Old Mar 30, 2012, 03:32 AM
djdavies83 is offline
Find More Posts by djdavies83
We can rebuild it!
djdavies83's Avatar
United Kingdom, Wales, Swffryd
Joined Apr 2010
Ifsorry you got done there airgus, if you happen to have some S107 or othe coax guts about I would say it may be worth trying another PCB, ok ther would be no roll or pitch controll but if your are able to take of and go up n down without spinning it would prove the mothers what's and gears are good.
Does anyone know if these have the same motors asthe S107?
Edit, have you check that the shafts are not slipping on the grars? With these gyro birds if one gear is slipping the gyro will restrict power to the good motor and shaft to stop it from spinning out of control.
djdavies83 is offline Find More Posts by djdavies83
Old Mar 31, 2012, 12:35 PM
Kurt is online now
Find More Posts by Kurt
Upstanding Member
Kurt's Avatar
United States, TX, Houston
Joined Sep 2003
Yes - same physical dimensions at least.
I got a PM asking how to adjust the swash linkages for more throw. See photo below - after popping the 2 canopy-posts off and removing it off the front, carefully pop the ball-links off the swash, and move the lower ends forward to the second hole. The third hole on the servo 'horn' is too large for the links, so I don't know why they are even there, but it's conceivable that you could drill/burn a tiny hole for moving the swash links even further out. Not sure that the swash wouldn't bind, but might be fun to try.
Kurt is online now Find More Posts by Kurt
Old Mar 31, 2012, 03:40 PM
gimps777 is offline
Find More Posts by gimps777
Joined Mar 2012
Thanks Kurt! in the time i spent waiting for you to respond to the above ( not mad about that) i ended up popping off the heli engine cover and figuring this out... my only screw up was i didnt check the label on the bladesvas since my fingers were so long i found it easier to take off the blades. Fun when i had to figure out the numbers were in the wrong area and when i tried to lift the heli just sat there full throttle lol..
gimps777 is offline Find More Posts by gimps777
Old Apr 02, 2012, 10:51 AM
Kurt is online now
Upstanding Member
Kurt's Avatar
Joined Sep 2003
Lightlake posted this link for $26 shipped over in the micro-heli forum :O
http://lightake.com/detail.do/sku.Sy...ro_White-51484
Old Apr 02, 2012, 05:38 PM
Airgus is offline
Find More Posts by Airgus
Airgus's Avatar
Joined Nov 2010
I checked, shafts are not slipping on the gears.
Airgus is offline Find More Posts by Airgus
Old Apr 06, 2012, 06:54 AM
We can rebuild it!
djdavies83's Avatar
Joined Apr 2010
Hey Kurt, have you seen they are usin your video review on the product page?
They given you anything for that?
Old Apr 06, 2012, 05:46 PM
Kurt is online now
Upstanding Member
Kurt's Avatar
Joined Sep 2003
heh thanks for the heads-up dj. No they didn't even ask for my permission, or give me any credit.
Have added a little note the beginning of the video
Now if they'd like to fly me to China as a "consultant" I'd be more than happy to work with them on future videos
cheers!
Old Apr 07, 2012, 07:27 AM
scotsoft is offline
Find More Posts by scotsoft
Master Of My Universe
scotsoft's Avatar
Newcastle, UK
Joined Jul 2010
cheers!
Nice footnote, I wonder if they will actually notice it though
scotsoft is offline Find More Posts by scotsoft
Old Apr 08, 2012, 04:38 PM
IceRail is offline
Find More Posts by IceRail
We NEED a LiPo w a USB plug!!!
IceRail's Avatar
Orland Park, Illinois
Joined Feb 2010
Oh why not,... I'll try one. The guys in the Syma 107 thread made me do it!
I haven't used Lightlake yet (just registered two minutes ago).
How are they (Lightlake) on a scale of 1 to 10 ("1" being AVOID at all costs! / "10" being Tier One Seller! ) with::
1. - Speed ?
