schumixmd
Old Jan 22, 2015, 03:11 AM
Norbit is offline
Find More Posts by Norbit
Lithuania, Vilnius County, Vilnius
Joined Jul 2014
30deg fov? forget it
Norbit is offline Find More Posts by Norbit
Old Jan 23, 2015, 02:30 PM
itsdrei is offline
Find More Posts by itsdrei
United States, MD, Waldorf
Joined Jan 2015
Skyzone 3D FPV Goggle review
This kids reaction to the Skyzone 3D goggles says it all!
http://youtu.be/_ll4cbT4yPc?t=8m30s
itsdrei is offline Find More Posts by itsdrei
Old Feb 06, 2015, 06:19 PM
John Hendry is offline
Find More Posts by John Hendry
John Hendry
Joined Oct 2013
Get out the butter...
If you want REAL 3D it takes real life technology... two eyes seeing the same thing separated and that requires two VTX's and two VRXs. When you watch a 3D movie and see mountains far away that's a trick and we need the real deal. But just remember like in a full scale aircraft 3D up high isn't going to make much difference and it's down low where it matters so these will be better than nothing and a huge step in the right direction. The best 3D right now is two pairs of DOMHDs hacked into one taking two signals and here is where harmonics come into play and I'll bet my last dollar it's FPV that advances electronics into the new age of tech wonderland. e{a}/t=hv
Edit: Just watched a video on these goggles and the diversity in 3D was claimed to be carrying each cameras signal to each eye separately and if that's how its working then that is awesome. Vision is a deeply complex issue that takes us into the very nature of reality itself but while it's true we lose 3D perception at distance we don't lose it all and motion increases it (even with monocular vision to a lessor degree) and flying between two objects as when flying down in a canyon 3D goggles will be amazing compared to the monocular vision of a single camera used. Our visual cortex uses binocular cells that have receptive fields in different horizontal positions in each eye and these cells are only active only when stimulus is in the correct position in each eye creating a disparity detector for our brain to process information. Much of the advantages of stereoscopic vision are subtle but quite real and it's when objects get close that depth perception is important and this is where people with good 3D vision are being blown away by 3D FPV.
John Hendry is offline Find More Posts by John Hendry
Last edited by John Hendry; Feb 06, 2015 at 11:18 PM. Reason: Adding information...
Old Feb 07, 2015, 09:15 AM
squishy654 is offline
Find More Posts by squishy654
squishy654's Avatar
Joined Jun 2010
Flight Club Skyzone 3d review night flight (4 min 40 sec)
squishy654 is offline Find More Posts by squishy654
Old Feb 08, 2015, 01:45 AM
BixlerBoy is offline
Find More Posts by BixlerBoy
Joined Aug 2013
Ipd...
Max IPD is 68 mm? What is this, goggles for ants?
BixlerBoy is offline Find More Posts by BixlerBoy
Old Feb 08, 2015, 01:49 AM
Joined Sep 2007
Nope, standard is 63.5mm, ask any optician !
Zeiiss cinemizers are recommended for 58-68mm people, and here fits 90% of caucazians. And they aren't adjustable !
Using these skyzone set at 68mm will be good even for a 72mm person.
Old Feb 08, 2015, 06:58 AM
type-si is online now
Find More Posts by type-si
United States, WA, Blaine
Joined Nov 2006
Foxtechfpv has them for 5% off plus loyalty 3% = 489usd
type-si is online now Find More Posts by type-si
Discussion New Diversity FPV Goggles SKYZONE available at foxtechfpv.com glassfox FPV Equipment 1559 Apr 20, 2015 04:20 PM
Sold SkyZone Diversity FPV Goggles - Brand New titanflyer FPV Equipment (FS/W) 1 Oct 16, 2014 02:03 PM
Sold SkyZone Diversity FPV Goggles - Brand New titanflyer Aircraft - Electric - Multirotor (FS/W) 1 Oct 16, 2014 01:17 PM
Sold Almost New - SkyZone Diversity FPV Goggles titanflyer Aircraft - Electric - Multirotor (FS/W) 2 Aug 25, 2014 10:49 AM
