View Poll Results: What style of Turnigy 1/16 vehicle do you prefer?
Rally Extreme 48 38.40%
Mini Trooper 47 37.60%
Racing Buggy 30 24.00%
Voters: 125. You may not vote on this poll
Old Jul 11, 2013, 11:52 AM
valiantGLX is offline
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
Originally Posted by archerwin View Post
Did you put one on your trooper? I'm using the HK-2 tx/rx combo, how do I install the standard gyro on my trooper. I might add it to my next order.
Nah, I soldered it into my micro LOSI SCT and I'm not prepared to pull it out.
HK-2, does that mean it's 2ch only? If so the telebee is probably the best bet, but I think the turnigy one would still work without heading hold. You just plug the gyro into the steering ch, and plug the servo into the gyro. Both the Telebee and Turnigy have an extra plug for the 3rd ch (Telebee: dual rates, Turnigy: heading hold) but you don't need to plug it in.
valiantGLX is offline Find More Posts by valiantGLX
Latest blog entry: Please ignore....... for now
Old Jul 11, 2013, 12:48 PM
mr. modder is offline
Find More Posts by mr. modder
Joined Jun 2013
can I get driveshaft length and the dimensions of the front of the chassis where the gearbox is and the dogbones length
mr. modder is offline Find More Posts by mr. modder
Old Jul 11, 2013, 01:40 PM
rcjose is offline
Find More Posts by rcjose
United States, TX, Richmond
Joined Aug 2010
Originally Posted by valiantGLX View Post
Some good news and bad news!
The good news is that my Spur and Pinion don't strip any more.
The bad news is that I broke a front lower arm, rear upper link, stripped the rear diff and lost a pin from the center drive shaft
The front arm and rear link were broken from a bad landing from a big air jump. Then I lost the drive shaft pin and I was down to RWD (which I should add is completely undriveable on loose surfaces). After the pin fell out and I only had RWD I thought "bugger it" and started doing some full throttle donuts to see it the $4 spur would fail, but the rear diff failed instead
So far my pins have not come out with the shrink tubing mod I did.
rcjose is offline Find More Posts by rcjose
Old Jul 11, 2013, 02:08 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
I might have to try it, but how does the tubing hold up? Have you needed to replace it yet?
Old Jul 11, 2013, 02:23 PM
rcjose is offline
Joined Aug 2010
Not yet. Make sure the tubing covers the entire shaft head
Old Jul 11, 2013, 04:06 PM
Joined Jun 2013
can I get driveshaft length and the dimensions of the front of the chassis where the gearbox is and the dogbones length please
I want to put 1/10 front gearbox shocks wheels on one i will order it and the gearbox same time please give measurement
Old Jul 11, 2013, 06:51 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Go to "My Media Dump" on the first page of this thread, scroll down to the bottom of the post and there is a PDF of the chassis including screw holes (it's traced from my chassis). Print it out and measure what you need.
The center shaft is 136mm long, the end without a pin is 5mm wide, and with the pin it is 9mm wide.
Old Jul 11, 2013, 07:02 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Here's the moment when my diff failed:
Turnigy Mini Trooper 1/16 Rear Diff Fail (1 min 26 sec)
Give me a like for my new dodgy production company :P
Also let me know if it doesn't play, youtube has matched my 3rd party content
Old Jul 12, 2013, 04:30 PM
Kondohon is offline
Find More Posts by Kondohon
Joined Jun 2013
I use the Telebee in my LOSI 1/24 SCT, and it works really well
However if you use 3ch electronics this gyro should be better because it has heading hold too:
Turnigy Head Lock & Standard Gyro (Digital/Analog)
Yeah, I'm thinking to install it to my mini trooper
Gyro is gaining popular on drift car too
However I broke my front and rear diff lol, so much bashing gonna buy some new set of gear diff. I don't know if compatible with kyosho mini inferno, I will checked first.
Kondohon is offline Find More Posts by Kondohon
Old Jul 12, 2013, 04:52 PM
Kondohon is offline
Joined Jun 2013
Anyone knows or used this gearbox and gear diff?
http://www.asiatees.com/display?Kyos...&id=4666&pid=1
http://www.asiatees.com/display?Kyos...id=45982&pid=1
I will order if direct replacement part, Hobbyking gear diff is soft
Old Jul 12, 2013, 05:01 PM
Kondohon is offline
Joined Jun 2013
Originally Posted by r/cmark View Post
I have run this a couple of times and just happed to notice that rear is not going back up when you press the rear end down (the front comes back fine).
I took off the shocks and all the pivot points seem to be free and moving nicely.
Is this normal?
http://www.youtube.com/watch?v=OQ6y4q68B0U
Me too, for short term I just fill the shock oil, saving my money to buy GPM racing shocks
Old Jul 12, 2013, 07:44 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
I'm 100% sure that the gears will fit, and 90% sure that the aluminium diff case will fit.
Old Jul 13, 2013, 10:32 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
I spoke too soon today I stripped a $4 spur before I could even get my camera out Seriously I got less than a minute run time; I drove a few meters forwards did a U-turn and that was it (I wasn't even driving it that hard). THIS IS GETTING BEYOND A FING JOKE!!!!!
Old Jul 14, 2013, 01:19 AM
Kondohon is offline
Joined Jun 2013
Haha, I like my mini trooper but the parts seems to be easy for wear and tear. Thats the downside of this model.
Old Jul 14, 2013, 04:15 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
All of the parts I have broken to date have been completely my fault (bad landings from big air jumps, hitting rocks, tree roots and a skatepark wall at full speed). However there is no excuse for these flamin' spur gears. I want to get a metal spur from Sour41 but he is so hard to get in contact with
Sold Turnigy Trooper SCT 4x4 PLUS Another 4X4 SC with Many EXTRAS!!! Only 190 bucks!! Maseo54 Cars - Trucks and Parts (FS/W) 1 Apr 23, 2013 02:20 PM
Sold Turnigy Trooper SCT 4x4 AND another SC 4X4 With a TON of Extras!! Only 190 bucks!! Maseo54 Cars - Cars and Parts (FS/W) 0 Apr 23, 2013 04:48 AM
Sold HK Trooper 4wd 1/10 SCT - RTR, upgrades, extras coolboarder Cars - Trucks and Parts (FS/W) 3 Apr 01, 2013 01:44 PM
Discussion Can I bolt on some different on road rims/tires for my Trooper SCT 4x4? MrRetro Off-road Cars 2 Jan 30, 2013 04:54 PM
Discussion 1/16 e-revo or Turnigy Trooper Dan_eflyer Off-road Cars 15 Jan 25, 2013 10:25 AM
