Old Oct 10, 2012, 09:36 AM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Covering ?
is this ok ? easy to work with ?:
http://www.ebay.com/itm/Top-Flite-Mo...item256484122f
How is it compared to oracover ?
I want a cover that is easy to attache, never done it before, want to cover a balsa build kit
Sebbe
sebbe is offline Find More Posts by sebbe
Old Oct 10, 2012, 10:15 AM
Fueled by Arabica Beans
ChillPhatCat's Avatar
United States, NY, Syracuse
Joined Oct 2008
I mostly cover with Monokote. It's not as easy to bend around corners as other coverings, and the backing is clear so sometimes it's a pain to find the edge... but that said it's tough and the adhesive never fails and it has a nice glossy finish. It takes high temp around 350-375F to bend around compound curves and some patience, but it will submit to whatever shape you want it to take.
ChillPhatCat is online now Find More Posts by ChillPhatCat
Old Oct 10, 2012, 10:25 AM
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Monokote seems to be about the standard in the US - I've been using it since I got here in 1994, as it can be bought at about any hobby shop around.
Like all coverings, it comes with an instruction sheet that gives suggested temperatures for adhering the covering to the structure and then shrinking it. I have found Monokote to be very flexible as to temperatures, but use a digital thermometer to check the temperature of my covering iron.
I have found it to be very good at covering around areas with changes in section and direction. It also sticks well to itself, as long as it is placed over a cleaned area with no grease, fingerprints or such on it.
To shrink it over an open framework, I use a heat gun of the sort produced for model aircraft coverings. Again, Monokote appears flexible as to temperature, though you can burn the covering if you held the heat gun against one spot too closely or for too long.
Monokote is about the heaviest of the iron on film coverings on the market. While it works well on larger, stiffer structures, I would not use it on small models with more flexible structures, as it could easily warp such a model when the Monokote was shrunk tightly.
Hope that helps
Dereck is offline Find More Posts by Dereck
Old Oct 10, 2012, 10:46 AM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
ok, thanks guys, helps...
Old Oct 10, 2012, 11:37 AM
Joined Oct 2008
Hope that helps
I agree, it will basically do whatever you want it to with the help of a heat gun and some time, and great care is needed for smaller structures like you said, it pulls hard on the structure when it shrinks, so it's not ideal for light/small models.
Old Oct 10, 2012, 02:00 PM
Dude, get me some ice cream!
Felt_ripper 23's Avatar
United States, MA, Amherst
Joined Apr 2012
Yea, I like the way monokote looks and cuts.
I can cover with monokote, but I always end up with a ton of wrinkles, especially on bare wings. How do I shrink the covering to solve this?
Felt_ripper 23 is offline Find More Posts by Felt_ripper 23
Old Oct 10, 2012, 02:32 PM
Joined Oct 2008
For large flat areas I tack around the perimiter and hit it with a heat gun until it's tight. Sometimes I cut the job into smaller sections for hard areas like near the tail... I'm not afraid of seams, but I do not like wrinkles. If you're bending around a wing tip or something similar, just keep heating it and pulling around the corners until the whole thing is covered without wrinkles and then I cut away the excess... it's a lot like vacuum forming, just without a mold. As with all things, it takes practice... my first several planes definitely had wrinkles in the more curvy areas.
Old Oct 10, 2012, 06:13 PM
Joined Apr 2012
Thanks for the tips. As is, my current scratch-build in progress is using good ole' fashioned tissue. My barely used, nice Hangar 9 iron is just sitting around. But sooner or later I will get more into film. It is a good skill. Besides, I have only tried monokote...
Old Oct 10, 2012, 06:14 PM
Joined Apr 2012
oops, put the pic of the ember 2 by accident
Help! Help with tissue covering? yapoyo Free Flight 17 Jun 19, 2012 08:45 PM
For Sale Woodpecker covering perforation tool- east Orlando FL kinseyd Aircraft - General - Miscellaneous (FS/W) 2 Jun 14, 2012 03:22 PM
Wanted Need covering iron nerv Aircraft - General - Miscellaneous (FS/W) 0 Jun 13, 2012 08:22 PM
Found eflite edge 540 covering rcrick10 Aircraft - General - Miscellaneous (FS/W) 0 Jun 12, 2012 01:23 AM
For Sale It turns out that the 53 had a plain rocker cover and the 63 had a black rocker cover rpwarehime Aircraft - Fuel - Engines and Accessories (FS/W) 4 Apr 01, 2012 09:54 PM
