Old May 15, 2013, 07:00 PM
eak is online now
eak
Find More Posts by eak
eak
Joined Feb 2011
Octa design will it work good?
Will this design work?
simply use 4 square pipes of aluminium and put 8motors?
and put a mounting plate in the center.
or is the geometry off?
eak is online now Find More Posts by eak
Old May 15, 2013, 07:06 PM
ritchie_laird is offline
Find More Posts by ritchie_laird
ritchie_laird's Avatar
Australia, VIC, Craigieburn
Joined Jul 2012
it should work quite good, all you would have to watch is the materials weight, but no reason in the world it won't fly, work out the motor size and prop size, esc current and you should be in the air.
ritchie_laird is offline Find More Posts by ritchie_laird
Old May 15, 2013, 07:18 PM
Granted is online now
Find More Posts by Granted
serial scratchbuilder
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
You might want to spread the booms apart a bit 'til the motors are equidistant, that way you won't be limiting your prop size as much.
Granted is online now Find More Posts by Granted
Discussion FPV Setup - Will this work good together? jakobwolff FPV Talk 2 May 08, 2013 07:06 PM
Discussion Quad Tiltrotor Landing Gear Design - will it work? maxvtol VTOLs 1 Aug 30, 2007 12:37 PM
Discussion Aerial video from a 3D plane? Will my design work? Hellbore Aerial Photography 14 Aug 24, 2007 07:43 AM
Large BL motor design...will these work? DougT Power Systems 4 Jan 30, 2005 02:55 PM
Weird aileron design will it work in a foamy wing? dwholler Foamies (Kits) 37 May 15, 2004 09:50 PM
