Old May 21, 2003, 01:52 PM
Monterrey NL. Mexico
Joined Oct 2001
How long is the hummingbird tailboom, :)
I would like to know if someone can tell me what is the length of the hummingbird tailboom. I have nice cf tube(wich i'm planning to use as fuse for a scratch slowflyer) but i don't want to cut it and get a short boom or fuse.
Thanks guys.
ermit ...
ermit is offline Find More Posts by ermit
Old May 21, 2003, 01:59 PM
Steve McBride's Avatar
Agra, Oklahoma
Joined Feb 2000
ermit,
I don't recall the length, but if you are off a bit it won't do any harm. Making it a bit longer will help with the tail rotor by lessening the load a bit and it does not look bad. I added a smigen to mine when I replaced the boom.
Good luck with it!
Steve
PS - aluminum tube also works but is easily dented.....
Steve McBride is offline Find More Posts by Steve McBride
Old May 21, 2003, 02:29 PM
2013 GRAND SPORT CORVETTE
Hoverup's Avatar
Golden Gulf Coast
Joined Jul 2002
Re: How long is the hummingbird tailboom, :)
Thanks guys.
ermit ...
Basic rule of thumb: Make it long enough so that the arc of the main rotor blades do no intersect the arc of the tail rotor blades. Longer gives more tail authority as posted. Measured length is 330 mm/or about 13 inches tip end to tip end prior to installation.
Cheers - Boyd
AMA 80393
Major USAF
Retired
Hoverup is offline Find More Posts by Hoverup
Old May 21, 2003, 02:48 PM
Joined Oct 2001
Oooooo... Sadnes ... I can get almost 30 cm of free length out of that cf tube... ... O well, but i'm going to finish with a not so ugly more or less stubenfliege look like plane...
I have some arrows. Maybe they can be converted to booms .
Thank you for the help guys(Huverup and Steve).
ermit.
How long have you been flying electric? Michael in Toronto Electric Plane Talk 55 Feb 03, 2009 12:44 PM
How long will my batteries last Masterpiece Beginner Training Area (Aircraft-Electric) 1 Jun 27, 2001 06:38 AM
IFO, 280, 4:1 box, how long does motor last? rktung Parkflyers 2 Jun 12, 2001 07:54 AM
GWS R4P Receiver - How long is your antenna? realdeal Electric Plane Talk 11 May 11, 2001 12:01 AM
How long do you want the wires on the pack to be? rcdude Electric Plane Talk 10 Apr 28, 2001 11:52 AM
