Old Jun 28, 2013, 02:08 AM
billisfree's Avatar
Joined Oct 2012
Question
What burns up first?
Lets say we have a 20amp motor, 20 amp ESC and a 20 amp battery.
IF we go to a 40 amp motor... will the ESC or Battery be damaged?
Likewise:
IF we go to a 40 amp ESC will the motor or battery be damaged?
IF we go to a 40 C (amp) battery will motor or ESC be damaged?
I supposed one is supposed to program the Xmitter to limit the amps?
billisfree is offline Find More Posts by billisfree
Old Jun 28, 2013, 02:22 AM
Staffs, UK
Joined Nov 2003
First thing....there's really no such thing as a "40amp motor". The actually current is controlled by the motor plus the load on it (i.e. the prop). A motor which might be safe at 40A will still only take 10A, 20A etc if it has a reasonably small prop on it. And if the motor is taking less than the ESC and battery are capable of there is never a problem.
If the motor is TRYING to take more the battery or ESC are capable of then either:
a) the battery may not provide all that's being asked for (which may damage it) or
b) the ESC may be damaged because there's too much current going through it
One is actually supposed to choose components that will work together. Relying on programming the Tx to make incompatible components sort of work is not a good idea .
Steve
slipstick is online now Find More Posts by slipstick
Old Jun 28, 2013, 02:27 AM
Kilsyth, Victoria, Australia
Joined Oct 2003
Essentially, you can forget the battery because IF the propeller to which is attached to the motor does not cause the system to draw in excess of 20 amps then battery capacity doesn't matter providing it is has sufficient capacity or has a high enough 'C' rating to handle a 20 amp system.
Going to a 40 amp motor means nothing. It is only the motor AND the prop which is fitted that draws any current other than a very small draw when running free.
Same with the ESC and even the battery. The prop is what cause the system to do the work.
David Hipperson is offline Find More Posts by David Hipperson
Old Jun 28, 2013, 03:10 AM
Letchworth, Great Britain (UK)
Joined Jul 2004
Originally Posted by billisfree View Post
...IF we go to a 40 C (amp) battery will motor or ESC be damaged?
As others have said, you don't limit the amps using the transmitter; you limit the amps by the prop you put on the motor. In theory, if a certain prop is making a "20A" motor draw 20 amps, then when it's on a bigger "40A" motor, it will still only make that motor draw 20 amps with the same battery voltage.
"40C" on a battery doesn't mean it can deliver 40 amps: To find out how many amps a battery can comfortably deliver you multiply its Ah capacity (that's mAh divided by 1000) by its C number. So, for example, a 2200mAh 30C pack should be capable of delivering 66 amps (2.2 x 30) comfortably. In practice you should sometimes take the manufacturers' C numbers with a pinch of salt though.
abenn is offline Find More Posts by abenn
Old Jun 28, 2013, 03:32 AM
billisfree's Avatar
Joined Oct 2012
You guys answered my question pretty good.
Now... I assume a motor with no prop attached will reach it's rated kv (like 1400kv) and draw very little current? Correct?
AND if a motor has big prop so that it is unable to reach it's rated kv... then there's a heavy current draw??? Such that the motor will overheat?
So now... if motor overheats... the smart move is to find a smaller prop?
Old Jun 28, 2013, 03:49 AM
Glow 😡 no no no
Australia, SA, Evanston Park
Joined Mar 2010
Smart move is to get a wattmeter in the beginning and avoid future problems.
Something like this, http://www.hobbyking.com/hobbyking/s...=6380&aff=3664 I know guys with these and they work well.
aeromaniac is online now Find More Posts by aeromaniac
Old Jun 28, 2013, 04:20 AM
United States, OR, The Dalles
Joined Apr 2011
Yes, current draw will likely be small if no prop is installed. Current draw will be large with a large prop. If something prevents the prop from spinning, current draw will be very high.
If you overload an ESC, or don't provide adequate cooling air, it can fail suddenly or burn up. If the ESC is also providing power to the reciever and servos via a built in BEC, you will loose control of the plane.
If you run recommended components things will likely be fine. Otherwise use a power meter to check amps and watts and make sure everything is within spec.
JeffinTD is offline Find More Posts by JeffinTD
Old Jun 28, 2013, 06:13 AM
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Simple answer... yes
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Jun 28, 2013, 06:31 AM
Staffs, UK
Joined Nov 2003
Just to be clear, as soon as you put any load on a motor it will turn at less than the theoretical rpm (V x Kv) and the current will increase over the minimum no-load current. The way we use our motors it's quite rare to run at much more than about 80% of V x Kv.
Steve
Old Jun 28, 2013, 11:36 AM
Da' Cajun
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
...my money.
Boogie_ is offline Find More Posts by Boogie_
Old Jun 28, 2013, 12:25 PM
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
The most overstressed component is most likely to fail first.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Jun 28, 2013, 03:48 PM
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Best answer of the bunch.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Jun 28, 2013, 04:20 PM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
United States, AK, Fairbanks
Joined Aug 2009
A very important note on "recommended components" is that motors will often have a couple different recommended prop sizes and battery cell counts. You might see a 10x6, 8x4, and 6x5 recommended for the same motor, and it might be rated for 2-4S batteries. Going off this info, you might try to run 4S with a 10x5 prop... and the motor would smoke instantly. The unseen rule is that the bigger props ALWAYS go with the lower voltages.
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old Jun 28, 2013, 04:22 PM
United States, NJ, Frenchtown
Joined Mar 2003
If you goto a place like adamonerc web calculator . He has a pictorial graph that shows ALL the data you are looking to juggle around & get the best speed power & duration with any combinations.
cyclops2 is online now Find More Posts by cyclops2
Alert Brown Bluff is burning up slopepilot Slope 24 May 05, 2013 03:06 PM
Help! Will me ESC burn up? jdidio1 Electric Ducted Fan Jet Talk 13 Apr 05, 2013 09:51 PM
Help! Burned up my first brushless NDflyer Power Systems 14 Aug 26, 2009 01:50 PM
Discussion Motor burned up after first flight, not sure why Bo Heck Beginner Training Area (Aircraft-Electric) 7 Jun 09, 2009 04:01 AM
Discussion I just re-wound my first motor but one stator burns up rampman Electric Motor Design and Construction 4 Mar 07, 2008 02:45 PM
