Old Sep 22, 2012, 08:45 AM
PA44Capt is offline
Find More Posts by PA44Capt
PA44Capt's Avatar
Joined Jan 2009
DA-60 popping question
Hey guys, I have a new DA-60 that I'm running on a test bench right now because I cannot run it in the airplane yet. I am aware of the risk of overheating on the bench and have been very careful with an IR gun to monitor cylinder temps and stay below 300.
I have read the newbie guides to setting up gas and they've been very helpful but I can't seem to find a clear answer to this question.
Here is a video of the engine running at approximately 1/3 throttle.
Now, at this point I had tuned the high end with a tach (around 7,000) and the low end for good transition. I'm sure the needles aren't perfect yet.
Here's my question, is the popping/missing that you hear in this video:
A. Normal, quit worrying about it they all do that.
B. Needle valves not adjusted right.
C. Not broken in yet (there's about 3/4 gal through it now)
D. Other or combination
All of the newbie guides and stuff go through how to setup and adjust the engines etc but none seem to really address this issue. Thanks in advance for your help.
PA44Capt is offline Find More Posts by PA44Capt
Old Sep 22, 2012, 10:07 AM
ahicks is offline
Find More Posts by ahicks
United States, FL, Citrus Springs
Joined Aug 2008
Does it still have the plug that came with it installed? If so that's where I'd start...
If you've already replaced the plug, I'm not a firm believer in screwing with these things on the ground much beyond the basics you say you've done. Not because of the heating issue, but because I think it's a waste of time? You're going to be tweaking ANYTHING you do on the ground once it's in the air anyway? No matter how careful you are. Ground tuning is just to get you close once airborne? That's just me/my opinion though... -Al
ahicks is offline Find More Posts by ahicks
Old Sep 22, 2012, 10:31 AM
PA44Capt is offline
PA44Capt's Avatar
Joined Jan 2009
Normally, I would fully agree with you about the flying vs ground situation. Unfortunately, I can't fly this engine right now because the UAV project it will be powering isn't in the same state as myself.
I did use the plug it came with because its an NGK CM6 which is what we all seem to go to on these engines. I know the DLE plugs are junk but this one should be good.
What do you think of the popping?
Old Sep 22, 2012, 11:47 AM
ahicks is offline
Joined Aug 2008
I think it would make me crazy as well, but would like to know if it would still be doing that in the air?
It sounds like ignition, but Ive been around these things long enough to know that doesn't mean much. Do you have it on 4.8 volts? Double checked for sure? Do you have another ignition module you can swap it out with? I'm just guessing, probably don't know much more about it than you do at this point. -Al
Old Sep 22, 2012, 02:46 PM
PA44Capt is offline
PA44Capt's Avatar
Joined Jan 2009
I'm certain the pack was charged and it's a 4.8v nimh so that should be fine. The ignition is a brand new module. I know they can be bad out of the box but my gut says that isn't it...
Discussion 89" 3DHS Slick 540 With DA-60 Windy 3D WithTrollR/C frivilousteamrc 3D Flying 0 Jul 15, 2012 12:47 PM
Sold DA 60! Fresh from DA hercdriver7777 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 19, 2012 06:12 PM
Sold DA-60 with MTW 75K canister flymustangs Aircraft - Fuel - Engines and Accessories (FS/W) 1 May 28, 2012 02:19 PM
Sold Low Time DA-60, MTW Headers, MTW TD75's, Pitts Style Muffler for DA-50, Ignition Cut FL62 Aircraft - Fuel - Engines and Accessories (FS/W) 10 May 25, 2012 01:02 PM
Sold Vess Balance Ring - 50cc - fits DA 50/60, DLE-55 6L6Amp Aircraft - Fuel - Engines and Accessories (FS/W) 2 Apr 06, 2012 09:32 AM
