Old Mar 13, 2014, 12:33 PM
tghsmith is offline
Find More Posts by tghsmith
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
Build Log
Uss raleigh c-8
started turning this project from planning to materials this last week or two, yes its hull with gun sponsens, yes its going to be a two piece mold and a few other things I said I wouldn't do again, The plug for the hull has been shaped and will get an epoxy filler coat to harden it up and seal it. primer and bondo then can be safely used.. the sponsens and other details will be added, once everthing looks good the hull halfs will be separated and molds made.. (hopefully in a week or two) with some minor adjustments to the hull the USS Cincinnati C-7 can be built.. 1/96th scale, the hull is approx 39 inches LOA, not having a large superstructure and being a coal burner the models displacement should make things easy..
tghsmith is offline Find More Posts by tghsmith
Old Mar 13, 2014, 12:44 PM
the goon is offline
Find More Posts by the goon
boat butcher
the goon's Avatar
Whittier CA.
Joined Oct 2009
Cool
Mark
the goon is offline Find More Posts by the goon
Old Mar 13, 2014, 05:32 PM
Homeport is offline
Find More Posts by Homeport
United States, MA, Lowell
Joined Dec 2008
Looking forward to seeing it in October.
Homeport is offline Find More Posts by Homeport
Old Mar 14, 2014, 02:44 PM
tghsmith is offline
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
the plug was coated with expoxy, given a quick sand to knock off any high points and to rough up the surface.. then everything was given a good coat of bondo.. it all gets to sit for a few days and then the sanding starts,, meanwhile work goes on the componates that will be added to the basic hull plug..
Old Mar 20, 2014, 02:31 PM
tghsmith is offline
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
side gun sponsons have been added and then gooped in place well with bondo, one side recieved some basic sanding to shape and a quick shot of primer to point out all the spots that need more work.. still have to add the small aft sponsons and the inset pair in the bow..
Old Mar 21, 2014, 02:27 PM
tghsmith is offline
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
have most of the starboard side work roughed in, now to start on the port..
Old Mar 21, 2014, 03:06 PM
Tim B. is offline
Find More Posts by Tim B.
Tim B.'s Avatar
Joined Aug 2009
Cool !
Looks bigger than 39 inches whilst on that bench top ~
Tim B. is offline Find More Posts by Tim B.
Old Mar 22, 2014, 10:37 AM
Dave0549jv is offline
Find More Posts by Dave0549jv
Joined Apr 2012
Looking good man, I'll stay tuned
Dave0549jv is offline Find More Posts by Dave0549jv
Old Apr 01, 2014, 01:13 PM
tghsmith is offline
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
about done with the bondo work, moving on to spot putty and finer sanding..
Old Apr 01, 2014, 06:18 PM
Homeport is offline
Joined Dec 2008
Will it be ready for October ?
William needs someone to run with.
Old Apr 01, 2014, 07:11 PM
tghsmith is offline
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
maybe something like this.. hope to have it close to done,my stuff never gets finished..
Old Apr 04, 2014, 12:02 PM
tghsmith is offline
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
spot putty, sanded and primed, getting close to the topcoat stage..
Old Apr 22, 2014, 04:57 PM
tghsmith is offline
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
more sanding, then a few coats of gloss paint to top it off.. then the big step of splitting the hull halfs down the keel as planned, somedays the plan works, now to mount them to flat plywood, seal the edge, wax, pva and lay-up glass+resin to make the molds..
Old Apr 26, 2014, 05:28 AM
tghsmith is offline
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
poly resin and glass day, first a thick coat with resin with filler, a few neat layers and then layers to build up bulk.. it all get to cure until monday...
Old Apr 26, 2014, 10:22 AM
herrmill is offline
Find More Posts by herrmill
Shanghai'd Expat
herrmill's Avatar
Xiaoshan, China
Joined Jun 2006
Looking good!
herrmill is offline Find More Posts by herrmill
Mini-Review C.C. Lee 1/400 USS Enterprise (CVN-65) Plastic Kit In-box Review...A kit for RC fun? Kronosaur Scale Boats 2 Mar 14, 2015 01:32 PM
For Sale Multiplex MiniMag RTF - LPU Raleigh, NC area cshepherd Aircraft - Electric - Airplanes (FS/W) 3 Feb 03, 2014 01:54 PM
For Sale Relisting for my Glider can be seen in person at Raleigh Hobby in Raleigh NC WallsRoofing71 Aircraft - Sailplanes (FS/W) 0 Jan 30, 2011 06:36 PM
Raleigh N.C. nightflying strat919 3D Flying 7 Aug 05, 2005 05:40 PM
RAMS 3rd annual electric funfly 2 day even in Raleigh, NC August 7 + 8 Steve H. Electric Flight Events 76 Aug 17, 2004 11:41 PM
