Old Aug 22, 2012, 12:45 AM
slidins15 is offline
Find More Posts by slidins15
Australia, NSW, Wollongong
Joined Aug 2011
Build Log
Rise Above Aerials Carboncore 1000 Octo build
Here is the build log for a CarbonCore 1000 Octo that I am building. I offer build services through my website Riseaboveaerials.com.
Check out my carboncore quad and hexa build logs also
Components:
DJI electronics
Carboncore frames
T-motor 2814-11
11" wood props (maybe use 12")
DYS 40A simonk flashed esc
When building it, I kept a few things in mind:
1. Cleanliness: where possible I keep all escs and wiring between the two main plates to keep the build looking nice and clean, while still allowing the frame to fold. All esc's are oversized to help with cooling. It is worth noting that so far it seems this can only be done when using aftermarket landing gear, as the carboncore gear mounts where you would likely put all your electronics. I am planning to use an Askman landing gear and gimbal on this frame; they are awesome.
2. redundancy in batteries; I have wired the two power boards together, as well as having a battery for each board. This still allows both boards to be powered by one battery in case of battery failure.
Here is the power board all wired up, using voltair power boards. 4 escs per board, wired up like an X quad. In case a board fails, the remaining 4 motors will be spinning as an X quad format; this should stop it falling from the sky like a brick.
Here is the bottom plate wired up with all escs, and the power boards. I cut the standoffs shorter to fit 2 powerboards in between the centre plates. The powerboard was insulated from the carbon fibre before I put the top plate on.
will update the post when I receive my replacement Wookong MC and finish the build
slidins15 is offline Find More Posts by slidins15
Old Aug 22, 2012, 08:37 AM
Joined Aug 2011
Ok so I received the replacement DJI eletronics this afternoon and installed them all. Basic wookong setup with addition of a data link for waypoint control.
Spektrum ar8000 receiver & telemetry module are only mounted temporarily for now.
Also yet to mount the remaining 4 arms of the top crash cage to allow ease of access to electronics.
I'll post up a video once I've done the test flight
And here is where it all comes together:
Old Sep 18, 2012, 06:38 AM
Joined Aug 2011
Now just waiting on the landing gear and camera gimbal. Here is the flight video:
Riseaboveaerials CarbonCore Octocopter (1 min 53 sec)
Old Feb 20, 2013, 11:52 AM
zagimon is offline
Find More Posts by zagimon
Patrick Jenkins
USA, LA, 5
Joined Dec 2006
Hey man...like your setup..is it still working well for you? About to build a heavy lift rotor and am gonna use the same frame.
zagimon is offline Find More Posts by zagimon
Old Feb 20, 2013, 06:42 PM
Joined Aug 2011
yep I'm really happy with the frame. Was having issues with the motor mounts being too thin but they have upgraded them on the newer frames.
Still haven't gotten a camera gimbal on it yet, but that is coming soon!
Build Log Rise Above Aerials CarbonCore 500X4 Quad Build slidins15 Multirotor Talk 1 Aug 22, 2012 12:44 AM
Build Log Rise Above Aerials CarbonCore Hexa 650 build slidins15 Scratchbuilt Multirotors 3 Aug 20, 2012 09:13 PM
Discussion Rise Above Aerials Carboncore 1000 Octo build slidins15 Scratchbuilt Multirotors 2 Aug 20, 2012 08:31 PM
Gallery CarbonCore Multicopters Octo Quad Carbon Core Aerial Photography 5 May 25, 2012 06:45 AM
