Old Dec 17, 2009, 01:04 PM
gotsol is offline
Find More Posts by gotsol
slow builder :D
gotsol's Avatar
Dannstadt, Germany
Joined Nov 2009
Question
what to do with a burned Spektrum 5in1 reciever ?!
Hi there...
i just burned a 5in1 Unit from my Blade mSR ( not a airplane, its a mirco heli )
and im angry with puttin this into the basket..
and in that 5in1 unit, obv only damaged the channel for the rear fan,
so i have 2 working servos, and 1 working motor speed controller..
so i came on the idea, that i can build a little fly, like that "Parkzone Vapor" thing... or something similar on foam..
so my question is, cause im new to this hobby..
is it possible to build something with this unit ?
or ist it impossible cause it is for helis not for planes ?!
should be less expensive if im right here ?!
maybe someone have some already done plans or story to this..
i saw some plans out there for foamies, but i search something smaller
that vapor is nice in size, and should fit my flyarea in my livingroom..
and i only got 3 channels.. not 4 .. so no (ailearon=?!) like that on the plans i saw
gotsol is offline Find More Posts by gotsol
Old Dec 17, 2009, 02:46 PM
thewildweasel is offline
Find More Posts by thewildweasel
Beware the Axis of Weasel.
thewildweasel's Avatar
Plymouth, Devon
Joined May 2007
You can do ailerons with the linear servos, just use a servo horn bolted to a piece of ply as a bellcrank. Your brick will be fine for a plane though you may have to play around with aligning it as it has a gyro.
thewildweasel is offline Find More Posts by thewildweasel
Old Dec 17, 2009, 03:05 PM
gotsol is offline
slow builder :D
gotsol's Avatar
Dannstadt, Germany
Joined Nov 2009
should i use the 2 servos to do aileron and lift ? or to do aileron and turn ?
sry for dump questions.. just dont know what is more effectiv
cant imangine how to use the servos, but i think i have understand what you mean with that servo horn as a bellcrank .. makes sense..
but how to make the lift off ? over the rear wing ?
Old Dec 17, 2009, 07:36 PM
ender707 is offline
Find More Posts by ender707
ender707's Avatar
Sacramento, CA
Joined May 2009
You can buy the 5in1 unit by itself, and then your heli will be alive again. That is probably your best option. Trying to make it in to a plane will most likely cost more money in the long run.
The 5in1 unit is sortof expensive at ~$59.99 and is available at:
http://www.redrockethobbies.com/E_Fl...p/eflh3001.htm
or at:
http://www.horizonhobby.com/Products...rodID=EFLH3001
Are you sure it is your 5in1 unit that went bad? Or is it possible that your tail motor just burned out? The reason I ask is that the replacement tail boom w/motor/prop on it is only ~$14.99 at both of the websites I just linked.
ender707 is offline Find More Posts by ender707
Old Dec 18, 2009, 06:15 AM
gotsol is offline
slow builder :D
gotsol's Avatar
Dannstadt, Germany
Joined Nov 2009
or at:
Thanks for your Help..
but i have already tested the tail two ways 1) directly plugged to the lipo, and 2) connected to the Mainmotor port on the 5in1.. both work well..
And i already have ordered a new 5in1 for my mSR...
but thats the topic, dont want to dump the old one, and search a function for it, this is why i ask for help to build a small plane..
i never would put my msr in the basket its to lovely
but atm i wonder.. i ordered the new 5in1 in a german shop, and it still isnt here (i live in germany) a way long shipping for national...
so im still intressted in finding a way to put my 5(4in)in1 in something with wings
best regards
Alex
Old Dec 18, 2009, 02:27 PM
gotsol is offline
slow builder :D
gotsol's Avatar
Dannstadt, Germany
Joined Nov 2009
wich motor should i use on this 5in1 ? any advices here ?
i just want to build a micro plane with ~ 25" wingspan
Old Dec 18, 2009, 05:39 PM
Plymouth, Devon
Joined May 2007
Try www.flying-kit.com for a 7mm which produces a good 30g of thrust (I've tested this myself), of if you want more power get the gears and motor from a pz P-51, that gives about 40g.
Old Dec 19, 2009, 10:37 AM
mickgunn is offline
Find More Posts by mickgunn
Joined Aug 2007
Hi from Mick
I used one of these receiver blocks in a micro plane with no problems & as there is 2 motor speed controllers the plane I made was a micro cessna bobcat style with one motor in the nose & one in the tail.
