Old Feb 22, 2013, 06:49 PM
United States, CA, Signal Hill
Joined Aug 2009
Help!
HobbyWing Platinum PRO 150A-OPTO ESC
how to i get the throttle signal to work ?
im setup just like in this picture on a trex 600 do i need a 7 ch tx for this type setup ? and if so how can i use this with a 6ch rx ?
should i use the signal wire from the esc and stick it into share with the 3rd spot on the bec ?
wc_wickedclown is offline Find More Posts by wc_wickedclown
Old Feb 22, 2013, 08:32 PM
Joined Aug 2009
how to align 3gx v3 to a 6ch rx HELP!!!!. futaba T6 transmitter HobbyWing Platinum PRO 150A- (2 min 18 sec)
HobbyWing Platinum PRO 150A- pos (1 min 30 sec)
Old Feb 23, 2013, 08:21 AM
Joined Dec 2007
Make sure you didn't remove the red wire from the ESC itself. Many use seperate BECs in their setup, and remove the red wire from the ESC to shut down the internal BEC, but these HV ESCs are opto isolated and do not have internal BECs, therefore all three wires from the ESC must be plugged in to work.
The number of channels you have has no bearing on your ESC working. Your RX has a throttle port and that's all that matters. Plug the ESC into the throttle port and plug the BEC into any open port and it will power the RX.
Xrayted is offline Find More Posts by Xrayted
Old Feb 23, 2013, 01:23 PM
Joined Aug 2009
you are the man
thank you thank you
Old Feb 23, 2013, 01:32 PM
wlee1017's Avatar
Joined Jul 2011
wc, what model futaba rx you use? Without channel 7 or battery port on rx, cannot connect power from 3gx to futaba rx using traditional connection method.
Hobbywing Pro 150 -opto ESC has no bec built-in and you do not need to remove red wires from esc throttle signal wire.
Here is how to hook up 3gx, futaba rx and esc using traditional connection.
1. connect battery / BEC outpout wire to 3gx battery "IN" port.
2. connect to esc thottle signal to 3gx throttle input, last port as shown in diagram.
3. connect 3gx battery "OUT" port to futaba rx channel 7 or battery port.
4. connect purple wire from 3gx to "throttle" channel on futaba rx.
I hope it help.
wlee1017 is offline Find More Posts by wlee1017
Old Feb 23, 2013, 02:19 PM
Joined Aug 2009
thank you
hiphip harray HobbyWing Platinum PRO 150A (0 min 39 sec)
Sold HobbyWing Platinum PRO 150A-OPTO ESC w/ 5A BEC - $80 shipped nuttcaze Aircraft - Electric - Power Systems (FS/W) 1 Jan 09, 2013 03:18 PM
Sold Repost HOBBYWING Platinum 150A OPTO Brushless Motor ESC SL100 Elec 1800 Aircraft - Electric - Power Systems (FS/W) 0 Nov 30, 2012 12:46 PM
Sold HOBBYWING Platinum 150A OPTO Brushless Motor ESC SL100 Elec 1800 Aircraft - Electric - Power Systems (FS/W) 0 Oct 31, 2012 10:06 AM
Wanted Hobbywing platinum pro 150A esc williamleelewis Aircraft - Electric - Power Systems (FS/W) 0 Apr 07, 2012 10:48 PM
For Sale Hobbywing platinum pro 150A opto esc **reduced** postalflyer72 Aircraft - Electric - Power Systems (FS/W) 1 Jul 09, 2011 02:14 AM
