Old Jun 18, 2012, 09:04 AM
doc-e is offline
Find More Posts by doc-e
Live to fly!
doc-e's Avatar
United States, NJ, Fair Lawn
Joined Nov 2002
Question
Recommendations for a motor for Kyosho fan
Hi guys,
I have an old Kyosho Learjet with two 75mm stock Kyosho fans. I used to fly it on two Mega 16/15/2 motors with two 2S packs. It flies ok, but I was hoping to get some more power. Can you recommend a good alternative that would run in the Kyosho fan on a 3S pack (3S is too much for the Mega 16/15/2)? I have a Kontronic 400-36 in my Kyosho F-16 and that flies great, but I can't afford two new Kontronics. Mega 16/15/3 is a possibility, but they are hard to come by these days. What else is out there?
Thanks in advance.
Doc
doc-e is offline Find More Posts by doc-e
Old Jun 18, 2012, 09:46 AM
juliant is offline
Find More Posts by juliant
Julian T
Fleet, UK
Joined Jun 2005
The 16/15/2 is ok on 3s in a 70mm fan but you are probably correct that the Kyosho unit might be pushing it a bit too far. Since you have the motors though it might be worth seeing what the figures are just in case. The 16/15/3 is ok on 3s but not quite hot enough in a 70mm fan - so might be good in the Kyosho one. The 16/15/3 is too hot for 4s though imo. They are still easily available over here. Het do a number of motors in various winds and can lengths one of which would probably suit you - Mega rip offs and not the same quality but they do what is needed.
Julian
juliant is offline Find More Posts by juliant
Old Jun 18, 2012, 01:58 PM
abenn is online now
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
I fly my Kyosho LearJet on Wemotec mini fans with Mega 16EDF motors powered by two 3S 3900mAh LiPos in parallel. Gives me almost 150 watts/pound. A far cry from the original Kyosho setup with 7-cell 2000mAh NiCd batteries!
abenn is online now Find More Posts by abenn
Old Jun 18, 2012, 09:43 PM
Bruce Abbott is online now
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
The HET 3W is a good substitute for the Mega 16/15/3.
Bruce Abbott is online now Find More Posts by Bruce Abbott
Old Jun 19, 2012, 08:11 PM
doc-e is offline
Live to fly!
doc-e's Avatar
Joined Nov 2002
Julian
I tried the Mega /2 on 3S in the Kyosho fan. I went to full throttle (maybe not even) for a second, and it registered 56A, so I immediately shut it down. The /2 is rated only for 35A, so 3S is out of the question. I wonder if anyone knows the numbers for Mega /3 on 3S in a Kyosho fan.
Thanks for your input Julian!
Old Jun 19, 2012, 08:13 PM
doc-e is offline
Live to fly!
doc-e's Avatar
Joined Nov 2002
Bruce,
Is the 3W a direct substitute for Mega 16/15/x, i.e. is the motor diameter and shaft diameter the same?
Doc
Old Jun 19, 2012, 08:59 PM
Joined Jan 2001
Yes.
Old Jun 19, 2012, 09:50 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Suggest this one:
http://www.hobbyking.com/hobbyking/s...eli_Motor.html
Cheap and Proven to be a very good, simple EDF motor
Bare is offline Find More Posts by Bare
Discussion Recommend Replacement Motor for 55mm Fan Set... KenS999 Electric Ducted Fan Jet Talk 5 Aug 08, 2010 12:32 AM
Help! What can I build or buy for Kyosho Illusion Fan and motor setup? rebec Foamy EDFs 6 Jul 08, 2008 10:54 PM
Kyosho F16 Motor/Fan For Hand Launch? Joe Elston Electric Ducted Fan Jet Talk 84 Apr 23, 2004 12:16 PM
Kyosho AP 29L Fan With Motor For Sale mirageman2005 Aircraft - Electric - Airplanes (FS/W) 1 Apr 16, 2003 03:07 AM
WTB: Astroflight Brushless 05 805K Motor for Kyosho F-16 Ducted Fan tvilling1 Aircraft - Electric - Airplanes (FS/W) 0 Jan 09, 2002 06:06 PM