So use the receiver it should be O.K
mickgunn is offline Find More Posts by mickgunn
Old Dec 20, 2009, 05:27 AM
gotsol is offline
slow builder :D
gotsol's Avatar
Dannstadt, Germany
Joined Nov 2009
okay i think i found a beautiful very small plane for me..
so cuuute..
but take look for your self
http://www.modellbau-ramseyer.ch/cub...od&productId=6
or
(the one in the lower right corner)
now just have to find a fittin motor
some advices here ? are 10g thrust a little much ? or is this fine..
wingspan is about 10"
overall weight should something about 25g if im right..
im very thankfull for any tips where to buy the motor, and if the shop have the fittin motor to this would be more fine, cause of the savin shippin costs
Old Dec 20, 2009, 05:49 AM
Plymouth, Devon
Joined May 2007
Bit of a problem with your choice I'm afraid these are 3D models and have been designed with a better than 1:1 power to weight ratio in mind so 10g of thrust would most likely barely drag them to the ground I'm afraid, 3D planes are designed to be draggy so they fly slowly.
I don't understand German I'm afraid, not even the Swiss version, but you'd be after a motor that can provide 30g of thrust or more. Have a look at www.flying-kit.com, they sell 7mm pager motor/gearboxes, I've got two and they give over 30g of thrust on a regular 70mAh minium cell so should give more with a higher capacity lipo. Postage from this site is a little slow (2 weeks) but as it's free I can live with that.
As an alternative, have a look in the scratchbuilt foamies section, there's a thread called 'free plans', a guy called chris3d designed a really nice Pitts Special that would work with your gear, I've built several ranging in size from the original 30cm, up to 60cm and down to 15cm and all have been great little planes. It was designed for balsa so the fuse is in two halves but if you make it out of foam you can join the turtle decks behind the cockpit and save yourself a glue joint.
Old Dec 20, 2009, 08:01 AM
gotsol is offline
slow builder :D
gotsol's Avatar
Dannstadt, Germany
Joined Nov 2009
your site dont have my beloved plane.. so i decided to search a bit longer..
u talk from 30g thrust...
if i understand this right...
THIS MOTOR should have enough thrust with THIS PROPELLERS or isnt this what is required in the specs... am not sure here...
best regards.. and thank you very much for help
PS: forgot to say.. i already own some 130mAH lipo and 240 mAH lipo
Old Dec 20, 2009, 09:46 AM
Plymouth, Devon
Joined May 2007
That's the same motor, just a bit more expensive. Robotbirds did have the donuts micros but i don't know if they have any left.
Old Dec 20, 2009, 10:25 AM
gotsol is offline
slow builder :D
gotsol's Avatar
Dannstadt, Germany
Joined Nov 2009
yeah they have..
ok i this setup fits, i'll order
let's see how i build that small plane
ok forget a question here...
did i need that esc ? i dont think so cause it should ne in my spare already ? am i right here ?
Old Dec 20, 2009, 10:31 AM
Plymouth, Devon
Joined May 2007
E-mail them about the P&P for the nano planes, the guy in the local model shop bought one and paid a lot less for the postage than their standard kit shipping fee.
Nice looking litle plane in the flesh, though they come with no instructions and the foam can be quite badly bent. Do a search and you'll find some methods for straightening it, as well as the build instructions.
Old Dec 20, 2009, 10:43 AM
gotsol is offline
slow builder :D
gotsol's Avatar
Dannstadt, Germany
Joined Nov 2009
did i need that ESC OR is one in the 5in1 i already got ?
sry for asking holes in your stomach
im so thankfull you helpin me
Discussion Help with FPV Setup: I got the RX, reciever, and Camera, now what? ColbySTS FPV Talk 2 Dec 05, 2009 08:54 AM
Sold spektrum dx2.0 with reciever JASON671 Cars - Accessories (FS/W) 1 Nov 11, 2009 04:26 AM
Question What do you do with your old stock gear? Vok_250 Electric Ducted Fan Jet Talk 1 Oct 12, 2009 05:03 PM
Discussion Large heli flyers. What else do you do with your free time? Greybird Large Electric Helis 22 Sep 14, 2009 08:26 PM
Idea What do you do with your burned up 4 in 1? chuter1 Coaxial Helicopters 9 Apr 24, 2007 08:50 AM
