Old Nov 12, 2012, 08:20 PM
Held by Grace
BDOG1's Avatar
Upstate New York
Joined Apr 2006
Thread size for Dynamight .15 ?
Hey Guy's - I am looking to buy a collet for a Dynamight .15 marine engine ,any one know the thread size?
The motor was given to me and I thought I would put it in a Zippkits Jae.12 on my winter build list.
Any other info {prop,pipe lenght ect would be helpfull
Will be running 40% nitro fuel
I know there are lots of other higher HP options out there,thought I would play with this and see what it can do - Thanks Mike
BDOG1 is offline Find More Posts by BDOG1
Old Nov 12, 2012, 09:45 PM
Joined Feb 2012
I am sure you could buy an Octura collet that would work look it up.
MN fish is offline Find More Posts by MN fish
Old Nov 13, 2012, 10:17 AM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
Most .12-.18's have 5mm threads on the output shaft, the Dynamite should be the same.
As far as props go, a non-lifting prop will make it easier to drive. An Octura X-437 or Prather 215 would be 2 good places to start.
Pipe length varies according to the pipe but usually 8-1/2" from the glow plug following the flow of the exhaust to the widest part of the pipe should get you close.
I've built 2 of the JAE .12's, versions 1 and 2 but not the ultra-light.
Watch which Octura collet that you get was one of the 5mm versions is not threaded, it's made for electric motors. The part numbers tell the story. It'll have the 5MM in it plus what cable size you're using, .125" or .150".
Ron Olson is online now Find More Posts by Ron Olson
Old Nov 13, 2012, 10:50 AM
Held by Grace
BDOG1's Avatar
Upstate New York
Joined Apr 2006
Thank You Ron for you answer,that should get me in the ball park to start out with
Old Nov 13, 2012, 11:33 AM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
It's a start.
When I began messing around with the .12's, I started with a Trinity/Picco/Nova Rossi which wasn't the fastest one around but it was dependable if not anything. I've still got it 12 years later and still running great. I also run air-cooled as they don't need water cooling, just lopping off most of the heat sinks. It won't be a rocket but you can always upgrade later.
If you need a few tips and tricks on the 'rigger, I can help you out there.
Old Nov 14, 2012, 10:54 AM
Held by Grace
BDOG1's Avatar
Upstate New York
Joined Apr 2006
Super Ron - I will drop you a pm when I start the build
Old Nov 14, 2012, 10:56 AM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
OK. It's just a few small things but they do help.
Discussion The official thread for electric powered setups for 50cc sized 3D airplanes racin06 Giant Electric Planes 224 Apr 29, 2014 04:30 AM
Sold E-Flite 10-15 Size Retacts for Main Gear jeb6684 Aircraft - Electric - Airplanes (FS/W) 3 Jul 01, 2012 08:08 PM
Sold Aluminum spinners-All Sizes Buy two & get one FREE for just $15 each plus shipping!!! unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 6 Apr 16, 2012 06:13 PM
Sold 10/15 size spring struts. 15.00 a pair shipped ryramZ Aircraft - Electric - Airplanes (FS/W) 5 Apr 11, 2012 11:32 AM
Discussion PAW .15 thread size CashRC Vintage & Old-Timer Designs 7 Apr 02, 2010 11:15 PM
