Old Oct 21, 2002, 03:31 PM
sizam is offline
Find More Posts by sizam
sizam's Avatar
Mountain View, CA
Joined Aug 2002
Various charger technical questions
-When using a charger is whatever your input voltage is also the output voltage to the battery, or is the voltage regulated? I know you regulate the current to a battery given its capacity but what about the voltage given the number of cells?
-How does the charger regulate the current? Does it use a digital device to send PWM signals to a mosfet/h-bridge/transistor which (through switching) controls the current? Or can that only control voltage and you have to use some sort of pot to control current?
These are pretty broad questions and I'll appreciate any answers
sizam is offline Find More Posts by sizam
Old Oct 21, 2002, 03:49 PM
sizam is offline
sizam's Avatar
Mountain View, CA
Joined Aug 2002
Ok, so resistance regulates current. I can see how this would work in some chargers, the ones with dials, they probably turn a POT which changes the resistance. But how does a charger like the Super Turbo or Supernova do this? There are no dials, only buttons, does it route the current over different resistors within the device? Is that why there are only certain current values available, usually in steps of 100 mA?
Old Oct 21, 2002, 06:49 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
The output voltage is regulated by the battery under charge (at least nickel-based chemistries) as long as the charger is capable of putting out a higher one. For chargers that can do more than 7 cells there is a voltage-multiplier of some variety to boost that possible output voltage above the nominal 12V in.
Current regulation...... I don't think there are any other than the cheapest chargers out there which do it by simply dumping power into a (variable) resistor any more - if they did it that way the charge current would continually fall as the battery under charge's voltage increased which plays havoc with reliable peak detection. I presume, therefore that there is some sort of PWM scheme involved though I have never looked into this aspect.
I do know the little Multiplex (also sold by Dymond and FMA) charger with the three charge currents selected by a switch must do it by PWM at a fairly low frequency because you can hear it "sing" under load and the sound changes with the three different current selections (1, 2, 4A).
BEC is offline Find More Posts by BEC
Old Oct 22, 2002, 03:36 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
Most chargers use a standard electronic circuit block known as a "current source" for regulating current. There are number of variants used but they all allow the current to be defined by an input voltage (not the same voltage as the output to the battery). If you're really interested in this particular aspect of the internal design of chargers I suggest a web search on "current source" or "constant current source" (even though it's really variable).
Steve
steve lewin is offline Find More Posts by steve lewin
Old Oct 22, 2002, 01:30 PM
sizam is offline
sizam's Avatar
Mountain View, CA
Joined Aug 2002
Ah, yes in my searches I keept seeing 'constant current source' come up but thought "Thats not what I want, I want a variable current source.". I'll look back into those circuits. And thanks for pointing out that just a pot won't work, I had actually started looking into digital pots, and someone suggested a DAC coupled with an current opAmp...
Charger Experts - Questions on GWS-MC2002 Aspen Batteries and Chargers 17 Apr 26, 2009 06:11 PM
Orbit charger usage questions....... rktung Batteries and Chargers 1 Apr 25, 2003 11:18 AM
I have a battery pack ,Charger and solder questions jayboy Parkflyers 9 Jan 13, 2003 10:56 PM
Triton Charger/Discharger Questions rscamp Batteries and Chargers 1 Dec 08, 2002 07:58 PM
Battery/charger related questions Xoltri Parkflyers 1 Jul 21, 2002 02:48 AM
