Old Dec 20, 2014, 08:24 PM
soarrich is offline
Find More Posts by soarrich
Soarrich
soarrich's Avatar
Middletown, NJ
Joined Dec 2003
Help!
I don't know what is wrong with my gyro, do you?
Cat in hat RC gyro. (0 min 41 sec)
The first attempt it was windy, when gave it up the gyro came up, but it looked too steep so I gave a little down and it dove into the ground.
Cat in hat second attempt at flight. (0 min 35 sec)
Almost no wind on second attempt. I cut some of the "Elevator" throw and added some nose weight so it would hand about 10 nose down. I also added some more back angle on the rotor's normal setting, but it still would not lift off without pulling back.
Any suggestions?
soarrich is offline Find More Posts by soarrich
Old Dec 20, 2014, 11:43 PM
Jockadopolus is online now
Find More Posts by Jockadopolus
Jockadopolus's Avatar
Scotland
Joined Jan 2010
Rich you are so close to getting it flying
What are the head and blades from?
Posting video of test flight problems is very helpful to see what went wrong
A couple of things I would check
1.Hang angle a bit more than 10deg
2.Check the neg pitch on the blades too much and you will lose lift
3.The main wheels look a bit too far back and may not allow the model to rotate
Keep videoing any more flights, I rely on videos for my tests as I can never remember exactly what my model did
Joe
Jockadopolus is online now Find More Posts by Jockadopolus
Old Dec 21, 2014, 12:26 AM
soarrich is offline
Soarrich
soarrich's Avatar
Middletown, NJ
Joined Dec 2003
Joe
Joe
1.The hang angle is about 10.
2. I'm thinking this may be the problem. I'm using Flying Balsa's rotor and blades so I never actually check the negative pitch, I assumed it would just be correct. I find the blades spin up very easily, so they maybe too negative pitched.
3. I don't think that's the problem, it seemed as though it over rotated on the last attempt, that's what caused the dump.
I try to get my wife to video for me, but it's tough to get her out there. I've tried guys, you get a lot of sky and grass, aircraft not so much.
The last flight broke the hinge on one blade, it was below freezing, so now I have to disassemble the head and make a new hinge.
Rich
Old Dec 21, 2014, 01:17 AM
Gyrocopter is online now
Find More Posts by Gyrocopter
What could possibly go wrong!!
In Bedfordshire, UK.
Joined Oct 2008
Rich
That was so close and I think as Joe said it is likely to be hang angle, if possible aim to get it nearer say 14deg but without adding weight. You might also try a few hops first to get the feel of it but keeping the lift off point as close to you as possible to avoid disorientation.
Good luck but dont give up, you are nearly there.
Chas
Gyrocopter is online now Find More Posts by Gyrocopter
Old Dec 21, 2014, 08:52 AM
SafeLandings is online now
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
Rich,
Looks to me that you have too much negative incidence added to your blades, they looked to spin up really quickly with no lift off until you pulled back on the rotors. What you need is the least amount possible, this way you will get the best lift from the blades.
If your thrust line is above the CG position this will cause the nose to dip under power, the more lift/drag your blades produce the lesser this effect.
Also, if you are able to adjust your U/C so that the horizontal stab is parallel well with the ground this will help ROG. To me it looks like its pointing down slightly?
Keep at it mate.
Rich
SafeLandings is online now Find More Posts by SafeLandings
Old Dec 21, 2014, 08:54 AM
David A Ramsey is offline
Find More Posts by David A Ramsey
New Jersey, USA
Joined May 2003
You have good head speed. What I see is not enough, or not enough available, left rudder input to level the airframe. With a high angle at lift-off, cyclic roll/tilt, isn't always enough to catch the right roll. I suggest a larger rudder.
David A Ramsey is offline Find More Posts by David A Ramsey
Old Dec 21, 2014, 01:01 PM
Joined Dec 2007
Way to much negative incidence Rich, look at getting around 1 degree maximum, try and get a bigger hang as well at around 15 degrees. With three blades the rotor should be about 5-6 degrees off horizontal tipping rearwards. The reason why it is tipped back so much is because of the excess negative shim on the blades.
Rich
Old Dec 21, 2014, 04:56 PM
mnowell129 is offline
Find More Posts by mnowell129
Mickey from Orlando. Really.
Joined Nov 2004
What's the disk area and weight?
Plenty of rotor speed, looks like it might be too heavy.
mnowell129 is offline Find More Posts by mnowell129
Old Dec 21, 2014, 07:41 PM
soarrich is offline
Soarrich
soarrich's Avatar
Middletown, NJ
Joined Dec 2003
Disk area is 2200 sq. in., I never weighted it, but probably about 5~6 pounds. I'm going to take -3 negative out of the blades and try again.
Old Dec 22, 2014, 07:30 AM
Joined Nov 2004
This is almost 7 ounce per square foot disk loading. The issue may be not enough power/speed. About 5 ounces/ft^2 is a good number to start with for small models, less is better. Properly loaded it should lift off by itself.
Old Dec 22, 2014, 08:39 PM
soarrich is offline
Soarrich
soarrich's Avatar
Middletown, NJ
Joined Dec 2003
I just weight it..........7.8 pounds we'll wait after the next attempt to see if a diet is in order, so far the filling of the aluminum channels with wood has kept it from bending like a pretzel.
Old Dec 22, 2014, 08:42 PM
soarrich is offline
Soarrich
soarrich's Avatar
Middletown, NJ
Joined Dec 2003
Rich
Ok, I'll use your numbers on my next attempt. Thanks.
Old Dec 22, 2014, 08:45 PM
soarrich is offline
Soarrich
soarrich's Avatar
Middletown, NJ
Joined Dec 2003
Do I need the stab? I put it on mainly for visibility, is it needed aerodynamically?
Old Dec 23, 2014, 06:36 AM
Joined Nov 2004
8 ounce/ft^2 loading is probably your problem. You need to lose 3 pounds somewhere or make a much bigger rotor. Shoot for 5 ounces/ft^2.
At 8 pounds you probably need 3-4 pounds of thrust, 600 watts probably.
Discussion I'm new and don't know what to do. lol. randolph45 Electric Plane Talk 48 May 18, 2014 11:09 PM
Help! need arbitration... bought heli and don't know what to do, Help me Dcope17 Trader Talk 62 Nov 17, 2013 03:15 PM
Help! I don't know what else to do with my paraglider to make it fly kizzie33 Flying Wings 8 Feb 22, 2013 09:36 PM
Discussion Don't know what to do with my money Mr. Lin? Rudi GWS (Grand Wing Servo) 5 Dec 14, 2007 07:04 AM
