Old Feb 04, 2016, 03:33 PM
ditonics is offline
Find More Posts by ditonics
United Kingdom, England, Kent
Joined Aug 2015
Lookinf for ESC with hall effect parking for SLS
Do any of the current ESC manufacturers offer a hall effect sensor input for parking a prop in a specific position, EG in a SLS system.
Schulze used to do a range that were capable of this, the 'future' range of ESC's but they have not been made in several years now.
I have looked for a replacement but I am drawing a blank.
Any help appreciated
ditonics is offline Find More Posts by ditonics
Old Feb 05, 2016, 03:42 PM
Lou is offline
Lou
Find More Posts by Lou
Lou
Ground Penetration Tester
United States, VA, Waynesboro
Joined Dec 2005
Maybe not quite the answer you are looking for but have you seen this ....
http://www.icare-rc.com/self_launch_systems.htm
http://www.klapptriebwerk.de/uber-uns/?lang=en
Certainly not cheap but fun to dream about.
Lou is offline Find More Posts by Lou
Old Feb 05, 2016, 04:10 PM
ditonics is offline
Joined Aug 2015
Thanks for the reply but maybe I didn't explain too well.
I have a 1:3 scale LET Ventus with a SLS 22 installed. It has been modified to 'park' the propeller in the correct position for retracting the SLS system via a hall effect sensor installed in the SLS arm and a pair of magnets in the prop. The current ESC (a schulze future L 32) is capable of positioning the prop so the magnet lines up with the hall effect sensor ready to retract the prop into the fuz.
I was wondering if an alternative ESC existed.
This shows the system in effect on a LET discus 'not mine'
Discus 2cT with SLS22 from LET Model #3 (2 min 41 sec)
And this is mine on the Ventus currently with a dead ESC
LET Ventus 2cx - retract and SLS (0 min 47 sec)
Question Hall effect magnetic model switch cct nicholg DIY Electronics 13 Apr 04, 2014 10:10 AM
Discussion Using Different Hall Effect RPM Sensor with Recorder/Pro jrandle Eagle Tree Systems 2 Jun 25, 2011 01:04 AM
Discussion Brushless with Hall Effect MacgMan Power Systems 4 Nov 07, 2007 06:14 AM
Discussion hall effect for rpm birdofplay DIY Electronics 3 Jan 28, 2007 02:35 PM
Tach for DC Motor using Hall-Effect evolive DIY Electronics 1 May 11, 2004 07:03 AM
