This thread is privately moderated by JimDrew, who may elect to delete unwanted replies.
Old Jun 18, 2014, 04:43 PM
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Using Nano with Serial Link to emulate the XDP
If you have a spare Nano and the Serial Link, you essentially also have our XDP hardware. Using these two devices you can fool any of our programs that use the XDP hardware into thinking that a real XDP is present. To use the Nano and Serial Link as an XDP, do the following:
1. Connect the Serial Link to your USB port.
2. Connect one end of a JR female-female cable to the Serial Link, noting the proper polarity.
2. Place the jumper on the binding port of the Nano.
3. Plug the other end of the JR female-female into output port 6 on the Nano, noting the proper polarity. The LED will rapidly flash.
4. After a second or so of the LED rapidly flashing, remove the jumper that is on the binding port. The LED on the Nano will now be solid red.
5. Place the jumper back on the binding port (and leave it on). The LED will rapidly flash 10 times and then turn solid red.
That's it! Now your Serial Link/Nano combination is a XDP! This of course is not permanent. Removing power will return the devices back to their original purpose.
JimDrew is offline Find More Posts by JimDrew
Old Jun 18, 2014, 08:17 PM
joshgluck's Avatar
United States, NJ, Middletown
Joined May 2012
Schweet
joshgluck is offline Find More Posts by joshgluck
Old Jun 18, 2014, 09:40 PM
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
You should make this a Sticky
GBR2 is offline Find More Posts by GBR2
Old Jun 18, 2014, 11:06 PM
Lake Havasu, AZ
Joined Jun 2005
Done!
Old Jul 19, 2014, 11:19 AM
United States, IL, Salem
Joined Apr 2011
Serial Link
Where do you get the Serial Link
RC Ducky is offline Find More Posts by RC Ducky
Old Jul 19, 2014, 01:20 PM
Joined Apr 2011
Forget question....I have no brain!!!
Discussion Need help with FW updates & nano w/ SL as xdp joshgluck Xtreme Power Systems 24 Jul 05, 2014 09:50 PM
Discussion XDP and Nano 1 - programming rebell Xtreme Power Systems 5 Dec 28, 2013 05:17 AM
Discussion Serial Link Information JimDrew Xtreme Power Systems 21 Oct 05, 2013 11:02 PM
Discussion Serial Link??? jcyr1 Xtreme Power Systems 3 Oct 04, 2013 12:01 AM
Discussion Serial Link and XDP hardware interaction JimDrew Xtreme Power Systems 0 Sep 24, 2013 10:19 PM