2. - Communications (especially if there's a hang-up)?
3. - Packaging ?
IceRail is offline Find More Posts by IceRail
Old Apr 09, 2012, 05:35 PM
Kurt is online now
Upstanding Member
Kurt's Avatar
Joined Sep 2003
Sorry don't know anything about their service, but thanks to youtube's analytics I do know that only 38 people viewed my video on their site in the past week
Good luck with yours - I'm running out to the hobby store now for supplies and will pick up some plastic tube to glue inside old metal sticks for longer controls. Should help with the craptastic TX resolution a bit...
Old Apr 10, 2012, 09:43 PM
talktodan is offline
Find More Posts by talktodan
Joined Dec 2004
I took apart the controller to see how tough it would be to de-solder and swap the rudder and aileron. I'm sure it can be done, just above my pay grade. Would need to also re-wire the rudder trim.
Kurt, It's actually not bad. The trim is independent so you don't have to mess with that circuit. It's just a matter of cutting two traces and addind two wires. I'll post some pics either tonight or tomorrow morning. It now feels normal with this mod.
-Dan
talktodan is offline Find More Posts by talktodan
Old Apr 10, 2012, 10:58 PM
Kurt is online now
Upstanding Member
Kurt's Avatar
Joined Sep 2003
-Dan
Dan - that would be great! I'd love to see pics of how you do this.
I tried patching in an old Walkera controller's pot with 3 leads on the bottom of the S800g's PCB so I'd have higher quality, higher precision controls but it didn't work. Can you tell I'm a mechanical engineer, not an EE :P
I did replace the stock plastic 'button' sticks with longer, metal ones from the Walkera controller. This helps a LOT in smoothing out the aileron and throttle control. Converting it to mode 4 (and beefing up the tx's exterior to better fit my hands) will make this a truly excellent little indoor 4-ch package.
cheers!
Old Apr 11, 2012, 12:38 AM
Joined Dec 2004
cheers!
I'm also an ME, or at least hope to be after this May
It was hard to get good pictures in low light (camera phone), but I think you should still be able to see the modifications. I cut two traces as seen as red lines and soldered the two wires where the blue circles are. I had to scratch off the green masking on one spot to apply solder onto the trace.
-Dan
Old Apr 11, 2012, 03:05 AM
We can rebuild it!
djdavies83's Avatar
Joined Apr 2010
I dropped into my local Modelzone test day and was aloud to "play with" S800 and the missile firing Udi helicopter, now I can really see exactly what everyone who has this shape of Tx has been talking about, them tiny little sticks! The open door, the aircon and the rudder and aileron being te wrong way round didn't help either, I may get one from lightake at some point (they were reasonably quick at sending my iPhone S107 Tx dongle and charger) but I'm in no hurry for a S800.
The Udi missile heli was very smooth and responsive, personally I think I would get one of them first, shame they lost all the missiles.
Old Apr 11, 2012, 12:09 PM
Kurt is online now
Upstanding Member
Kurt's Avatar
Joined Sep 2003
Dan - thanks much for the pics and description.
Darned good close up pics for a phone IMO!
How do you 'cut' a trace? Just scratch through the green insul and conductor to 'break' the circuit?
Going to give it a try.
Good luck with school, tough road but so worth it!
open door, aircon? eh?
Discussion F106 4ch inexpensive coaxial Melnic Coaxial Helicopters 11 Jan 11, 2012 04:39 PM
Help! 4ch coaxial beginner help please Rusty Old Fart Coaxial Helicopters 5 Nov 24, 2011 10:06 AM
Discussion Esky Nano 4ch coaxial. Melnic Micro Helis 3 Aug 01, 2011 01:19 AM
Discussion Large Size 4ch Coaxial??? eviljack Coaxial Helicopters 11 May 21, 2011 10:56 AM
Discussion 4CH Sub Micro Coaxial: Converting a 3CH to 4CH EQMOD Coaxial Helicopters 6 May 02, 2009 10:06 AM
