Old Feb 22, 2013, 03:13 PM
Thumb Blisters is offline
Find More Posts by Thumb Blisters
Thumb Blisters's Avatar
Joined Nov 2012
Can anyone tell me a good prop and prop adaptor for the beast 3d motor? I have it in my mx2 and don't lime the stock prop.
Thumb Blisters is offline Find More Posts by Thumb Blisters
Old Mar 01, 2013, 09:39 PM
3flyguy3 is offline
Find More Posts by 3flyguy3
3flyguy3's Avatar
United States, IL, Waukegan
Joined Apr 2012
2S JST-PH connector?
Is there an adapter I can get so I can charge/discharge 2S lipos with the JST-PH connector (UMX series) with my Thunder AC6? Or am I stuck using the Eflite charger and have to suffer charging one at a time?
3flyguy3 is offline Find More Posts by 3flyguy3
Old Mar 03, 2013, 07:37 PM
tomcor is offline
Find More Posts by tomcor
Battery Powered==(*)==
tomcor's Avatar
Mesquite, Nevada
Joined Jan 2002
Check rcconnectors website. Or make an adapter yourself.
tomcor is offline Find More Posts by tomcor
Old Mar 04, 2013, 07:21 AM
3flyguy3 is offline
3flyguy3's Avatar
Joined Apr 2012
Mini MX2 with AS3X guts
Got wings hinged and some paint. (tip: don't rush on your paint job, you'll get overspray and lines that don't meet). Hopefully should be installing gear tonight. May even install cf in the elevator.
Old Mar 17, 2013, 10:05 PM
chaz4jc is offline
Find More Posts by chaz4jc
Just one more landing, okay?
chaz4jc's Avatar
United States, UT, Hooper
Joined Jun 2012
Hobby King sells one that parallel charges 6 batteries at a time.
http://www.hobbyking.com/hobbyking/s...2S_Lipoly.html
chaz4jc is offline Find More Posts by chaz4jc
Old Mar 18, 2013, 04:22 AM
Steve Percifield is offline
Find More Posts by Steve Percifield
Noblesville, Indiana
Joined Jan 2005
Hey guys, how are the tiny servos you are using in the mini's ( the ones FF sells in their package) holding up using 2 cells? HK"s website says they are single cell, 5 volts max>>
Steve Percifield is offline Find More Posts by Steve Percifield
Old Mar 20, 2013, 03:36 PM
chaz4jc is offline
chaz4jc's Avatar
Joined Jun 2012
For the adapter go to Shapeways:
http://www.shapeways.com/model/30591...ductBox-search
It's bullet proof almost...
5030 prop works well. I am working on a way to modify the Shapeways part to make a prop saver out of it- I will post pictures.
Old Apr 08, 2013, 04:55 PM
chaz4jc is offline
chaz4jc's Avatar
Joined Jun 2012
After an unavoidable week-and-a half visit to NYC for work, I finally got to sit down on a rainy day and finish painting and assembling my Mini MX2.
Thanks, Mike for helping out with lost parts! Radio and gear tonight when the glue is dry!
Old Apr 13, 2013, 10:50 AM
motorhead is offline
Find More Posts by motorhead
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Got back from the Toledo show this week. The Mini kits were a big hit. It motivated me to get the paint templates done for the MX2. They are now on the site painted. The Fenix will be done soon but first I am working on a Mini version of the Raptor.
motorhead is offline Find More Posts by motorhead
Old Apr 14, 2013, 04:51 PM
chaz4jc is offline
chaz4jc's Avatar
Joined Jun 2012
Gear installed on the Mini MX2:
Spektrum SPMAS6410NBL receiver w/ AS3X
2030LO servos on ailerons
2030L servos for rudder and elevator
180 BL 3000kv motor
5030 prop
home made prop adapter/prop saver
nano-tech 300 2S
Maiden flight was a blast! Plenty of power, vertical snaps straight on up. Stable as can be with the AS3X. I bought the USB plugin programmer and downloaded the full software for it so I can tune it a little if I need to, but it also allowed me to set up to turn AS3X on and off with channel 5. Second landing cracked the propeller on one side and that blade departed on the third launch. Today I fabricated a prop saver out of the hub of the broken propeller. I will post pictures of it next.
Old Apr 14, 2013, 05:06 PM
chaz4jc is offline
chaz4jc's Avatar
Joined Jun 2012
Eflite 180 prop saver/prop adapter.
After breaking a prop on the maiden of my Mini MX2 and not being able to find a prop saver for the E-flite 180 motors, I decided to fabricate my own. I took the hub of the broken propeller, cut off the blades, center drilled it through in four steps from 1/32" to 7/64". Then I tapped it to #6x32 threads and epoxied it onto a UMX Beast prop adapter so that about 1/16" sticks out of the front to act as center pin for the propeller. Then I used blue thread lock to hold 2 #6-32 x 1/4" electrical face plate screws in place for the retainer o-ring to fit around. A 3/4" Viton o-ring does the trick well.
Old Apr 15, 2013, 12:06 PM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Good idea on the prop saver.
Old Apr 15, 2013, 11:12 PM
chaz4jc is offline
chaz4jc's Avatar
Joined Jun 2012
Thanks, I am going to have one of my CAD wizard friends draw this up for me and try to 3D print it on Shapeways.
Old May 05, 2013, 03:46 AM
GoAround is offline
Find More Posts by GoAround
Can't fly 3D for toffee ...
United Kingdom, Taunton
Joined Dec 2012
180 BL 3000kv motor
5030 prop
nano-tech 300 2S
Chaz, Thanks for your post on the CC thread. This looks like the guts of a CC. How are you dealing with the offset aileron servos?
GoAround is offline Find More Posts by GoAround
Old May 08, 2013, 04:32 PM
chaz4jc is offline
chaz4jc's Avatar
Joined Jun 2012
The flat wing mini needs the offset servos to keep yaw under control in a roll. The down aileron creates more drag than the up aileron in a turn. When you build the bigger versions of the Fancy Foam kits they include or recommend an offset servo horn.
Sold NEW Fancy Foam Andrew Jesky Blender BIPLANE wolfcbr2003 Aircraft - Electric - Airplanes (FS/W) 11 Mar 14, 2012 06:13 PM
Sold ... cam17 Aircraft - Electric - Airplanes (FS/W) 1 Feb 29, 2012 10:43 PM
Wanted UMX guts for micro beast TMAC4123 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Feb 29, 2012 05:36 PM
Sold SOLD - Fancy Foam Vrolet V1 F3P 3D kit with servos - $45.00 Shipped and Insured. GTMAXX Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Feb 29, 2012 09:28 AM
Question Looking for build for Fancy Foam Sbach 1.3 dan n 3D Foamies 1 Jan 07, 2012 06:09 PM
