Old Oct 08, 2012, 09:52 PM
szewang2805 is offline
Find More Posts by szewang2805
Joined Dec 2006
Cool
Only USD98.9 SKYRC Proteus Water Cooled X520 730KV 1280KV Brushless Motor for Marine
Proteus Series Motors are designed for large scale rc boat (1.5-2m length).
The revolutionary design of Proteus motors is its unique wire configuration. There are six connectors on the motor and the user can switch the wire configuration (wire or triangle) by themselves at any time. When the user requests the motor with more RPM and high speed, he could use triangle configuration; when the user request the motor with more torque and power, he could use star configuration,. In this case, one piece of motor can meet the user's request for speed or power in different situation.
What's more, there is water cooling shell outside of the motor. It is designed to cool down the motor temperature so that the motor could perform best.
These motors can be switched between STAR and TRIANGLE with configuration.
There are 6 connectors on the motor.
Triangle Configuration=More RPM
Star Configuration=More Torque
Specifications
X520 3Y System
Watts: 5280W
Max Voltage: 41V
Max Amps: 128A
Resistance: 0.0132
KV (RPM/volt): 730
Max RPM: 30000
Length: 102mm
Diameter (w/fins): 55.8mm
Weight: 925g
Shaft Diameter: 8mm
Length of extend shaft: 30mm
X520 3D System
Watts: 5280W
Max Voltage: 23V
Max Amps: 229A
Resistance: 0.0046
KV (RPM/volt): 1280
Max RPM: 30000
Length: 102mm
Weight: 925g
Shaft Diameter: 8mm
Features
High Quality Bearings
Rotor - 4 Pole Neodymium Magnets
Stator- Super Thin Laminations
Super Strength 8mm shaft
With Water Cooling Shell
6 Connectors
2 Wire Configuration-Triangle & Star
http://www.hobbyhot.com/SKYRC-Proteu...ine-IM680.html
szewang2805 is offline Find More Posts by szewang2805
Reply With Quote  (Disabled)
Cool Only USD111.9 SKYRC Proteus Water Cooled X524 600KV 1050KV Brushless Motor for Marine szewang2805 Product Announcements 0 Sep 23, 2012 10:42 PM
Cool Only USD111.9 SKYRC Proteus Water Cooled X524 910KV 1580KV Brushless Motor for Marine szewang2805 Product Announcements 0 Sep 23, 2012 10:38 PM
Sold Brand new Aquacraft 60amp water cooled brushless lipo Esc (marine) williebro Boats (FS/W) 1 Aug 09, 2012 04:12 AM
Discussion Turnigy AquaStar 3973-2200KV Water Cooled Brushless Motor wet banshee Racing Boats - Electric 5 Jun 08, 2012 01:52 PM
Sold Astro Flight Super Ferrite Marine 40 Low hours w/ Water Cooled Marine Motor Mount kelleysislande Boats (FS/W) 2 Jan 29, 2012 08:16 AM
