Old Dec 28, 2012, 03:55 PM
cap23244's Avatar
USA, OH, Warren
Joined Jan 2011
dle 35 anyone run one
i waswondering if anyone has been using the dle 35ra.? any issues with the engine. how do you like i
any tips or info i would be greaful
thanks
cap23244 is offline Find More Posts by cap23244
Old Dec 28, 2012, 04:00 PM
Tampa,Fl
Dale 813's Avatar
United States, FL, Tampa
Joined Jan 2007
My buddy just put together a Pilot Rc Edge and installed a brand new DLE 35 RA last week. As up till now he has almost a gallon through it and had zero issues. He been flying way longer than me. Flies big stuff and he has been raving about this motor. Dude was doing rolling harriers, hovers. Idled nice too. He is using 93 octane gas along with a 30-1 mix. Have you used these gas motors before ?
Dale 813 is offline Find More Posts by Dale 813
Old Dec 28, 2012, 04:05 PM
cap23244's Avatar
USA, OH, Warren
Joined Jan 2011
no i got one for xmas and a 3dhs extra 72". just looking for input on them
Old Dec 28, 2012, 05:03 PM
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Ok. One thing is you can't use any two cycle oil mix. A friend bought a quart of mercury outboard mix from Walmart. That's a No No. I use the HP Ultra made by Stihl. It's In a silver container. Unless specifically noted in the manual what oil to use. You can buy this from a Stihl weed eater dealer. There are some others that gasser guys use too. Mix 4.2 ounces of oil to every gallon of 93 octane gas. Ethanol free is preferred but not necessary. My idle is more consistant with 93 than 87. It makes a difference.
Old Dec 29, 2012, 12:26 AM
United States, OR, Canby
Joined Aug 2011
I have one with about 2 hrs on the ground. I find it hard to hand start at times, I often use an electric starter with it. Seems to idle and run good.
600Bob is offline Find More Posts by 600Bob
Old Dec 29, 2012, 01:55 PM
cap23244's Avatar
USA, OH, Warren
Joined Jan 2011
i heard they should not be broke in on the ground i would cause them to over heat.?
Old Dec 29, 2012, 02:40 PM
Joined Aug 2011
As I recall the manual called for 2 hrs on the ground, usually mounted on the plane. I didn't have the cowl on. Never had an engine run hot. I had to wear gloves because the wind from the prop was so cold!
Old Dec 29, 2012, 04:24 PM
cap23244's Avatar
USA, OH, Warren
Joined Jan 2011
ok
i will look at the maual agian
Old Dec 29, 2012, 07:15 PM
Joined Aug 2011
I looked at the manual. On the back page it says "Breaking-in at 4000RPM/min for 2 hours. Running at low speed for too long might carbonize the spark plug."
It doesn't say on the ground but the RPM limitation made me think that would be what they were talking about. It also says 4000RPM Min. Other engines usually say MAX so I was a little easier on it there too, not running it hard for the first 30 min. or so. I still spent about 2 hrs. time between some initial run time before going to full throttle, which I don't like to do on a new engine, and then the tuning. Mine seemed very rich on the low end and took some fiddling with before I got it where I liked it.
Old Dec 29, 2012, 08:11 PM
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
You should be able to hover at 4000 rpm. Most of the power comes at around that range anyway.
Wanted DLE 20 -Anyone have one? ant1 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jul 31, 2012 07:46 PM
For Sale DLE 55 never run in the box lla Aircraft - Fuel - Engines and Accessories (FS/W) 1 May 25, 2012 09:32 AM
For Sale BNIB Pilot-RC Extra 260 35% + DLE-111 + CANS metalfred Aircraft - Fuel - Airplanes (FS/W) 0 May 14, 2012 08:08 AM
Question Cool Running Heli ESC's - Anyone use one? GBR2 Micro Helis 2 Jan 04, 2006 03:24 PM
Mini-T Pro, Anyone running one? War Bird Radio Micro Cars 3 Nov 17, 2004 03:56 PM
