Old Jul 17, 2014, 12:19 PM
The Willamette Valley, Oregon
Joined Dec 2008
Turn coordination esoterica
Never mind, there was an error in my thinking. A slip-skid ball far ahead or far behind the "tangent point" between the fuselage and the curving path of the turn will be less sensitive to the centrifugal force acting on it (compared to a slip-skid ball at the tangent point), because it is not aligned parallel to the turn radius as seen from above. But at the same time, it has more centrifugal force acting on it (compared to a slip-skid ball at the tangent point), because it is describing a larger turn radius than is the point on the fuselage that is tangent to the curving flight path. If I did my trig right it all washes out-- a slip-skid ball or bubble level located at the nose should read the same as a slip-skid ball located at the tail, no matter whether the "tangent point" between the fuselage and the curving flight path is located near the nose, near the tail, midway between, far ahead of the nose (skid), or far behind the tail (slip).
There still is some justification for allowing a slight slip as measured by the ball, and a significantly larger slip as measured by a yaw string at the nose.
Steve
aeronaut999 is offline Find More Posts by aeronaut999
Discussion Coordinated Turn? Electromagnetic Modeling Science 45 Jul 20, 2014 12:58 PM
Discussion Coordinated Turns SuperCamel UAV - Unmanned Aerial Vehicles 4 Nov 11, 2013 08:59 AM
Discussion Coordinated Turns - I Hate to Admit Being Wrong Leo L Electric Warbirds 10 Oct 28, 2013 12:36 PM
Coordinated Turn strouse Electric Plane Talk 7 Jul 21, 2003 11:30 PM
What the heck is a "coordinated turn"? Tim K Electric Plane Talk 18 May 14, 2002 04:30 PM
