Old Jul 05, 2014, 05:41 AM
RCFlyingKiwi is offline
Find More Posts by RCFlyingKiwi
RCFlyingKiwi's Avatar
New Zealand, Auckland, Manukau
Joined Jun 2008
Pre-Maiden
All finished, just a bit of checking and programming and it will be in the air. Going to use 3 modes, Takeoff / Normal / Landing.
TakeOff
Full rates on all surfaces, no aileron-rudder mix, 8 deg right rudder preset,15 deg of flaps down.
Normal
All surfaces on a single 3 position switch for rates, aileron differential, aileron-rudder mix.
Landing
15 deg of flaps down the rest controlled by a slider, full rates, no aileron mix, 75% exponential on the elevator.
All I need now is some decent weather, rain and wind at the moment, after all it is winter in the roaring 40s.
RCFlyingKiwi is offline Find More Posts by RCFlyingKiwi
Old Jul 05, 2014, 06:12 AM
stevespana is online now
Find More Posts by stevespana
Huesca, Spain
Joined Aug 2009
Very nice RCFlyingKiwi.
I like the covering scheme very much and you've done a great job on the landing gear.
I stupidly sold mine to a friend for a pittance and I've only ever seen him fly it once. If I could persuade him to sell it back to me I'd certainly attempt a new covering job such as yours.
Steve.
stevespana is online now Find More Posts by stevespana
Old Jul 06, 2014, 01:16 AM
tezact is offline
Find More Posts by tezact
Tezact
tezact's Avatar
Australia, ACT, Kambah
Joined Apr 2010
Hi Kiwi,
Can I suggest that you do NOT use flaps for your first takeoff. The model takes off very well without them and if you have too much flap you risk stalling. Play around with the flaps for takeoff once you have a bit of familiarity. Landing is different. Use all the flap travel you wish
Good luck.
tezact is offline Find More Posts by tezact
Old Jul 06, 2014, 04:39 AM
Joined Jun 2008
Thanks Tezat, usually approach a new plane very conservatively and certainly no flaps on the first flight, maybe try them at 100' but not low and slow. I'll post vid of how it goes.
Old Jul 06, 2014, 10:57 PM
tezact is offline
Tezact
tezact's Avatar
Joined Apr 2010
Kiwi,
Nice big High pressure system on its way over - make the most of it
Tezact
Old Jul 07, 2014, 03:43 AM
Joined Jun 2008
We have gale warnings for the next 2 days between the 2 systems, but the weekend is looking epic. Should have some vids soon.
Old Jul 12, 2014, 05:14 AM
Huesca, Spain
Joined Aug 2009
Steve.
Yes, yes, yes !!!
Just this morning I bought the Pilatus back from my friend for slightly less than I sold it to him for. What a result!
I'm now going to search for a suitable scheme and intend to strip the model down and recover it. Also, whilst the airframe is bare I will retro fit flaps and also consider how to improve the landing gear and whatever else comes to mind.
Steve.
Old Jul 24, 2014, 03:43 AM
Joined Jun 2008
Maiden
Got the maiden done in nice still conditions. Very successful although it needed a lot of down trim that may have been caused by the addition of split flaps. Underestimated the amount of down trim mix required for the flaps, they really hang out there, can do 60deg descents without breaking VNE. In subsequent flights I packed the aft edge of the wing up 1.5mm and that took out 75% of the down elevator trim so that is sorted now.
The active suspension is a great success, really scale and gives a very realistic motion on the ground.
My oddball 1900Kv 2 cell powering system driving the 10x7 3 blader is very well suited to the plane. Draws 96A on the bench and gives more than enough power for any scale maneuver, A 5 minute flight at 60% power gets the pack down to 3.85v per cell.
Overall a beautiful scale bird that performs exactly as it should. I'm stoked !!
Old Aug 11, 2014, 10:17 PM
Joined Jun 2008
Porter Maiden
Well the Porter is totally dialed in now and going really well. Will do the steep descent and flare out just like the real ones. Definitely a keeper.
Old Nov 18, 2014, 10:53 AM
jonnie22 is offline
Find More Posts by jonnie22
Joined Nov 2014
Flaps for PC 6 HOW TO?
[QUOTE=RCFlyingKiwi;28784790]My PC6 is coming along, will maiden next weekend with a bit of luck.
Took the forums advice and did split flaps rather than hacking into the wing. Used a 3mm carbon rod with 2mm ply ply flap glued to the back edge and a single servo actuator.
My undercarriage implementation is just about there, did it just like the real ones with 2 hinged A frames and a spring loaded strut giving 2cm of travel. There is a string inside the strut to stop it falling apart in the air. I used alloy/carbon arrow shafts that are really strong. Silver brazed up inserts at the right angles and epoxyed them into the shafts, the axle is a 5mm stainless bolt bent to necessary angle.
HI have you any more pictures of how you did your flaps as i have know got one of these planes and would love to do the same ,many thanks ( hope i have done this O.K. as first time on here)
jonnie22 is offline Find More Posts by jonnie22
Old Nov 18, 2014, 10:59 AM
jonnie22 is offline
Joined Nov 2014
Hi have you any more pictures of how you did this as i would really like to do the same many thanks.
Old Nov 18, 2014, 08:40 PM
Joined Jun 2008
I have a 27Mb .3pg file showing the operation, PM your email @ and I'll flick it across to you. I used 3mm square carbon rod, 1.5mm ply covered in shrink film for the flap blade.
I have found the wing horizontal stab incidences are not quite right for me, the CG is at the aft end of the limit, this caused quite a bit of down trim on the elevator to get level flight. I packed up the rear of the wing 1.5mm and that made it much better. I did not want to ballast for a more forward CG. If I were doing another one I'd raise the front of the horizontal stab 1 to 1.5mm but this is only specific to my electric conversion and my weights of LiPo and motor. If you get the chance to balance it before fixing the horizontal stab might be something to keep in mind.
Still going great, about 100 flights and nothing even close to a crash, a little truck damage but have a look at my facebook page (https://www.facebook.com/pages/Macle...?ref=bookmarks)
for the full story.
Old Dec 31, 2014, 12:02 AM
Joined Jun 2008
Near Miss
My Porter is going strong with a hundred flights up now. Had one of those 'Ooh S@#t' moments with my son-in-laws hexcopter. After a bit of camera testing we found it was an 8m miss.
Instinctive reaction was to pull a hard (very) stall turn and get the hell out of there.
Discussion pc-6 pilatus porter VQ 2.7m note Scale Fuel Planes 1 Mar 29, 2012 05:07 PM
Discussion VQ models Pilatus Porter PC-6 ranstam Fuel Plane Talk 14 Apr 14, 2011 04:49 PM
Found VQ Models Pilatus Porter PC-6 donho1 Aircraft - Fuel - Airplanes (FS/W) 1 Jun 15, 2010 02:08 PM
For Sale VQ Pilatus PC-6 107in W/S sarg96 Aircraft - Fuel - Airplanes (FS/W) 0 Jun 06, 2010 07:38 PM
For Sale VQ Pilatus PC-6 107in W/S sarg96 Aircraft - Fuel - Airplanes (FS/W) 0 May 17, 2010 04:26 PM
